[PATCH] BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)
Wed Aug 13 22:40:49 UTC 2014
I have comments interspersed. Most are on formatting and should be
considered as just those I managed to spot.
the rtems-testing git repo has a directory of merge-helpers and
a check script which (I hope) helps you identify some of these
in more detail.
On 8/13/2014 2:48 PM, Premysl Houdek wrote:
> Included variants:
>   tms570ls3137_hdk_intram - place code and data into internal SRAM
>   tms570ls3137_hdk_sdram - place code into external SDRAM and data to SRAM
>   tms570ls3137_hdk - variant prepared for stand-alone RTEMS aplication
>                       stored and running directly from flash. Not working yet.
> Chip initialization code not included in BSP.
> External startup generated by TI's HalCoGen was used    for
> testing and debugging.
> More information about TMS570 BSP can be found at
>   http://www.rtems.org/wiki/index.php/Tms570
>  c/src/lib/libbsp/arm/tms570/Makefile.am            |  148 ++++++
>  c/src/lib/libbsp/arm/tms570/README                 |   64 +++
>  c/src/lib/libbsp/arm/tms570/bsp_specs              |   13 +
>  c/src/lib/libbsp/arm/tms570/clock/tms570-rti.c     |  205 ++++++++
>  c/src/lib/libbsp/arm/tms570/configure.ac           |   45 ++
>  .../lib/libbsp/arm/tms570/console/printk-support.c |   68 +++
>  c/src/lib/libbsp/arm/tms570/console/tms570-sci.c   |  546 ++++++++++++++++++++
>  c/src/lib/libbsp/arm/tms570/include/bsp.h          |  101 ++++
>  c/src/lib/libbsp/arm/tms570/include/irq.h          |  134 +++++
>  c/src/lib/libbsp/arm/tms570/include/tms570-pom.h   |  101 ++++
>  c/src/lib/libbsp/arm/tms570/include/tms570-rti.h   |   95 ++++
>  .../libbsp/arm/tms570/include/tms570-sci-driver.h  |   39 ++
>  c/src/lib/libbsp/arm/tms570/include/tms570-sci.h   |   75 +++
>  c/src/lib/libbsp/arm/tms570/include/tms570-vim.h   |   74 +++
>  c/src/lib/libbsp/arm/tms570/include/tms570.h       |   29 ++
>  c/src/lib/libbsp/arm/tms570/irq/irq.c              |  182 +++++++
>  .../make/custom/tms570ls3137_hdk-testsuite.tcfg    |   19 +
>  .../arm/tms570/make/custom/tms570ls3137_hdk.cfg    |   19 +
>  .../tms570/make/custom/tms570ls3137_hdk_intram.cfg |   20 +
>  .../tms570/make/custom/tms570ls3137_hdk_sdram.cfg  |   19 +
>  c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c       |  100 ++++
>  c/src/lib/libbsp/arm/tms570/startup/bspreset.c     |   37 ++
>  c/src/lib/libbsp/arm/tms570/startup/bspstart.c     |   46 ++
>  .../lib/libbsp/arm/tms570/startup/bspstarthooks.c  |   42 ++
>  .../arm/tms570/startup/linkcmds.tms570ls3137_hdk   |   27 +
>  .../startup/linkcmds.tms570ls3137_hdk_intram       |   28 +
>  .../tms570/startup/linkcmds.tms570ls3137_hdk_sdram |   27 +
You should include preinstall.am.
>  27 files changed, 2303 insertions(+)
>  create mode 100644 c/src/lib/libbsp/arm/tms570/Makefile.am
>  create mode 100644 c/src/lib/libbsp/arm/tms570/README
>  create mode 100644 c/src/lib/libbsp/arm/tms570/bsp_specs
>  create mode 100644 c/src/lib/libbsp/arm/tms570/clock/tms570-rti.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/configure.ac
>  create mode 100644 c/src/lib/libbsp/arm/tms570/console/printk-support.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/include/bsp.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/include/irq.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/include/tms570-pom.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/include/tms570-rti.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/include/tms570-sci.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/include/tms570-vim.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/include/tms570.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/irq/irq.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg
>  create mode 100644 c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
>  create mode 100644 c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
>  create mode 100644 c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
>  create mode 100644 c/src/lib/libbsp/arm/tms570/network/tms570-ethernet.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/network/tms570-ethernet.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/startup/bspreset.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/startup/bspstart.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/startup/bspstarthooks.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
>  create mode 100644 c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
>  create mode 100644 c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
> diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
> new file mode 100644
> index 0000000..6ded6af
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
> @@ -0,0 +1,148 @@
> +# @file makefile.am
> +# @brief Makefile of LibBSP for the TMS570 boards.
> +ACLOCAL_AMFLAGS = -I ../../../../aclocal
> +include $(top_srcdir)/../../../../automake/compile.am
> +include_bspdir = $(includedir)/bsp
> +dist_project_lib_DATA = bsp_specs
> +# ------  Headers
> +include_HEADERS = include/bsp.h
> +nodist_include_HEADERS = ../../shared/include/coverhd.h
> +nodist_include_HEADERS += include/bspopts.h
> +nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
> +include_bsp_HEADERS =
> +include_bsp_HEADERS += ../../shared/include/utility.h
> +include_bsp_HEADERS += ../../shared/include/irq-generic.h
> +include_bsp_HEADERS += ../../shared/include/irq-info.h
> +include_bsp_HEADERS += ../../shared/include/stackalloc.h
> +include_bsp_HEADERS += ../../shared/include/uart-output-char.h
> +include_bsp_HEADERS += ../../shared/tod.h
> +include_bsp_HEADERS += ../shared/include/start.h
> +include_bsp_HEADERS += include/tms570.h
> +include_bsp_HEADERS += include/tms570-sci.h
> +include_bsp_HEADERS += include/irq.h
> +include_bsp_HEADERS += include/tms570-rti.h
> +include_bsp_HEADERS += include/tms570-vim.h
> +include_bsp_HEADERS += include/tms570-pom.h
> +include_bsp_HEADERS += include/tms570-sci-driver.h
> +include_HEADERS += ../../shared/include/tm27.h
> +# ------  Data
> +noinst_LIBRARIES = libbspstart.a
> +libbspstart_a_SOURCES = ../shared/start/start.S
> +project_lib_DATA = start.$(OBJEXT)
> +project_lib_DATA += startup/linkcmds
> +EXTRA_DIST =
> +EXTRA_DIST += startup/linkcmds.tms570ls3137_hdk
> +EXTRA_DIST += startup/linkcmds.tms570ls3137_hdk_sdram
> +EXTRA_DIST += startup/linkcmds.tms570ls3137_hdk_intram
> +# ------  LibBSP
> +noinst_LIBRARIES += libbsp.a
> +libbsp_a_SOURCES =
> +libbsp_a_CPPFLAGS =
> +libbsp_a_LIBADD =
> +# Shared
> +libbsp_a_SOURCES += ../../shared/bootcard.c
> +libbsp_a_SOURCES += ../../shared/bspclean.c
> +libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
> +libbsp_a_SOURCES += ../../shared/bsplibc.c
> +libbsp_a_SOURCES += ../../shared/bsppost.c
> +libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
> +libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
> +libbsp_a_SOURCES += ../../shared/sbrk.c
> +libbsp_a_SOURCES += ../../shared/src/stackalloc.c
> +libbsp_a_SOURCES += ../../shared/src/uart-output-char.c
> +# Startup
> +libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
> +libbsp_a_SOURCES += startup/bspreset.c
> +libbsp_a_SOURCES += startup/bspstart.c
> +# POM
> +libbsp_a_SOURCES += pom/tms570-pom.c
> +# IRQ
> +libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
> +libbsp_a_SOURCES += ../../shared/src/irq-generic.c
> +libbsp_a_SOURCES += ../../shared/src/irq-info.c
> +libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
> +libbsp_a_SOURCES += ../../shared/src/irq-server.c
> +libbsp_a_SOURCES += ../../shared/src/irq-shell.c
> +libbsp_a_SOURCES += irq/irq.c
> +# Console
> +libbsp_a_SOURCES += ../../shared/console-termios.c
> +libbsp_a_SOURCES += console/printk-support.c
> +libbsp_a_SOURCES += console/tms570-sci.c
> +# Clock
> +libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
> +libbsp_a_SOURCES += clock/tms570-rti.c
> +# RTC
> +# GPIO
> +# Timer
> +# Benchmark Timer
> +# Misc
> +# Watchdog
> +# Start hooks
> +libbsp_a_SOURCES += startup/bspstarthooks.c
> +# Network
> +if HAS_NETWORKING
> +noinst_PROGRAMS = network.rel
> +network_rel_CPPFLAGS = $(AM_CPPFLAGS) -D__INSIDE_RTEMS_BSD_TCPIP_STACK__ -D__BSD_VISIBLE
> +network_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> +libbsp_a_LIBADD += network.rel
> +endif
> +# ------  Special Rules
> +DISTCLEANFILES = include/bspopts.h
> +include $(srcdir)/preinstall.am
> +include $(top_srcdir)/../../../../automake/local.am
> diff --git a/c/src/lib/libbsp/arm/tms570/README b/c/src/lib/libbsp/arm/tms570/README
> index 0000000..3150626
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/README
> @@ -0,0 +1,64 @@
> +Development Board: TMS570LS31x Hercules Development Kit from TI
> +http://www.ti.com/tool/tmds570ls31hdk
> +Drivers:
> +       o Console
> +       o Clock
> +  o Ethernet - work in progress
> +BSP variants:
> +  tms570ls3137_hdk_intram - place code and data into internal SRAM
> +  tms570ls3137_hdk_sdram - place code into external SDRAM and data to SRAM
> +  tms570ls3137_hdk - variant prepared for stand-alone RTEMS aplication
> +                      stored and running directly from flash. Not working yet.
