Error with examples-v2
Gedare Bloom
gedare at rtems.org
Thu Apr 24 23:08:58 UTC 2014
You may be interested to read the README.waf and try to use that to build
the examples instead of Make.
On Thu, Apr 24, 2014 at 5:20 PM, Federico Lenarduzzi <
federico.lenarduzzi at tallertechnologies.com> wrote:
> I already set RTEMS_MAKEFILE_PATH variable as you mentioned. Are you
> following the same tutorial? These steps are OK ?
> Thanks for help me.
> 2014-04-24 18:05 GMT-03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 4/24/2014 3:55 PM, Federico Lenarduzzi wrote:
>> Hi everybody, I'm trying compile the examples following this steps:
>> http://www.rtems.org/wiki/index.php/Example_Application_Compiling
>> If you did a "make install" on the build tree, then this is all that
>> would be required.
>> export RTEMS_MAKEFILE_PATH=/home/admin/rtems/arm-rtems4.11/lpc1768
>> make
>> I probed for lpc1768 and lm3s6965 but with both configurations didn't
>> work. Exist files which aren't generated.
>> *admin at laptop ~/examples-v2 $* make
>> /home/admin/rtems/make/custom/lm3s69xx.inc:5:
>> /home/admin/rtems/make/custom/default.cfg: No such file or directory
>> make: *** No rule to make target
>> `/home/adm1/rtems/make/custom/default.cfg'. Stop.
>> Note: I use --prefix:/home/admin/rtems as installation point.
>> An alternative: "hardcode". In other words, paste the files missing into
>> appropriate folders. After that, the errors disappeared. However, when I
>> compile the hello world example, throws a new error.
>> *admin at laptop ~/examples-v2/hello/hello_world_c $* make
>> make: *** No rule to make target `/test.o', needed by `/hello.exe'. Stop.
>> Any suggestion? Someone have or had problems with examples?
>> <http://www.tallertechnologies.com>
>> *Federico Lenarduzzi*
>> Software Engineer
>> Taller Technologies Argentina
>> San Lorenzo 47, 3rd Floor, Office 5
>> Cordoba, Argentina
>> Phone: +54 351 4220701
>> Mobile: +54 358 4289083
>> Skype: federico.lenarduzzi1
>> <https://www.facebook.com/tallertechnologies> <http://www.linkedin.com/company/taller-technologies>
>> Joel Sherrill, Ph.D. Director of Research & Developmentjoel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
> Software Engineer
> Cordoba, Argentina
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140424/d13e309f/attachment-0001.html>
