Error with examples-v2
Federico Lenarduzzi
federico.lenarduzzi at tallertechnologies.com
Fri Apr 25 11:34:12 UTC 2014
I followed exactly this steps. in the second block, there is a make
install. I'm reading the README.waf. Thanks for your answers.
2014-04-24 21:55 GMT-03:00 Gedare Bloom <gedare at rtems.org>:
> On Thu, Apr 24, 2014 at 8:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Apr 24, 2014 at 7:28 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com
>> > wrote:
>>> If you don't do the make install step then neither will work.
>> Good point, and those wiki instructions don't explicitly say "make
>> install".
> Or, yes they do, in the second block of code.
>> On Apr 24, 2014 6:05 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> You may be interested to read the README.waf and try to use that to
>>> build the examples instead of Make.
>>> On Thu, Apr 24, 2014 at 5:20 PM, Federico Lenarduzzi <
>>> federico.lenarduzzi at tallertechnologies.com> wrote:
>>>> I already set RTEMS_MAKEFILE_PATH variable as you mentioned. Are you
>>>> following the same tutorial? These steps are OK ?
>>>> Thanks for help me.
>>>> 2014-04-24 18:05 GMT-03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>> On 4/24/2014 3:55 PM, Federico Lenarduzzi wrote:
>>>>> Hi everybody, I'm trying compile the examples following this steps:
>>>>> http://www.rtems.org/wiki/index.php/Example_Application_Compiling
>>>>> If you did a "make install" on the build tree, then this is all that
>>>>> would be required.
>>>>> export RTEMS_MAKEFILE_PATH=/home/admin/rtems/arm-rtems4.11/lpc1768
>>>>> make
>>>>> I probed for lpc1768 and lm3s6965 but with both configurations
>>>>> didn't work. Exist files which aren't generated.
>>>>> *admin at laptop ~/examples-v2 $* make
>>>>> /home/admin/rtems/make/custom/lm3s69xx.inc:5:
>>>>> /home/admin/rtems/make/custom/default.cfg: No such file or directory
>>>>> make: *** No rule to make target
>>>>> `/home/adm1/rtems/make/custom/default.cfg'. Stop.
>>>>> Note: I use --prefix:/home/admin/rtems as installation point.
>>>>> An alternative: "hardcode". In other words, paste the files missing
>>>>> into appropriate folders. After that, the errors disappeared. However, when
>>>>> I compile the hello world example, throws a new error.
>>>>> *admin at laptop ~/examples-v2/hello/hello_world_c $* make
>>>>> make: *** No rule to make target `/test.o', needed by `/hello.exe'.
>>>>> Stop.
>>>>> Any suggestion? Someone have or had problems with examples?
>>>>> <http://www.tallertechnologies.com>
>>>>> *Federico Lenarduzzi*
>>>>> Software Engineer
>>>>> Taller Technologies Argentina
>>>>> San Lorenzo 47, 3rd Floor, Office 5
>>>>> Cordoba, Argentina
>>>>> Phone: +54 351 4220701
>>>>> Mobile: +54 358 4289083
>>>>> Skype: federico.lenarduzzi1
>>>>> <https://www.facebook.com/tallertechnologies> <http://www.linkedin.com/company/taller-technologies>
>>>>> Joel Sherrill, Ph.D. Director of Research & Developmentjoel.sherrill at OARcorp.com On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>> Support Available (256) 722-9985
>>>> Software Engineer
>>>> Cordoba, Argentina
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
Software Engineer
Cordoba, Argentina
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140425/acf09ce7/attachment-0001.html>