> +Tool-chain
> +  GCC 4.9.0 + Newlib 2.1.0 + Binutils 2.24 configuration:
> +  CFLAGS="-O2 -pipe" LDFLAGS=-s \
> +  ../../../src/gcc-4.9/configure --target=arm-rtems4.11 --prefix=/usr \
> +               --enable-languages=c,c++ \
> +               --disable-libstdcxx-pch \
> +               --with-gnu-ld \
> +               --with-gnu-as \
> +               --enable-threads \
> +               --enable-target-optspace \
> +               --with-system-zlib \
> +               --verbose \
> +               --disable-nls --without-included-gettext \
> +               --disable-win32-registry \
> +               --with-newlib \
> +               --enable-plugin \
> +               --enable-newlib-io-c99-formats \
> +               --enable-version-specific-runtime-libs \
> +               --enable-newlib-iconv \
> +               --disable-lto \
> +Patches required for Cortex-R and big-endian ARM support are already
> +accepted by mainline.
> +Execution
> +  There is not used any generic bootloader. Initial complex CPU and peripherals
> +  initialization and self test are not implemented and included in RTEMS BSP
> +  right now. For testing and debuging purposes is used simple Ti's HalCoGen
> +  generated application to setup board and then download RTEMS image over
> +  OpenOCD to internal EEC SRAM or external SDRAM.
This is rough from an English viewpoint.  How about:
Currently, a bootloader is not used. For test and debug purposes, TI's
HalCoGen generated
application is used to set up the board and then the RTEMS application
image is loaded
using OpenOCD to internal EEC SRAM or external DRAM. The following
features are
not implemented in the BSP:
  + Initial complex CPU and peripheral initialization
  + Self-test
Can you be more specific about what that first bullet covers?
Is the generated setup code available? What's the license on it?
> +  Setup application code is available there:
> +          https://github.com/hornmich/tms570ls3137-hdk-sdram
> +Howto setup TMDS570LS31HDK?
> +       o Unpack board.
> +       o Verify that demo application runs.
> +  o Upload bootloader specified above
> +  o write BSP aplication either to sdram or intram and jump to RTEMS start code
application not aplication
Internal RAM?
> +Additional information about the board can be found at
> +  http://www.rtems.org/wiki/index.php/Tms570
> +Additional information about the CPU can be found at
> +  http://www.ti.com/product/tms570ls3137
> diff --git a/c/src/lib/libbsp/arm/tms570/bsp_specs b/c/src/lib/libbsp/arm/tms570/bsp_specs
> index 0000000..1afa2ba
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/bsp_specs
> @@ -0,0 +1,13 @@
> +%rename endfile old_endfile
> +%rename startfile old_startfile
> +%rename link old_link
> +*startfile:
> +%{!qrtems: %(old_startfile)} \
> +%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
> +*link:
> +%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N -EB }
> +*endfile:
> +%{!qrtems: *(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
> diff --git a/c/src/lib/libbsp/arm/tms570/clock/tms570-rti.c b/c/src/lib/libbsp/arm/tms570/clock/tms570-rti.c
> index 0000000..3f8278c
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/clock/tms570-rti.c
> @@ -0,0 +1,205 @@
> + * @file tms570-rti.c
> + * @ingroup tms570
> + * @brief clock functions definitions.
> + * Copyright (c) 2014 Premysl Houdek <kom541000 at gmail.com>
> + * Google Summer of Code 2014 at
> + * Czech Technical University in Prague
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> + * Based on LPC24xx and LPC1768 BSP
> + * by embedded brains GmbH and others
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#include <stdlib.h>
> +#include <rtems.h>
> +#include <bsp.h>
> +#include <bsp/irq.h>
> +#include <bsp/tms570-rti.h>
> +void Clock_exit( void );
> +rtems_isr Clock_isr( rtems_vector_number vector );
> +void Install_clock( rtems_isr_entry );
> + *  Clock_driver_ticks is a monotonically increasing counter of the
> + *  number of clock ticks since the driver was initialized.
> +volatile uint32_t         Clock_driver_ticks;
> + *  Clock_isrs is the number of clock ISRs until the next invocation of
> + *  the RTEMS clock tick routine.  The clock tick device driver
> + *  gets an interrupt once a millisecond and counts down until the
> + *  length of time between the user configured microseconds per tick
> + *  has passed.
> +uint32_t         Clock_isrs;              /* ISRs until next tick */
> + * These are set by clock driver during its init
> +rtems_device_major_number rtems_clock_major = ~0;
> +rtems_device_minor_number rtems_clock_minor;
Not needed any longer. Hopefully these aren't in any other BSPs. I
thought they
were all stripped out.
> + *  The previous ISR on this clock tick interrupt vector.
> +rtems_isr_entry  Old_ticker;
> + * @brief Clock isr handler
> + * bump the number of clock driver ticks since initialization
> + * determine if it is time to announce the passing of tick as configured
> + * to RTEMS through the rtems_clock_tick directive
> + * @param[in] vector interrupt vector
> + * @retval Void
> +  rtems_vector_number vector
> +   TMS570_RTI.RTIINTFLAG = 0x00000001;
> +   ++Clock_driver_ticks;
> +   /* TMS570_RTI.RTICOMP0 += 1000; */
> +   if ( Clock_isrs <= 1 ) {
> +     rtems_clock_tick();
> +     Clock_isrs = rtems_configuration_get_microseconds_per_tick() / 1000;
> +   else
> +     Clock_isrs -= 1;
> + * @brief Installs clock handler
> + * to RTEMS through the rtems_clock_tick directive *
> + * @retval Void
> +static void tms570_clock_handler_install(rtems_isr_entry clock_isr)
> +  rtems_status_code sc = RTEMS_SUCCESSFUL;
> +  sc = rtems_interrupt_handler_install(
> +    TMS570_IRQ_TIMER_0,
> +    "Clock",
> +    RTEMS_INTERRUPT_UNIQUE,
> +    (rtems_interrupt_handler) Clock_isr,
> +    NULL
> +  if (sc != RTEMS_SUCCESSFUL) {
> +    rtems_fatal_error_occurred(0xdeadbeef);
> + *  Install a clock tick handler and reprograms the chip.  This
> + *  is used to initially establish the clock tick.
> + * @retval Void
> +  rtems_isr_entry clock_isr
> +   *  Initialize the clock tick device driver variables
> +  Clock_driver_ticks = 0;
> +  tms570_clock_handler_install(clock_isr);
> +  /* Hardware specific initialize */
> +  TMS570_RTI.RTIGCTRL = 0;
> +  TMS570_RTI.RTICPUC0 = BSP_PLL_OUT_CLOCK /1000000 / 2; /* prescaler */
> +  TMS570_RTI.RTITBCTRL = 2;
> +  TMS570_RTI.RTICAPCTRL = 0;
> +  TMS570_RTI.RTICOMPCTRL = 0;
> +  /* set counter to zero */
> +  TMS570_RTI.RTIUC0 = 0;
> +  TMS570_RTI.RTIFRC0 = 0;
> +  /* clear interrupts*/
> +  TMS570_RTI.RTICLEARINTENA = 0x00070f0f;
> +  TMS570_RTI.RTIINTFLAG = 0x0007000f;
> +  /* set timer */
> +  TMS570_RTI.RTICOMP0 = TMS570_RTI.RTIFRC0 + 1000;
> +  TMS570_RTI.RTICOMP0CLR = TMS570_RTI.RTICOMP0 + 500;
> +  TMS570_RTI.RTIUDCP0 = 1000;
> +  /* enable interupt */
> +  TMS570_RTI.RTISETINTENA = 0x1;
> +  /* enable timer */
> +  TMS570_RTI.RTIGCTRL = 1;
> +   *  Schedule the clock cleanup routine to execute if the application exits.
> +  atexit( Clock_exit );
> + * @brief Clock exit
> + * Called by aplication exit
> + * Clean up before the application exits
> + * @retval Void
> +  /* turn off the timer interrupts */
> +  TMS570_RTI.RTICLEARINTENA = 0x20000;
> + *  @brief Initialize the clock driver
> + *  Device driver entry point for clock tick driver initialization.
> + *  Calls Install_clock
> + * @retval RTEMS_SUCCESSFUL
> +rtems_device_driver Clock_initialize(
> +  rtems_device_major_number major,
> +  rtems_device_minor_number minor,
> +  void *pargp
> +  Install_clock( Clock_isr );
> +   * make major/minor avail to others such as shared memory driver
> +  rtems_clock_major = major;
> +  rtems_clock_minor = minor;
> +  return RTEMS_SUCCESSFUL;
Please use clockdrv_shell.h and look at the clock driver for erc32 or
jmr3904 for
examples. This will eliminate a lot of the code you have here. It is
just duplicated
boilerplate.
That lets you define a few macros and the driver just falls out.
> diff --git a/c/src/lib/libbsp/arm/tms570/configure.ac b/c/src/lib/libbsp/arm/tms570/configure.ac
> index 0000000..952c7a4
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/configure.ac
> @@ -0,0 +1,45 @@
> +# @file configure.ac
> +# @brief Configure script of LibBSP for the TMS570 board.
