[PATCH] score: Split _Terminate and call _Terminate_CPU_Fatal_halt.
Sun Apr 27 12:30:12 UTC 2014
On 04/27/2014 02:13 PM, Chris Johns wrote:
> Splitting the call to _CPU_Fatal_halt out into a separate function
> allows the rtems-test gdb support the ability to halt once the
> _Terminate function has completed it's work.
> This change allows the BeagleBoard xM BSP to pass a number of
> important tests.
I don't find a BeagleBord BSP in the tree.
In case the BSP has to do fancy things during termination, why don't you
do this in bsp_reset() or bsp_fatal_extension()?
I guess the bsp.h has no:
#include <bsp/default-initial-extension.h>
The way to control the termination sequence is via user extensions and
not weak functions.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
