[PATCH 00/14] Removal of or32/openrisc and introduction of or1k
Wed Apr 23 22:00:36 UTC 2014
On 4/23/2014 4:57 PM, Hesham Moustafa wrote:
> On Wed, Apr 23, 2014 at 11:48 PM, Christian Svensson <christian at cmd.nu> wrote:
>> On Wed, Apr 23, 2014 at 10:38 PM, Hesham Moustafa
>> <heshamelmatary at gmail.com> wrote:
>>> Here [1] line 76. Please correct me if I misunderstood that. When I
>> That's just setting the default board. If you don't specify a
>> -mboard=something it will default to a board called or1ksim.
> Yes I know. This default board library comes from libgloss (which
> won't be supported
> by RTEMS/newlib), right? But as Dr. Joel?
The or1k-rtems target will have to undef LIB_SPEC and provide our own.
Probably in a file like gcc/config/or1k/rtems.h or similar. Check for
gcc/config/*/*rtems*.h for example names.