> +AC_PREREQ([2.69])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-tms570],[_RTEMS_VERSION],
> +                               [http://www.rtems.org/bugzilla])
> +AC_CONFIG_SRCDIR([bsp_specs])
> +RTEMS_TOP(../../../../../..)
> +RTEMS_CANONICAL_TARGET_CPU
> +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> +RTEMS_BSP_CONFIGURE
> +RTEMS_PROG_CC_FOR_TARGET
> +RTEMS_CANONICALIZE_TOOLS
> +RTEMS_PROG_CCAS
> +RTEMS_CHECK_NETWORKING
> +AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "no")
> +RTEMS_BSPOPTS_SET([ARM_TMS570LS3137],[*],[0])
> +RTEMS_BSPOPTS_HELP([ARM_TMS570LS3137],[target used for identify TMS570LS3137 board])
> +RTEMS_BSPOPTS_SET([BSP_MINIMUM_TASK_STACK_SIZE],[*],[1024])
> +RTEMS_BSPOPTS_HELP([BSP_MINIMUM_TASK_STACK_SIZE],[Suggested minimum task stack
> +                       size in bytes])
> +RTEMS_BSPOPTS_SET([TMS570_OSCILLATOR_MAIN],[*],[12000000U])
> +RTEMS_BSPOPTS_HELP([TMS570_OSCILLATOR_MAIN],[main oscillator frequency in Hz])
> +RTEMS_BSPOPTS_SET([TMS570_OSCILLATOR_RTC],[*],[32768U])
> +RTEMS_BSPOPTS_HELP([TMS570_OSCILLATOR_RTC],[RTC oscillator frequency in Hz])
> +RTEMS_BSPOPTS_SET([TMS570_CCLK],[*],[96000000U])
> +RTEMS_BSPOPTS_HELP([TMS570_CCLK],[CPU clock in Hz])
> +RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
> +RTEMS_BSP_LINKCMDS
> +AC_CONFIG_FILES([Makefile])
> +AC_OUTPUT
> diff --git a/c/src/lib/libbsp/arm/tms570/console/printk-support.c b/c/src/lib/libbsp/arm/tms570/console/printk-support.c
> index 0000000..39baf04
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/console/printk-support.c
> @@ -0,0 +1,68 @@
> + * @file printk-support.c
> + * @ingroup tms570
> + * @brief definitions of serial line for debugging.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#include <rtems/bspIo.h>
> +#include <stdint.h>
> +#include <bsp/tms570-sci.h>
> +#include <bsp/tms570-sci-driver.h>
> +extern const tms570_sci_context driver_context_table[];
> + * @brief Puts chars into peripheral
> + * debug functions always use serial dev 0 peripheral
> + * @retval Void
> +static void tms570_putc(char ch)
> +  rtems_interrupt_level level;
> +  rtems_interrupt_disable(level);
> +  while ((driver_context_table[0].regs->SCIFLR & 0x100) == 0) {
> +    rtems_interrupt_flash(level);
> +  driver_context_table[0].regs->SCITD = ch;
> +  rtems_interrupt_enable(level);
> + * @brief debug console output
> + * @retval Void
> +static void console_output(char c)
> +  if (c == '\n') {
> +    char r = '\r';
> +    tms570_putc(r);
> +  tms570_putc(c);
Does spprintk have the right output? I question the newline/CR expansion.
> +BSP_output_char_function_type BSP_output_char = console_output;
> diff --git a/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c b/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
> index 0000000..4815263
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
> @@ -0,0 +1,546 @@
> + * @file tms570-sci.c
> + * @ingroup tms570
> + * @brief Serial communication interface (SCI) functions definitions.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#include <bspopts.h>
> +#include <libchip/sersupp.h>
> +#include <rtems/console.h>
> +#include <bsp.h>
> +#include <bsp/fatal.h>
> +#define TMS570_SCI_BUFFER_SIZE 10
> +#define TMS570_CONTEXT_TABLE_SIZE 2
> +#define TMS570_USE_INTERRUPTS
> + * @brief Table including all serial drivers
> + * Definitions of all serial drivers
> +const tms570_sci_context driver_context_table[] = {
> +    .device_name = "/dev/console",
> +    .regs = &TMS570_SCI,
> +    .irq = TMS570_IRQ_SCI_LEVEL_0,
> +    .device_name = "/dev/ttyS1",
> +    .regs = &TMS570_SCI2,
> +    .irq = TMS570_IRQ_SCI2_LEVEL_0,
> + * @brief Serial drivers init function
> + * Initialize all serial drivers specified in driver_context_table
> + * @param[in] major
> + * @param[in] minor
> + * @param[in] arg
> + * @retval RTEMS_SUCCESSFUL Initialization completed
> +rtems_device_driver console_initialize(
> +  void                      *arg
> +  rtems_status_code sc;
> +#ifdef TMS570_USE_INTERRUPTS
> +  const rtems_termios_device_handler *handler = &tms570_sci_handler_interrupt;
> +#else
> +  const rtems_termios_device_handler *handler = &tms570_sci_handler_polled;
> +#endif
> +   * Initialize the Termios infrastructure.  If Termios has already
> +   * been initialized by another device driver, then this call will
> +   * have no effect.
> +  rtems_termios_initialize();
> +  /* Initialize each device */
> +  for (
> +    minor = 0;
> +    minor < RTEMS_ARRAY_SIZE(driver_context_table);
> +    ++minor
> +    tms570_sci_context *ctx = (tms570_sci_context *) &driver_context_table[minor];
> +     * Install this device in the file system and Termios.  In order
> +     * to use the console (i.e. being able to do printf, scanf etc.
> +     * on stdin, stdout and stderr), one device must be registered as
> +     * "/dev/console" (CONSOLE_DEVICE_NAME).
> +    sc = rtems_termios_device_install(
> +      ctx->device_name,
> +      major,
> +      minor,
> +      handler,
> +      ctx
> +      bsp_fatal(BSP_FATAL_CONSOLE_NO_DEV);
> + * @brief Reads chars from HW
> + * Reads chars from HW peripheral specified in driver context.
> + * TMS570 does not have HW buffer for serial line so this function can
> + * return only 0 or 1 char
> + * @param[in] ctx context of the driver
> + * @param[out] buf read data buffer
> + * @param[in] N size of buffer
> + * @retval x Number of read chars from peripherals
> +static int tms570_sci_read_received_chars(
> +  tms570_sci_context * ctx,
> +  char * buf,
> +  int N)
> +  if(N<1)return 0;
> +  if(ctx->regs->SCIRD != 0){
> +     buf[0] = ctx->regs->SCIRD;
> +    return 1;
> +  return 0;
This doesn't match the expected style. The rules are here:
http://www.rtems.org/wiki/index.php/Coding_Conventions
But Sebastian Huber has also posted uncrustify setup which is
linked to from there and is
http://www.rtems.org/wiki/images/d/db/Rtems.uncrustify
As a minimum, the If should be "if (" and the return should be on a separate
line.
The code in the if..SCIRD is not lined up.
> + * @brief Enables RX interrupt
> + * Enables RX interrupt source of SCI peripheral
> + * specified in the driver context.
> + * @retval Void
> +static void tms570_sci_enable_interrupts(tms570_sci_context * ctx){
> +  ctx->regs->SCISETINT = (1<<9);
Brace should be on its own line.
> + * @brief Disables RX interrupt
> + * Disables RX interrupt source of SCI peripheral specified in the driver context.
> + * @retval Void
> +static void tms570_sci_disable_interrupts(tms570_sci_context * ctx){
> +  ctx->regs->SCICLEARINT = (1<<9);
> + * @brief Check whether driver has put char in HW
> + * Check whether driver has put char in HW.
> + * This information is read from the driver context not from a peripheral.
> + * TMS570 does not have write data buffer asociated with SCI
> + * so the return can be only 0 or 1.
> + * @retval x
> +static int tms570_sci_transmitted_chars(tms570_sci_context * ctx)
> +  int ret;
> +  ret = ctx->tx_chars_in_hw;
> +  if(ret == 1){
> +    ctx->tx_chars_in_hw = 0;
> +    return 1;
> +  return ret;
> + * @brief Set attributes of the HW peripheral
> + * Sets attributes of the HW peripheral (parity, baud rate, etc.)
> + * TODO: untested function
> + * @param[in] tty rtems_termios_tty
> + * @param[in] t termios driver
> + * @retval true peripheral setting is changed
> +static bool tms570_sci_set_attributes(
> +  rtems_termios_tty    *tty,
> +  const struct termios *t
> +  tms570_sci_context *ctx = rtems_termios_get_device_context(tty);
> +  rtems_interrupt_lock_context lock_context;
> +  rtems_termios_interrupt_lock_acquire(tty, &lock_context);
> +  switch (t->c_cflag & (PARENB|PARODD)) {
> +    case (PARENB|PARODD):
> +      /* Odd parity */
> +      ctx->regs->SCIGCR1 &= !(1<<3);
> +      ctx->regs->SCIGCR1 |= (1<<2);
> +      break;
> +    case PARENB:
> +      /* Even parity */
> +      ctx->regs->SCIGCR1 |= (1<<3);
> +      break;
> +    default:
> +    case 0:
> +    case PARODD:
> +      /* No Parity */
> +      ctx->regs->SCIGCR1 &= !(1<<2);
> +  /* Baud rate */
> +  ctx->regs->BRS |= 0xFF00001A;
> +  rtems_termios_interrupt_lock_release(tty, &lock_context);
> +  return true;
> + * @brief sci interrupt handler
> + * Handler checks which interrupt occured and provides nessesary maintenance
> + * dequeue characters in termios driver whether character is send succesfully
> + * enqueue characters in termios driver whether character is recieved
> + * @param[in] arg rtems_termios_tty
> + * @retval Void
> +static void tms570_sci_interrupt_handler(void * arg){
> +  rtems_termios_tty *tty = arg;
> +  char buf[TMS570_SCI_BUFFER_SIZE];
> +  size_t n;
> +   * Check if we have received something.
