[PATCH] sparc: store the tpc for asynchronous traps
Mon Apr 14 00:19:31 UTC 2014
This behavior also may appear in older RTEMS versions, with the
affected file in score/cpu/sparc/cpu_asm.S
On Sun, Apr 13, 2014 at 8:04 PM, Gedare Bloom <gedare at rtems.org> wrote:
> The current ISR handling does not save a copy of the PC in the TPC field
> of the interrupt frame for asynchronous traps.
>  c/src/lib/libbsp/sparc/shared/irq_asm.S |    3 +--
>  1 file changed, 1 insertion(+), 2 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> index fc4c0be..fc368a2 100644
> --- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
> +++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> @@ -255,8 +255,7 @@ SYM(_ISR_Handler):
>          andcc   %l3, SPARC_SYNCHRONOUS_TRAP_BIT_MASK, %g0
>                                        ! Is this a synchronous trap?
> -        be,a    win_ovflow            ! No, then skip the adjustment
> -        nop                           ! DELAY
> +        be    win_ovflow            ! No, then skip the adjustment
>          mov     %l1, %l6              ! save trapped pc for debug info
>          mov     %l2, %l1              ! do not return to the instruction
>          add     %l2, 4, %l2           ! indicated
> 1.7.9.5
