Error with examples-v2
Fri Apr 25 00:55:14 UTC 2014
On Thu, Apr 24, 2014 at 8:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Apr 24, 2014 at 7:28 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>>  If you don't do the make install step then neither will work.
> Good point, and those wiki instructions don't explicitly say "make
> install".
Or, yes they do, in the second block of code.
>  On Apr 24, 2014 6:05 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>  You may be interested to read the README.waf and try to use that to
>> build the examples instead of Make.
>> On Thu, Apr 24, 2014 at 5:20 PM, Federico Lenarduzzi <
>> federico.lenarduzzi at tallertechnologies.com> wrote:
>>> I already set RTEMS_MAKEFILE_PATH variable as you mentioned. Are you
>>> following the same tutorial? These steps are OK ?
>>> Thanks for help me.
>>> 2014-04-24 18:05 GMT-03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>   On 4/24/2014 3:55 PM, Federico Lenarduzzi wrote:
>>>>  Hi everybody, I'm trying compile the examples following this steps:
>>>>  http://www.rtems.org/wiki/index.php/Example_Application_Compiling
>>>>  If you did a "make install" on the build tree, then this is all that
>>>> would be required.
>>>> export RTEMS_MAKEFILE_PATH=/home/admin/rtems/arm-rtems4.11/lpc1768
>>>> make
>>>>  I probed for lpc1768 and lm3s6965 but with both configurations didn't
>>>> work. Exist files which aren't generated.
>>>>  *admin at laptop ~/examples-v2 $* make
>>>> /home/admin/rtems/make/custom/lm3s69xx.inc:5:
>>>> /home/admin/rtems/make/custom/default.cfg: No such file or directory
>>>> make: *** No rule to make target
>>>> `/home/adm1/rtems/make/custom/default.cfg'.  Stop.
>>>> Note: I use --prefix:/home/admin/rtems as installation point.
>>>> An alternative: "hardcode". In other words, paste the files missing
>>>> into appropriate folders. After that, the errors disappeared. However, when
>>>> I compile the hello world example, throws a new error.
>>>>   *admin at laptop ~/examples-v2/hello/hello_world_c $* make
>>>> make: *** No rule to make target `/test.o', needed by `/hello.exe'.
>>>>  Stop.
>>>>  Any suggestion? Someone have or had problems with examples?
>>>>  <http://www.tallertechnologies.com>
>>>>  *Federico Lenarduzzi*
>>>> Software Engineer
>>>>  Taller Technologies Argentina
>>>> San Lorenzo 47, 3rd Floor, Office 5
>>>> Cordoba, Argentina
>>>> Phone: +54 351 4220701
>>>> Mobile: +54 358 4289083
>>>> Skype: federico.lenarduzzi1
>>>>   <https://www.facebook.com/tallertechnologies> <http://www.linkedin.com/company/taller-technologies>
>>>> Joel Sherrill, Ph.D.             Director of Research & Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
>>> Software Engineer
>>> Cordoba, Argentina
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140424/008dd39f/attachment-0001.html>