> +   if((ctx->regs->SCIFLR & (1<<9)) == (1<<9)){
> +      n = tms570_sci_read_received_chars(ctx, buf, TMS570_SCI_BUFFER_SIZE);
> +      if (n > 0) {
> +        /* Hand the data over to the Termios infrastructure */
> +        rtems_termios_enqueue_raw_characters(tty, buf, n);
> +   * Check if we have something transmitted.
> +  if((ctx->regs->SCIFLR & (1<<8)) == (1<<8)){
> +    n = tms570_sci_transmitted_chars(ctx);
> +    if (n > 0) {
> +       * Notify Termios that we have transmitted some characters.  It
> +       * will call now the interrupt write function if more characters
> +       * are ready for transmission.
> +      rtems_termios_dequeue_characters(tty, n);
> + * @brief sci write function called from interrupt
> + * Nonblocking write function. Writes characters to HW peripheral
> + * so only one character can be written.
> + * @param[in] buf buffer of characters pending to send
> + * @param[in] len size of the buffer
> + * @retval Void
> +static void tms570_sci_interrupt_write(
> +  const char *buf,
> +  size_t len
> +  if (len > 0) {
> +    /* start UART TX, this will result in an interrupt when done */
> +    ctx->regs->SCITD = *buf;
> +    /* character written - raise count*/
> +    ctx->tx_chars_in_hw = 1;
> +    /* Enable TX interrupt (interrupt is edge-triggered) */
> +    ctx->regs->SCISETINT = (1<<8);
> +  } else {
> +    /* No more to send, disable TX interrupts */
> +    ctx->regs->SCICLEARINT = (1<<8);
> +    /* Tell close that we sent everything */
> + * Blocking write function. Waits until HW peripheral is ready and then writes
> + * character to HW peripheral. Writes all characters in the buffer.
> + * @retval Void
> +static void tms570_sci_poll_write(
> +  const char        *buf,
> +  size_t             n
> +  size_t i;
> +  /* Write */
> +  for (i = 0; i < n; ++i) {
> +    while ((ctx->regs->SCIFLR & (1<<11)) == 0) {
> +    ctx->regs->SCITD = buf[i];
> + * @brief See if there is recieved charakter to read
> + * read the RX flag from peripheral specified in context
> + * @retval 0 No character to read
> + * @retval x Character ready to read
> +static int TMS570_sci_can_read_char(
> +  return ctx->regs->SCIFLR & (1<<9);
> + * @brief reads character from peripheral
> + * reads the recieved character from peripheral specified in context
> +static char TMS570_sci_read_char(
> +  return ctx->regs->SCIRD;
> + * @brief sci read function
> + * check if there is recieved character to be read and reads it.
> + * @param[in] tty rtems_termios_tty (context of the driver)
> + * @retval -1 No character to be read
> + * @retval x Read character
> +static int tms570_sci_poll_read(rtems_termios_tty *tty)
> +  /* Check if a character is available */
> +  if (TMS570_sci_can_read_char(ctx)) {
> +    return TMS570_sci_read_char(ctx);
> +  } else {
> +    return -1;
> + * @brief inicialization of the driver
> + * inicialization of the HW peripheral specified in contex of the driver.
> + * This function is called only once when opening the driver.
> + * @param[in] tty context of the driver
> + * @param[in] args
> + * @retval false Error occured during inicialization
> + * @retval true Driver is open and ready
> +static bool tms570_sci_poll_first_open(
> +  rtems_libio_open_close_args_t *args
> +  bool ok;
> +  /* TODO: test peripheral startup code below
> +    ctx->regs->SCIGCR1 |= (1<<25) | (1<<24) | (1<<4);
> +    ctx->regs->SCIFORMAT |= 0x7;
> +    ctx->regs->SCIPIO0 |= (1<<1) | (1<<2);
> +    ctx->regs->SCISETINTLVL = 0;
> +    ok = tms570_sci_set_attributes(tty, rtems_termios_get_termios(tty));
> +  ok = true;
> +  if (!ok) {
> +    return false;
> +  return true;
Someone mentioned constants for those register values. Otherwise these are
just magic values.
> + * @brief inicialization of the interrupt driven driver
> + * calls tms570_sci_poll_first_open function.
> + * install and enables interrupts.
> + * @param[in] args
> +static bool tms570_sci_interrupt_first_open(
> +  bool ret;
Add Blank line
> +  ret = tms570_sci_poll_first_open(tty,args);
> +  if (ret == false)
> +    return false;
> +  /* Register Interrupt handler */
> +  sc = rtems_interrupt_handler_install(ctx->irq,
> +                                       ctx->device_name,
> +                                       RTEMS_INTERRUPT_SHARED,
> +                                       tms570_sci_interrupt_handler,
> +                                       tty);
> +    return false;
Blank line
> +  tms570_sci_enable_interrupts(rtems_termios_get_device_context(tty));
> +  return true;
> + * @brief deinicializes sci peripheral
> + * @param[in] args
> +static void tms570_sci_poll_last_close(
> +  /*tms570_sci_context *ctx = rtems_termios_get_device_context(tty);*/
> +  /* TODO: Here shall be peripheral HW reset, someday */
> + * @brief deinicializes sci peripheral of interrupt driven driver
> + * calls tms570_sci_poll_last_close and disables interrupts
> + * @param[in] args
> +static void tms570_sci_interrupt_last_close(
> +  /* Turn off RX interrupts */
> +  tms570_sci_disable_interrupts(ctx);
> +  /* Flush device */
> +  while ((ctx->regs->SCIFLR & (1<<11)) > 0) {
> +    ;/* Wait until all data has been sent */
Is there anyway for this to lock up permanently? Can there be a timeout?
Not a critical issue for a first merge but mark it in a comment.
> +  /* uninstall ISR */
> +  rtems_interrupt_handler_remove(ctx->irq, tms570_sci_interrupt_handler, tty);
> +  tms570_sci_poll_last_close(tty,args);
> + * @brief Struct containing definitions of polled driver functions.
> + * Encapsulates polled driver functions.
> + * Use of this table is determited by not defining TMS570_USE_INTERRUPTS
> +const rtems_termios_device_handler tms570_sci_handler_polled = {
> +  .first_open = tms570_sci_poll_first_open,
> +  .last_close = tms570_sci_poll_last_close,
> +  .poll_read = tms570_sci_poll_read,
> +  .write = tms570_sci_poll_write,
> +  .set_attributes = tms570_sci_set_attributes,
> +  .stop_remote_tx = NULL,
> +  .start_remote_tx = NULL,
> +  .mode = TERMIOS_POLLED
> + * @brief Struct containing definitions of interrupt driven driver functions.
> + * Encapsulates interrupt driven driver functions.
> + * Use of this table is determited by defining TMS570_USE_INTERRUPTS
> +const rtems_termios_device_handler tms570_sci_handler_interrupt  = {
> +  .first_open = tms570_sci_interrupt_first_open,
> +  .last_close = tms570_sci_interrupt_last_close,
> +  .poll_read = NULL,
> +  .write = tms570_sci_interrupt_write,
> +  .mode = TERMIOS_IRQ_DRIVEN
> diff --git a/c/src/lib/libbsp/arm/tms570/include/bsp.h b/c/src/lib/libbsp/arm/tms570/include/bsp.h
> index 0000000..450ca68
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/include/bsp.h
> @@ -0,0 +1,101 @@
> + * @file bsp.h
> + * @ingroup tms570
> + * @brief Global BSP definitions.
Blank line.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#ifndef LIBBSP_ARM_TMS570_BSP_H
> +#define LIBBSP_ARM_TMS570_BSP_H
> +#define TMS570_PCLK ( TMS570_CCLK / TMS570_PCLKDIV )
> +#define TMS570_MPU_REGION_COUNT 8u
> +#define BSP_FEATURE_IRQ_EXTENSION
> +#ifndef ASM
> +#include <rtems.h>
> +#include <rtems/clockdrv.h>
> +#include <bsp/default-initial-extension.h>
> +#define BSP_OSCILATOR_CLOCK 8000000
> +#define BSP_PLL_OUT_CLOCK 160000000
> +/** Define operation count for Tests */
> +#define OPERATION_COUNT 4
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +struct rtems_bsdnet_ifconfig;
> + * @defgroup tms570 TMS570 Support
> + * @ingroup bsp_arm
> + * @brief TMS570 support package.
> + * @brief Optimized idle task.
> + * This idle task sets the power mode to idle.  This causes the processor
> + * clock to be stopped, while on-chip peripherals remain active.
> + * Any enabled interrupt from a peripheral or an external interrupt source
> + *  will cause the processor to resume execution.
