[PATCH] spcache01: Add tests for misaligned cache access
    Joel Sherrill
    Joel.Sherrill at OARcorp.com
    Thu Apr 10 16:27:47 UTC 2014
Does this run without faulting on a strict alignment architecture like the MIPS?
On Apr 10, 2014 11:24 AM, Ralf Kirchner <ralf.kirchner at embedded-brains.de> wrote:
 testsuites/sptests/spcache01/init.c        |   81 ++++++++++++++++++++++++++++
 testsuites/sptests/spcache01/spcache01.doc |    1 +
 testsuites/sptests/spcache01/spcache01.scn |    2 +
 3 Dateien geändert, 84 Zeilen hinzugefügt(+)
diff --git a/testsuites/sptests/spcache01/init.c b/testsuites/sptests/spcache01/init.c
index 2c9d184..4be1040 100644
--- a/testsuites/sptests/spcache01/init.c
+++ b/testsuites/sptests/spcache01/init.c
@@ -37,6 +37,86 @@ const char rtems_test_name[] = "SPCACHE 1";
 CPU_STRUCTURE_ALIGNMENT static int data[1024];
+static void test_misalignment(void)
+  if (rtems_cache_get_data_line_size() > 0) {
+    rtems_interrupt_lock         lock;
+    rtems_interrupt_lock_context lock_context;
+    volatile int                *vdata      = &data[0];
+    int                         *tdata      = &data[2];
+    const uint32_t               LINE_SIZE  = rtems_cache_get_data_line_size();
+    int                          tcount     = LINE_SIZE;
+    int                          vcount     = tcount + 3 * LINE_SIZE;
+    size_t                       tdata_size = tcount * sizeof(data[0]);
+    bool                         write_through;
+    int                          i;
+    int                          end;
+    printf("data cache flush and invalidate test with misaligned addresses\n");
+    rtems_interrupt_lock_initialize(&lock, "test");
+    rtems_interrupt_lock_acquire(&lock, &lock_context);
+    for (i = 0; i < vcount; ++i) {
+      vdata[i] = i;
+    rtems_cache_flush_multiple_data_lines(tdata, tdata_size);
+      rtems_test_assert(vdata[i] == i);
+      vdata[i] = ~i;
+    rtems_cache_invalidate_multiple_data_lines(tdata, tdata_size);
+    end = (tdata_size + LINE_SIZE) / sizeof(data[0]);
+    write_through = vdata[LINE_SIZE / sizeof(data[0])] == ~LINE_SIZE / sizeof(data[0]);
+    if (write_through) {
+      for (i = 0; i < end; ++i) {
+        rtems_test_assert(vdata[i] == ~i);
+    } else {
+      for( i = 0; i < end; ++i) {
+    i = end;
+    end = i + LINE_SIZE + LINE_SIZE;
+    for( ; i < end;  ++i) {
+      vdata[i] = ~i;
+    rtems_interrupt_lock_release(&lock, &lock_context);
+    rtems_interrupt_lock_destroy(&lock);
+    printf(
+      "data cache operations with misaligned addresses passed the test (%s cache detected)\n",
+           write_through ? "write-through" : "copy-back"
+  } else {
+    printf(
+      "skip data cache flush and invalidate test with misaligned addresses"
+      " due to cache line size of zero\n"
 static void test_data_flush_and_invalidate(void)
@@ -376,6 +456,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
   test_data_flush_and_invalidate();
+  test_misalignment();
   test_timing();
   TEST_END();
diff --git a/testsuites/sptests/spcache01/spcache01.doc b/testsuites/sptests/spcache01/spcache01.doc
index bbc8f25..1a56be8 100644
--- a/testsuites/sptests/spcache01/spcache01.doc
+++ b/testsuites/sptests/spcache01/spcache01.doc
@@ -17,3 +17,4 @@ directives:
 concepts:
   - Ensure that some cache manager functions work.
+  - Ensure they also work with misaligned addesses
diff --git a/testsuites/sptests/spcache01/spcache01.scn b/testsuites/sptests/spcache01/spcache01.scn
index 8013945..53d3e70 100644
--- a/testsuites/sptests/spcache01/spcache01.scn
+++ b/testsuites/sptests/spcache01/spcache01.scn
@@ -2,6 +2,8 @@
 data cache operations by line passed the test
 data cache operations by line passed the test (copy-back cache detected)
+data cache flush and invalidate test with misaligned addresses
+data cache operations with misaligned addresses passed the test (copy-back cache detected)
 data cache line size 32 bytes
 data cache size 262144 bytes
 data cache level 1 size 32768 bytes
1.7.10.4
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140410/2f81c8ec/attachment-0001.html>
