[PATCH] testsuite: Add a per BSP test check for tests not to build.
Sebastian Huber
Thu Apr 24 06:44:06 UTC 2014
On 2014-04-24 07:44, Chris Johns wrote:
> Provide a file per BSP to list tests that do not build for a BSP. This change
> removes the BSP_SMALL_MEMORY hack from the code. That hack was a
> mistake.
> Provide configuration files for each BSP with tests that cannot build.
I think these optional BSP specific test configuration files are an acceptable
solution to replace the BSP_SMALL_MEMORY hack although a matrix is used instead
of two vectors.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