> + * To enable the idle task use the following in the system configuration:
> + * @code
> + * #include <bsp.h>
> + * #define CONFIGURE_INIT
> + * #define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
> + * #include <confdefs.h>
> + * @endcode
> +void*bsp_idle_thread( uintptr_t ignored );
> +#define BSP_CONSOLE_UART_BASE 0x4000C000U
> + * @brief Restarts the bsp with "addr" address
> + * @param addr Address used to restart the bsp
> +void bsp_restart( const void *addr );
> +#ifdef __cplusplus
> +#endif /* ASM */
> +#endif /* LIBBSP_ARM_TMS570_BSP_H */
> diff --git a/c/src/lib/libbsp/arm/tms570/include/irq.h b/c/src/lib/libbsp/arm/tms570/include/irq.h
> index 0000000..718abad
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/include/irq.h
> @@ -0,0 +1,134 @@
> + * @file irq.h
> + * @ingroup tms570
> + * @brief TMS570 interrupt definitions.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#ifndef LIBBSP_ARM_TMS570_IRQ_H
> +#define LIBBSP_ARM_TMS570_IRQ_H
> +#ifndef ASM
> +#include <rtems.h>
> +#include <rtems/irq.h>
> +#include <rtems/irq-extension.h>
> +#endif
> +#define BSP_INTERRUPT_VECTOR_MIN 0U
> +#define TMS570_IRQ_ESM_HIGH 0
> +#define TMS570_IRQ_RESERVED 1
> +#define TMS570_IRQ_TIMER_0 2
> +#define TMS570_IRQ_TIMER_1 3
> +#define TMS570_IRQ_TIMER_2 4
> +#define TMS570_IRQ_TIMER_3 5
> +#define TMS570_IRQ_RTI_OVERFLOW_0 6
> +#define TMS570_IRQ_RTI_OVERFLOW_1 7
> +#define TMS570_IRQ_RTI_TIMEBASE 8
> +#define TMS570_IRQ_GIO_HIGH 9
> +#define TMS570_IRQ_HET_HIGH 10
> +#define TMS570_IRQ_HET_TU_HIGH 11
> +#define TMS570_IRQ_MIBSPI1_HIGH 12
> +#define TMS570_IRQ_SCI_LEVEL_0 13
> +#define TMS570_IRQ_ADC1_EVENT 14
> +#define TMS570_IRQ_ADC1_GROUP_1 15
> +#define TMS570_IRQ_CAN1_HIGH 16
> +#define TMS570_IRQ_RESERVED 17
> +#define TMS570_IRQ_FLEXRAY_HIGH 18
> +#define TMS570_IRQ_CRC_1 19
> +#define TMS570_IRQ_ESM_LOW 20
> +#define TMS570_IRQ_SSI 21
> +#define TMS570_IRQ_PMU 22
> +#define TMS570_IRQ_GIO_LOW 23
> +#define TMS570_IRQ_HET_LOW 24
> +#define TMS570_IRQ_HET_TU_LOW 25
> +#define TMS570_IRQ_MIBSPI1_LOW 26
> +#define TMS570_IRQ_SCI_LEVEL_1 27
> +#define TMS570_IRQ_ADC1_GROUP_2 28
> +#define TMS570_IRQ_CAN1_LOW 29
> +#define TMS570_IRQ_ADC1_MAG 31
> +#define TMS570_IRQ_FLEXRAY_LOW 32
> +#define TMS570_IRQ_DMA_FTCA 33
> +#define TMS570_IRQ_DMA_LFSA 34
> +#define TMS570_IRQ_CAN2_HIGH 35
> +#define TMS570_IRQ_DMM_HIGH 36
> +#define TMS570_IRQ_MIBSPI3_HIGH 37
> +#define TMS570_IRQ_MIBSPI3_LOW 38
> +#define TMS570_IRQ_DMA_HBCA 39
> +#define TMS570_IRQ_DMA_BTCA 40
> +#define TMS570_IRQ_DMA_BERA 41
> +#define TMS570_IRQ_CAN2_LOW 42
> +#define TMS570_IRQ_DMM_LOW 43
> +#define TMS570_IRQ_CAN1_IF3 44
> +#define TMS570_IRQ_CAN3_HIGH 45
> +#define TMS570_IRQ_CAN2_IF3 46
> +#define TMS570_IRQ_FPU 47
> +#define TMS570_IRQ_FLEXRAY_TU 48
> +#define TMS570_IRQ_SPI4_HIGH 49
> +#define TMS570_IRQ_ADC2_EVENT 50
> +#define TMS570_IRQ_ADC2_GROUP_1 51
> +#define TMS570_IRQ_FLEXRAY_T0C 52
> +#define TMS570_IRQ_MIBSPIP5_HIGH 53
> +#define TMS570_IRQ_SPI4_LOW 54
> +#define TMS570_IRQ_CAN3_LOW 55
> +#define TMS570_IRQ_MIBSPIP5_LOW 56
> +#define TMS570_IRQ_ADC2_GROUP_2 57
> +#define TMS570_IRQ_FLEXRAY_TU_ERROR 58
> +#define TMS570_IRQ_ADC2_MAG 59
> +#define TMS570_IRQ_CAN3_IF3 60
> +#define TMS570_IRQ_FSM_DONE 61
> +#define TMS570_IRQ_FLEXRAY_T1C 62
> +#define TMS570_IRQ_HET2_LEVEL_0 63
> +#define TMS570_IRQ_SCI2_LEVEL_0 64
> +#define TMS570_IRQ_HET_TU2_LEVEL_0 65
> +#define TMS570_IRQ_IC2_INTERRUPT 66
> +#define TMS570_IRQ_HET2_LEVEL_1 73
> +#define TMS570_IRQ_SCI2_LEVEL_1 74
> +#define TMS570_IRQ_HET_TU2_LEVEL_1 75
> +#define TMS570_IRQ_HWA_INT_REQ_H 80
> +#define TMS570_IRQ_HWA_INT_REQ_H 81
> +#define TMS570_IRQ_DCC_DONE_INTERRUPT 82
> +#define TMS570_IRQ_DCC2_DONE_INTERRUPT 83
> +#define TMS570_IRQ_HWAG1_INT_REQ_L 88
> +#define TMS570_IRQ_HWAG2_INT_REQ_L 89
> +#define BSP_INTERRUPT_VECTOR_MAX 94
> +#define TMS570_IRQ_PRIORITY_VALUE_MIN 0U
> +#define TMS570_IRQ_PRIORITY_VALUE_MAX 0U
> +#define TMS570_IRQ_PRIORITY_COUNT ( TMS570_IRQ_PRIORITY_VALUE_MAX + 1U )
> +#define TMS570_IRQ_PRIORITY_HIGHEST TMS570_IRQ_PRIORITY_VALUE_MIN
> +#define TMS570_IRQ_PRIORITY_LOWEST TMS570_IRQ_PRIORITY_VALUE_MAX
> +#ifndef ASM
> +void tms570_irq_set_priority(
> +  rtems_vector_number vector,
> +  unsigned            priority
> +unsigned tms570_irq_get_priority( rtems_vector_number vector );
Doxygen for these would be good.
> +#endif /* ASM */
> +#endif /* LIBBSP_ARM_TMS570_IRQ_H */
> diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-pom.h b/c/src/lib/libbsp/arm/tms570/include/tms570-pom.h
> index 0000000..810c5c8
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/include/tms570-pom.h
> @@ -0,0 +1,101 @@
> + * @file tms570-pom.h
> + * @ingroup tms570
> + * @brief Parameter Overlay Module (POM) header file
> + * Copyright (c) 2014 Pavel Pisa <pisa at cmp.felk.cvut.cz>
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#ifndef LIBBSP_ARM_TMS570_POM_H
> +#define LIBBSP_ARM_TMS570_POM_H
> +#ifdef __cplusplus
> +extern "C" {
> +#define TMS570_POM_REGIONS 32
> +#define TMS570_POM_GLBCTRL_ENABLE 0x000000a0a
> +#define TMS570_POM_REGSIZE_DISABLED 0
> +#define TMS570_POM_REGSIZE_64B      1
> +#define TMS570_POM_REGSIZE_128B     2
> +#define TMS570_POM_REGSIZE_256B     3
> +#define TMS570_POM_REGSIZE_5120B    4
> +#define TMS570_POM_REGSIZE_1KB      5
> +#define TMS570_POM_REGSIZE_2KB      6
> +#define TMS570_POM_REGSIZE_4KB      7
> +#define TMS570_POM_REGSIZE_8KB      8
> +#define TMS570_POM_REGSIZE_16KB     9
> +#define TMS570_POM_REGSIZE_32KB   0xa
> +#define TMS570_POM_REGSIZE_64KB   0xb
> +#define TMS570_POM_REGSIZE_128KB  0xc
> +#define TMS570_POM_REGSIZE_256KB  0xd
> +#define TMS570_POM_REGADDRMASK    ((1<<23)-1)
> +typedef struct tms570_pom_region_t {
> +  uint32_t PROGSTART;
> +  uint32_t OVLSTART;
> +  uint32_t REGSIZE;
> +  uint32_t res0;
> +} tms570_pom_region_t;
> +typedef struct tms570_pom_t {
> +  uint32_t GLBCTRL;     /* 000h Global Control Register */
> +  uint32_t REV;         /* 004h Revision ID */
> +  uint32_t CLKCTRL;     /* 008h Clock Gate Control Register */
> +  uint32_t FLG;         /* 00Ch Status Register */
> +  uint32_t res0[0x1f0/4];
> +  tms570_pom_region_t REG[TMS570_POM_REGIONS]; /* 200h Program Regions */
> +  uint32_t res1[0xb00/4];
> +  uint32_t ITCTRL;     /* F00h Integration Control Register */
> +  uint32_t res2[0x09c/4];
> +  uint32_t CLAIMSET;   /* FA0h Claim Set Register */
> +  uint32_t CLAIMCLR;   /* FA4h Claim Clear Register */
> +  uint32_t res3[0x008/4];
> +  uint32_t LOCKACCESS; /* FB0h Lock Access Register */
> +  uint32_t LOCKSTATUS; /* FB4h Lock Status Register */
> +  uint32_t AUTHSTATUS; /* FB8h Authentication Status Register */
> +  uint32_t res4[0x00c/4];
> +  uint32_t DEVID;      /* FC8h Device ID Register */
> +  uint32_t DEVTYPE;    /* FCCh Device Type Register */
> +  uint32_t PERIPHERALID4;      /* FD0h Peripheral ID 4 Register */
> +  uint32_t PERIPHERALID5;      /* FD4h Peripheral ID 5 Register */
> +  uint32_t PERIPHERALID6;      /* FD8h Peripheral ID 6 Register */
> +  uint32_t PERIPHERALID7;      /* FDCh Peripheral ID 7 Register */
> +  uint32_t PERIPHERALID0;      /* FE0h Peripheral ID 0 Register */
> +  uint32_t PERIPHERALID1;      /* FE4h Peripheral ID 1 Register */
> +  uint32_t PERIPHERALID2;      /* FE8h Peripheral ID 2 Register */
> +  uint32_t PERIPHERALID3;      /* FECh Peripheral ID 3 Register */
> +  uint32_t COMPONENTID0;       /* FF0h Component ID 0 Register */
> +  uint32_t COMPONENTID1;       /* FF4h Component ID 1 Register */
> +  uint32_t COMPONENTID2;       /* FF8h Component ID 2 Register */
> +  uint32_t COMPONENTID3;       /* FFCh Component ID 3 Register */
> +} tms570_pom_t;
It would look better if the comments lined up.
