Error with examples-v2
Federico Lenarduzzi
federico.lenarduzzi at tallertechnologies.com
Thu Apr 24 21:20:10 UTC 2014
I already set RTEMS_MAKEFILE_PATH variable as you mentioned. Are you
following the same tutorial? These steps are OK ?
Thanks for help me.
2014-04-24 18:05 GMT-03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 4/24/2014 3:55 PM, Federico Lenarduzzi wrote:
> Hi everybody, I'm trying compile the examples following this steps:
> http://www.rtems.org/wiki/index.php/Example_Application_Compiling
> If you did a "make install" on the build tree, then this is all that would
> be required.
> export RTEMS_MAKEFILE_PATH=/home/admin/rtems/arm-rtems4.11/lpc1768
> make
> I probed for lpc1768 and lm3s6965 but with both configurations didn't
> work. Exist files which aren't generated.
> *admin at laptop ~/examples-v2 $* make
> /home/admin/rtems/make/custom/lm3s69xx.inc:5:
> /home/admin/rtems/make/custom/default.cfg: No such file or directory
> make: *** No rule to make target
> `/home/adm1/rtems/make/custom/default.cfg'. Stop.
> Note: I use --prefix:/home/admin/rtems as installation point.
> An alternative: "hardcode". In other words, paste the files missing into
> appropriate folders. After that, the errors disappeared. However, when I
> compile the hello world example, throws a new error.
> *admin at laptop ~/examples-v2/hello/hello_world_c $* make
> make: *** No rule to make target `/test.o', needed by `/hello.exe'. Stop.
> Any suggestion? Someone have or had problems with examples?
> <http://www.tallertechnologies.com>
> *Federico Lenarduzzi*
> Software Engineer
> Taller Technologies Argentina
> San Lorenzo 47, 3rd Floor, Office 5
> Cordoba, Argentina
> Phone: +54 351 4220701
> Mobile: +54 358 4289083
> Skype: federico.lenarduzzi1
> <https://www.facebook.com/tallertechnologies> <http://www.linkedin.com/company/taller-technologies>
> Joel Sherrill, Ph.D. Director of Research & Developmentjoel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
Software Engineer
Cordoba, Argentina
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140424/3fabd116/attachment-0001.html>
