[PATCH 00/14] Removal of or32/openrisc and introduction of or1k
    Hesham Moustafa
    heshamelmatary at gmail.com
    Wed Apr 23 22:03:57 UTC 2014
On Thu, Apr 24, 2014 at 12:00 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 4/23/2014 4:57 PM, Hesham Moustafa wrote:
>> On Wed, Apr 23, 2014 at 11:48 PM, Christian Svensson <christian at cmd.nu> wrote:
>>> On Wed, Apr 23, 2014 at 10:38 PM, Hesham Moustafa
>>> <heshamelmatary at gmail.com> wrote:
>>>> Here [1] line 76. Please correct me if I misunderstood that. When I
>>> That's just setting the default board. If you don't specify a
>>> -mboard=something it will default to a board called or1ksim.
>> Yes I know. This default board library comes from libgloss (which
>> won't be supported
>> by RTEMS/newlib), right? But as Dr. Joel?
> The or1k-rtems target will have to undef LIB_SPEC and provide our own.
> Probably in a file like gcc/config/or1k/rtems.h or similar. Check for
> gcc/config/*/*rtems*.h for example names.
Thanks.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