> +#define TMS570_POM (*(volatile tms570_pom_t*)0xffa04000)
> +int mem_dump(void *buf, unsigned long start, unsigned long len, int blen);
> +void tms570_pom_remap(void);
> +#ifdef __cplusplus
> +#endif /* LIBBSP_ARM_TMS570_POM_H */
> diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-rti.h b/c/src/lib/libbsp/arm/tms570/include/tms570-rti.h
> index 0000000..379d4e1
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/include/tms570-rti.h
> @@ -0,0 +1,95 @@
> + * @file tms570-rti.h
> + * @ingroup tms570
> + * @brief Real Time Interrupt module (RTI) header file.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#ifndef LIBBSP_ARM_TMS570_RTI_H
> +#define LIBBSP_ARM_TMS570_RTI_H
> +#ifndef ASM
> +#ifdef __cplusplus
> +extern "C" {
> + typedef struct {
> +    uint32_t RTIGCTRL;   //RTIGlobalControlRegister
> +    uint32_t RTITBCTRL;  //RTITimebaseControlRegister
> +    uint32_t RTICAPCTRL;   //RTICaptureControlRegister
> +    uint32_t RTICOMPCTRL;  //RTICompareControlRegister
> +    uint32_t RTIFRC0;  //RTIFreeRunningCounter0Register
> +    uint32_t RTIUC0;   //RTIUpCounter0Register
> +    uint32_t RTICPUC0;   //RTICompareUpCounter0Register
> +    uint32_t reserved1 [0x4/4];
> +    uint32_t RTICAFRC0;  //RTICaptureFreeRunningCounter0Register
> +    uint32_t RTICAUC0;   //RTICaptureUpCounter0Register
> +    uint32_t reserved2 [0x8/4];
> +    uint32_t RTIFRC1;  //RTIFreeRunningCounter1Register
> +    uint32_t RTIUC1;   //RTIUpCounter1Register
> +    uint32_t RTICPUC1;   //RTICompareUpCounter1Register
> +    uint32_t reserved3 [0x4/4];
> +    uint32_t RTICAFRC1;  //RTICaptureFreeRunningCounter1Register
> +    uint32_t RTICAUC1;   //RTICaptureUpCounter1Register
> +    uint32_t reserved4 [0x8/4];
> +    uint32_t RTICOMP0;   //RTICompare0Register
> +    uint32_t RTIUDCP0;   //RTIUpdateCompare0Register
> +    uint32_t RTICOMP1;   //RTICompare1Register
> +    uint32_t RTIUDCP1;   //RTIUpdateCompare1Register
> +    uint32_t RTICOMP2;   //RTICompare2Register
> +    uint32_t RTIUDCP2;   //RTIUpdateCompare2Register
> +    uint32_t RTICOMP3;   //RTICompare3Register
> +    uint32_t RTIUDCP3;   //RTIUpdateCompare3Register
> +    uint32_t RTITBLCOMP;   //RTITimebaseLowCompareRegister
> +    uint32_t RTITBHCOMP;   //RTITimebaseHighCompareRegister
> +    uint32_t reserved5 [0x8/4];
> +    uint32_t RTISETINTENA;   //RTISetInterruptEnableRegister
> +    uint32_t RTICLEARINTENA;   //RTIClearInterruptEnableRegister
> +    uint32_t RTIINTFLAG;   //RTIInterruptFlagRegister
> +    uint32_t reserved6 [0x4/4];
> +    uint32_t RTIDWDCTRL;   //DigitalWatchdogControlRegister
> +    uint32_t RTIDWDPRLD;   //DigitalWatchdogPreloadRegister
> +    uint32_t RTIWDSTATUS;  //WatchdogStatusRegister
> +    uint32_t RTIWDKEY;   //RTIWatchdogKeyRegister
> +    uint32_t RTIDWDCNTR;   //RTIDigitalWatchdogDownCounterRegister
> +    uint32_t RTIWWDRXNCTRL;  //DigitalWindowedWatchdogReactionControlRegister
> +    uint32_t RTIWWDSIZECTRL;   //DigitalWindowedWatchdogWindowSizeControlRegister
> +    uint32_t RTIINTCLRENABLE;  //RTICompareInterruptClearEnableRegister
> +    uint32_t RTICOMP0CLR;  //RTICompare0ClearRegister
> +    uint32_t RTICOMP1CLR;  //RTICompare1ClearRegister
> +    uint32_t RTICOMP2CLR;  //RTICompare2ClearRegister
> +    uint32_t RTICOMP3CLR;  //RTICompare3ClearRegister
> +}tms570_rti_t;
No C++ comments and line them up.
> +#define TMS570_RTI (*(volatile tms570_rti_t*)0xFFFFFC00)
> +#ifdef __cplusplus
> +#endif /* ASM */
> diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h b/c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h
> index 0000000..37ea8ce
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h
> @@ -0,0 +1,39 @@
> + * @file tms570-sci-driver.h
> + * @ingroup tms570
> + * @brief Declaration of serial's driver inner structure.
Blank line
> +#ifndef TMS570_SCI_DRIVER
> +#define TMS570_SCI_DRIVER
> +#include <rtems/termiostypes.h>
> +#ifdef __cplusplus
> +extern "C" {
> +/* Low-level driver specific data structure */
> +typedef struct {
> +  const char *device_name;
> +  volatile tms570_sci_t *regs;
> +  int tx_chars_in_hw;
> +  rtems_vector_number irq;
> +} tms570_sci_context;
> +extern const rtems_termios_device_handler tms570_sci_handler_polled;
> +extern const rtems_termios_device_handler tms570_sci_handler_interrupt;
Doxygen
> +#ifdef __cplusplus
> +#endif /* TMS570_SCI_DRIVER */
> diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-sci.h b/c/src/lib/libbsp/arm/tms570/include/tms570-sci.h
> index 0000000..da37c4d
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/include/tms570-sci.h
> @@ -0,0 +1,75 @@
> + * @file tms570-sci.h
> + * @ingroup tms570
> + * @brief Serial Communication Interface (SCI) header file.
Blank line
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#ifndef LIBBSP_ARM_TMS570_SCI_H
> +#define LIBBSP_ARM_TMS570_SCI_H
> +#include <libchip/serial.h>
> +#include <rtems.h>
> +#ifdef __cplusplus
> +extern "C" {
> +typedef struct {
> +  uint32_t SCIGCR0;    /*SCIGlobalControlRegister0*/
> +  uint32_t SCIGCR1;    /*SCIGlobalControlRegister1*/
> +  uint32_t SCISETINT;  /*SCISetInterruptRegister*/
> +  uint32_t SCICLEARINT;        /*SCIClearInterruptRegister*/
> +  uint32_t SCISETINTLVL;       /*SCISetInterruptLevelRegister*/
> +  uint32_t SCICLEARINTLVL;     /*SCIClearInterruptLevelRegister*/
> +  uint32_t SCIFLR;     /*SCIFlagsRegister*/
> +  uint32_t SCIINTVECT0;        /*SCIInterruptVectorOffset0*/
> +  uint32_t SCIINTVECT1;        /*SCIInterruptVectorOffset1*/
> +  uint32_t SCIFORMAT;  /*SCIFormatControlRegister*/
> +  uint32_t BRS;        /*BaudRateSelectionRegister*/
> +  uint32_t SCIED;      /*ReceiverEmulationDataBuffer*/
> +  uint32_t SCIRD;      /*ReceiverDataBuffer*/
> +  uint32_t SCITD;      /*TransmitDataBuffer*/
> +  uint32_t SCIPIO0;    /*SCIPinI/OControlRegister0*/
> +  uint32_t SCIPIO1;    /*SCIPinI/OControlRegister1*/
> +  uint32_t SCIPIO2;    /*SCIPinI/OControlRegister2*/
> +  uint32_t SCIPIO3;    /*SCIPinI/OControlRegister3*/
> +  uint32_t SCIPIO4;    /*SCIPinI/OControlRegister4*/
> +  uint32_t SCIPIO5;    /*SCIPinI/OControlRegister5*/
> +  uint32_t SCIPIO6;    /*SCIPinI/OControlRegister6*/
> +  uint32_t SCIPIO7;    /*SCIPinI/OControlRegister7*/
> +  uint32_t SCIPIO8;    /*SCIPinI/OControlRegister8*/
> +  uint32_t reserved2 [0x30/4];
> +  uint32_t IODFTCTRL;  /*Input/OutputErrorEnableRegister*/
> +}tms570_sci_t;
Line up comments
There are no spaces around the names but are in other structures.
