[PATCH 00/14] Removal of or32/openrisc and introduction of or1k
Hesham Moustafa heshamelmatary at gmail.com
Wed Apr 23 15:35:48 UTC 2014
Yes it's. Hope that gcc and gdb come next (soon).
On Wed, Apr 23, 2014 at 5:27 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
>  Looks like the OpenRISC is now in binutils.
> -------- Original Message --------  Subject: Re: [PATCH 00/14] Removal of
> or32/openrisc and introduction of or1k  Date: Wed, 23 Apr 2014 00:35:04
> -0500  From: Alan Modra <amodra at gmail.com> <amodra at gmail.com>  To: Christian
> Svensson <blue at cmd.nu> <blue at cmd.nu>  CC: Nicholas Clifton
> <nickc at redhat.com> <nickc at redhat.com>, "binutils at sourceware.org"<binutils at sourceware.org>
> <binutils at sourceware.org> <binutils at sourceware.org>
> On Tue, Apr 22, 2014 at 08:06:13PM +0100, Christian Svensson wrote:
> > Hi,
> > On Tue, Apr 22, 2014 at 4:02 PM, Nicholas Clifton <nickc at redhat.com> <nickc at redhat.com> wrote:
> > > They have been committed.
> > Thanks!
> --enable-maintainer-mode --enable-cgen-maint=yes --enable-targets=all
> cgen -s /src/binutils-gdb/opcodes/../cgen/cgen-opc.scm -s /src/binutils-gdb/opcodes/../cgen -v -f opinst -m all -a /src/binutils-gdb/opcodes/../cpu/or1k.cpu -OPC /src/binutils-gdb/opcodes/../cpu/or1k.opc -H tmp-9072-desc.h1 -C tmp-9072-desc.c1 -O tmp-9072-opc.h1 -P tmp-9072-opc.c1 -L tmp-9072-ibld.in1 -A tmp-9072-asm.in1 -D tmp-9072-dis.in1 -Q tmp-9072-opinst.c1
> Setting option `opinst' to "".
> Loading cpu description /src/binutils-gdb/opcodes/../cpu/or1k.cpu ...
> machs:   all
> isas:    all
> options: opinst
> trace:
> diags:
> Including file /src/binutils-gdb/opcodes/../cpu/simplify.inc ...
> Including file /src/binutils-gdb/opcodes/../cpu/or1kcommon.cpu ...
> Including file /src/binutils-gdb/opcodes/../cpu/or1korbis.cpu ...
> Including file /src/binutils-gdb/opcodes/../cpu/or1korfpx.cpu ...
> Processing cpu description /src/binutils-gdb/opcodes/../cpu/or1k.cpu ...
> Canonicalizing instruction semantics ...
> ERROR:
> While canonicalizing (set () BI sys-sr-ov (mul-o2flag WI rA rB)), operand #3 of:
> (sequence
>   (sequence
>     (set BI sys-sr-ov (mul-o2flag WI rA rB))
>     (set BI sys-sr-cy (mul-o1flag WI rA rB))
>     (set rD (mul WI rA rB)))
>   (if (andif sys-sr-ov sys-sr-ove)
>       (c-call VOID "@cpu at _exception" pc EXCEPT-RANGE)))
> @ /src/binutils-gdb/opcodes/../cpu/simplify.inc:173:3: referenced from:
> /src/binutils-gdb/opcodes/../cpu/simplify.inc:174:2(end): referenced from:
> /src/binutils-gdb/opcodes/../cpu/or1korbis.cpu:720:1: referenced from:
> /src/binutils-gdb/opcodes/../cpu/or1korbis.cpu:736:2(end):
> simplify.inc:173:3: canonicalizing semantics of l-mul: unknown rtx function: (mul-o2flag WI rA rB)
> No backtrace available.
> make[5]: *** [run-cgen] Error 1
> Alan Modra
> Australia Development Lab, IBM
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140423/861f532c/attachment-0001.html>