I would recommend adding spaces.
> +#define TMS570_SCI (*(volatile tms570_sci_t*)0xFFF7E400U)
> +#define TMS570_SCI2 (*(volatile tms570_sci_t*)0xFFF7E500U)
> +#ifdef __cplusplus
> +#endif
> diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-vim.h b/c/src/lib/libbsp/arm/tms570/include/tms570-vim.h
> index 0000000..6d3bb54
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/include/tms570-vim.h
> @@ -0,0 +1,74 @@
> + * @file tms570-vim.h
> + * @ingroup tms570
> + * @brief Vectored Interrupt Module (VIM) header file.
Blank line
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#ifndef LIBBSP_ARM_TMS570_VIM_H
> +#define LIBBSP_ARM_TMS570_VIM_H
> +#ifndef ASM
> +#include <rtems.h>
> +#ifdef __cplusplus
> +extern "C" {
> +typedef struct{
> +    uint32_t PARFLG;   /* InterruptVectorTableParityFlagRegister */
> +    uint32_t PARCTL;   /* InterruptVectorTableParityControlRegister */
> +    uint32_t ADDERR;   /* AddressParityErrorRegister */
> +    uint32_t FBPARERR;         /* Fall-BackAddressParityErrorRegister */
> +    uint32_t IRQINDEX;         /* IRQIndexOffsetVectorRegister */
> +    uint32_t FIQINDEX;         /* FIQIndexOffsetVectorRegister */
> +    uint32_t FIRQPR[3];        /* FIQ/IRQProgramControlRegister0 */
> +    uint32_t INTREQ[3];        /* PendingInterruptReadLocationRegister0 */
> +    uint32_t reserved4 [0x4/4];
> +    uint32_t REQENASET[3];     /* InterruptEnableSetRegister0 */
> +    uint32_t reserved5 [0x4/4];
> +    uint32_t REQENACLR[3];     /* InterruptEnableClearRegister0 */
> +    uint32_t WAKEENASET[3];    /* Wake-upEnableSetRegister0 */
> +    uint32_t reserved7 [0x4/4];
> +    uint32_t WAKEENACLR[3];    /* Wake-upEnableClearRegister0 */
> +    uint32_t reserved8 [0x4/4];
> +    uint32_t IRQVECREG;        /* IRQInterruptVectorRegister */
> +    uint32_t FIQVECREG;        /* FIQInterruptVectorRegister */
> +    uint32_t CAPEVT;   /* CaptureEventRegister */
> +    uint32_t reserved9 [0x4/4];
> +    uint32_t CHANCTRL [0x5c/4]; /* VIM Interrupt Control Register (PARSER ERROR) */
> +}tms570_vim_t;
You know what I see. Line them up.
> +#define TMS570_VIM (*(volatile tms570_vim_t*)0xFFFFFDEC)
> +#endif
> +#ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570.h b/c/src/lib/libbsp/arm/tms570/include/tms570.h
> index 0000000..e7f43f2
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/include/tms570.h
> @@ -0,0 +1,29 @@
> + * @file tms570.h
> + * @ingroup tms570
> + * @brief Specific register definitions according to tms570 family boards.
Blank line.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#ifndef LIBBSP_ARM_TMS570_H
> +#define LIBBSP_ARM_TMS570_H
> +#endif /* LIBBSP_ARM_TMS570_H */
> diff --git a/c/src/lib/libbsp/arm/tms570/irq/irq.c b/c/src/lib/libbsp/arm/tms570/irq/irq.c
> index 0000000..5f72356
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/irq/irq.c
> @@ -0,0 +1,182 @@
> + * @file irq.c
> + * @ingroup tms570
> + * @brief TMS570 interrupt support functions definitions.
Yep.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#include <rtems/score/armv4.h>
> +#include <bsp.h>
> +#include <bsp/irq-generic.h>
> +#include <bsp/tms570-vim.h>
> + * @brief Check if isr vector is valid
> + * Check if isr vector is valid by using BSP_INTERRUPT_VECTOR_MAX and
> + * BSP_INTERRUPT_VECTOR_MIN defined in irq.h
> + * @param[in] vector interrupt vector to be checked.
> + * @retval TRUE vector is valid.
> + * @retval FALSE vector is invalid
> +static inline bool tms570_irq_is_valid(rtems_vector_number vector)
> +  return (vector <= BSP_INTERRUPT_VECTOR_MAX) &&
> +         (vector > BSP_INTERRUPT_VECTOR_MIN);
> +unsigned int priorityTable[BSP_INTERRUPT_VECTOR_MAX+1];
> + * @brief Set priority of the interrupt vector.
> + * This function is here because of compability. It should set
> + * priority of the interrupt vector.
> + * !!!WARNING!!!
> + * It does not set any priority at HW layer. It is nearly imposible to set
> + * priority of the interrupt on TMS570 in the nice way.
> + * @param[in] vector vector of isr
> + * @param[in] priority new priority assigned to the vector
> + * @return Void
> +void tms570_irq_set_priority(rtems_vector_number vector, unsigned priority){
> +  if (tms570_irq_is_valid(vector)) {
> +    priorityTable[vector] = priority;
> + * @brief Gets priority of the interrupt vector.
> + * This function is here because of compability. It returns priority
> + * of the isr vector last set by tms570_irq_set_priority function.
> + * !!!WARNING!!!
I think there is a Doxygen @warning directive.
> + * It does not return any priority of the HW layer.
> + * @retval 0 vector is invalid.
> + * @retval priority priority of the interrupt
> +unsigned tms570_irq_get_priority(rtems_vector_number vector){
Bring brace down.
> +   return priorityTable[vector];
> + return 0;
> + * @brief Interrupt dispatch
> + * Called by OS to determine which interrupt occured.
> + * Function passes control to interrupt handler.
> + * @return Void
> +void bsp_interrupt_dispatch(void)
> +  rtems_vector_number vector = TMS570_VIM.IRQINDEX-1;
> +  bsp_interrupt_handler_dispatch(vector);
> + * @brief enables interrupt vector in the HW
> + * Enables HW interrupt for specified vector
> + * @param[in] vector vector of the isr which needs to be enabled.
> + * @retval RTEMS_INVALID_ID vector is invalid.
> + * @retval RTEMS_SUCCESSFUL interrupt source enabled.
> +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
> +  if(!tms570_irq_is_valid(vector))
> +    return RTEMS_INVALID_ID;
> +  TMS570_VIM.REQENASET[vector >> 5] = 1 << (vector & 0x1f);
> + * @brief disables interrupt vector in the HW
> + * Disables HW interrupt for specified vector
> + * @param[in] vector vector of the isr which needs to be disabled.
> + * @retval RTEMS_SUCCESSFUL interrupt source disabled.
> +rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
if(
> +  TMS570_VIM.REQENACLR[vector >> 5] = 1 << (vector & 0x1f);
> + * @brief Init function of interrupt module
> + * Resets vectored interrupt interface to default state.
> + * Disables all interrupts.
> + * Set all sources as IRQ (not FIR).
> + * @retval RTEMS_SUCCESSFUL All is set
> +rtems_status_code bsp_interrupt_facility_initialize(void)
> +  void (**vim_vec)(void) = (void (**)(void)) 0xFFF82000;
> +  unsigned int value = 0x00010203;
> +  unsigned int i = 0;
> +  uint32_t sctlr;
> +  /* Disable interrupts */
> +  for(i = 0; i < 3; i++)
> +    TMS570_VIM.REQENACLR[i] = 0xffffffff;
> +  /* Map default events on interrupt vectors */
> +  for(i=0;i<24;i+=1,value += 0x04040404)
> +    TMS570_VIM.CHANCTRL[i] = value;
> +  /* Set all vectors as IRQ (not FIR) */
> +  TMS570_VIM.FIRQPR[0] = 3;
> +  TMS570_VIM.FIRQPR[1] = 0;
> +  TMS570_VIM.FIRQPR[2] = 0;
> +  /*_CPU_ISR_install_vector(ARM_EXCEPTION_IRQ, _ARMV4_Exception_interrupt, NULL);*/
> +  for(i = 0; i <= 94; i++)
> +    vim_vec[i] = _ARMV4_Exception_interrupt;
> +  /* Clear bit VE in SCTLR register to not use VIM IRQ exception bypass*/
> +  asm volatile ("mrc p15, 0, %0, c1, c0, 0\n": "=r" (sctlr));
> +  sctlr &= ~(1 << 24);
> +  asm volatile ("mcr p15, 0, %0, c1, c0, 0\n": : "r" (sctlr));
> diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg
> index 0000000..6f722bc
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg
> @@ -0,0 +1,19 @@
> +# tms570ls3137 mbed RTEMS Test Database.
> +# Format is one line per test that is _NOT_ built.
> +flashdisk01
> +utf8proc01
> +spstkalloc02
> +fsdosfsname01
> +jffs2_fserror
> +jffs2_fslink
> +jffs2_fspatheval
> +jffs2_fspermission
> +jffs2_fsrdwr
> +jffs2_fssymlink
> +jffs2_fstime
> +pppd
> +mghttpd01
> diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
> index 0000000..ed43811
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
> @@ -0,0 +1,19 @@
> +# Config file for mbed TMS570LS3137 board.
> +include $(RTEMS_ROOT)/make/custom/default.cfg
> +RTEMS_CPU = arm
> +CPU_CFLAGS = -march=armv7-r -mthumb -mbig-endian
> +CFLAGS_OPTIMIZE_V = -O2 -ggdb3 -DNDEBUG
> +BINEXT?=.bin
> +# This defines the operations performed on the linked executable.
> +# is currently required.
> +define bsp-post-link
> +    $(OBJCOPY) -O binary --strip-all \
> +        $(basename $@)$(EXEEXT) $(basename $@)$(BINEXT)
> +    $(SIZE) $(basename $@)$(EXEEXT)
> +endef
> diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
> index 0000000..d4a7b44
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
> @@ -0,0 +1,20 @@
> +RTEMS_CPU = arm
> +#CFLAGS_OPTIMIZE_V = -O2 -ggdb3 -DNDEBUG
> +CFLAGS_OPTIMIZE_V = -O0 -ggdb3
> +BINEXT?=.bin
Blank line
> +endef
> diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
> @@ -0,0 +1,19 @@
> +RTEMS_CPU = arm
> +BINEXT?=.bin
Blank
> +endef
> diff --git a/c/src/lib/libbsp/arm/tms570/network/tms570-ethernet.c b/c/src/lib/libbsp/arm/tms570/network/tms570-ethernet.c
> index 0000000..e69de29
> diff --git a/c/src/lib/libbsp/arm/tms570/network/tms570-ethernet.h b/c/src/lib/libbsp/arm/tms570/network/tms570-ethernet.h
> diff --git a/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c b/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
> index 0000000..0b7ff79
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
> @@ -0,0 +1,100 @@
> + * @file tms570-pom.c
> + * @ingroup tms570
> + * @brief TMS570 Parameter Overlay Module functions definitions.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#include <bsp/tms570-pom.h>
> +#include <bsp/linker-symbols.h>
> +#include <bsp.h>
> + * @brief Prints part of the memory
> + * debug function
> + * @retval 0
> +  unsigned long addr=start;
> +  volatile unsigned char *p=buf;
> +  int i;
> +  while(len){
Spacing "while () {"
> +    printk("%08lX:",addr);
> +    i=len>16?16:len;
> +    addr+=i;
> +    len-=i;
> +    while(i>0){
> +      i -= blen;
> +      switch(blen){
> +        case 4:
> +          printk("%08lX%c",(unsigned long)*(volatile uint32_t*)p,i>0?' ':'\n');
> +          break;
> +        case 2:
> +          printk("%04X%c",*(volatile uint16_t*)p,i>0?' ':'\n');
> +          break;
> +        default:
> +          printk("%02X%c",*(volatile uint8_t*)(p),i>0?' ':'\n');
> +          break;
> +      p += blen;
> +  return 0;
> + * @brief remaps vector table
> + * transfer the rtems start vector table to address 0x0
> + * @retval Void
> +    int i;
> +    uint32_t vec_overlay_start = 0x08000000;
Indentation of this method is off.
> +    memcpy((void*)vec_overlay_start, bsp_start_vector_table_begin, 64);
> +    TMS570_POM.GLBCTRL = 0;
> +    for (i = 0; i < TMS570_POM_REGIONS; i++)
> +        TMS570_POM.REG[i].REGSIZE = TMS570_POM_REGSIZE_DISABLED;
> +    TMS570_POM.REG[0].PROGSTART = 0x0 & TMS570_POM_REGADDRMASK;
> +    TMS570_POM.REG[0].OVLSTART = vec_overlay_start & TMS570_POM_REGADDRMASK;
> +    TMS570_POM.REG[0].REGSIZE = TMS570_POM_REGSIZE_64B;
> +    TMS570_POM.GLBCTRL = TMS570_POM_GLBCTRL_ENABLE |
> +                         (vec_overlay_start & ~TMS570_POM_REGADDRMASK);
> +  #ifdef POM_REMAP_TEST
> +    p32[1] = 0xe12fff1e;
> +    mem_dump((uint8_t *)0x00000000, 0x00000000, 256, 1);
> +    printk("Probing call to address 0x00000004\n");
> +    ((void(*)(void))4)();
> +    printk("POM call really returned\n");
> +  #endif /*POM_REMAP_TEST*/
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/bspreset.c b/c/src/lib/libbsp/arm/tms570/startup/bspreset.c
> index 0000000..6a043f5
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/startup/bspreset.c
> @@ -0,0 +1,37 @@
> + * @file bspreset.c
> + * @ingroup tms570
> + * @brief Reset code.
Blank line.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#include <rtems.h>
> +#include <bsp/bootcard.h>
> +#include <bsp/tms570.h>
> +#include <bsp/start.h>
> +BSP_START_TEXT_SECTION __attribute__( ( flatten ) ) void bsp_reset( void )
> +  while ( true ) {
> +    /* Do nothing */
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/bspstart.c b/c/src/lib/libbsp/arm/tms570/startup/bspstart.c
> index 0000000..9a7e434
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/startup/bspstart.c
> @@ -0,0 +1,46 @@
> + * @file bspstart.c
> + * @ingroup tms570
> + * @brief Startup code.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#include <bsp.h>
> +void bsp_pretasking_hook( void )
There should be a stub bsp_pretasking_hook() in libbsp/shared.
Delete this and use that one.
> +void bsp_start( void )
> +    /* set the cpu mode to supervisor and big endian */
> +    arm_cpu_mode = 0x213;
> +    tms570_pom_remap();
> +    /* Interrupts */
> +    bsp_interrupt_initialize();
Indentation.
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/tms570/startup/bspstarthooks.c
> index 0000000..45a6903
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/startup/bspstarthooks.c
> @@ -0,0 +1,42 @@
> + * @file bspstarthooks.c
> + * @ingroup tms570
> + * @brief First configurations and initializations to the correct
> + *              functionality of the board.
> + * Zikova 1903/4
> + * 166 36 Praha 6
> + * Czech Republic
> +#include <bsp.h>
Extra blank
> +BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
Extra blank
> +BSP_START_TEXT_SECTION void bsp_start_hook_1( void )
> +  bsp_start_copy_sections();
> +  bsp_start_clear_bss();
> +  /* At this point we can use objects outside the .start section  */
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
> index 0000000..e02dcd6
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
> @@ -0,0 +1,27 @@
> +MEMORY {
> +       ROM_INT (RX)  : ORIGIN = 0x00000000, LENGTH = 3M
> +       RAM_INT (AIW) : ORIGIN = 0x08000000, LENGTH = 256k
> +       RAM_EXT (AIWX) : ORIGIN = 0x80000000, LENGTH = 8M
> +REGION_ALIAS ("REGION_START", ROM_INT);
> +REGION_ALIAS ("REGION_VECTOR", RAM_INT);
> +REGION_ALIAS ("REGION_TEXT", ROM_INT);
> +REGION_ALIAS ("REGION_TEXT_LOAD", ROM_INT);
> +REGION_ALIAS ("REGION_RODATA", ROM_INT);
> +REGION_ALIAS ("REGION_RODATA_LOAD", ROM_INT);
> +REGION_ALIAS ("REGION_DATA", RAM_INT);
> +REGION_ALIAS ("REGION_DATA_LOAD", ROM_INT);
> +REGION_ALIAS ("REGION_FAST_TEXT", RAM_INT);
> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", ROM_INT);
> +REGION_ALIAS ("REGION_FAST_DATA", RAM_INT);
> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", ROM_INT);
> +REGION_ALIAS ("REGION_BSS", RAM_INT);
> +REGION_ALIAS ("REGION_WORK", RAM_INT);
> +REGION_ALIAS ("REGION_STACK", RAM_INT);
> +bsp_stack_main_size = DEFINED (bsp_stack_main_size) ? bsp_stack_main_size : 1024;
> +bsp_stack_main_size = ALIGN (bsp_stack_main_size, bsp_stack_align);
> +INCLUDE linkcmds.armv4
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
> index 0000000..19bb7b2
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
> @@ -0,0 +1,28 @@
> +MEMORY {
> +       RAM_INT_VEC :    ORIGIN = 0x08000000, LENGTH = 1k
> +       RAM_INT (AIWX) : ORIGIN = 0x08000400, LENGTH = 256k - 1k
> +       RAM_EXT (AIW) :  ORIGIN = 0x80000000, LENGTH = 8M
> +REGION_ALIAS ("REGION_START", RAM_INT);
> +REGION_ALIAS ("REGION_TEXT", RAM_INT);
> +REGION_ALIAS ("REGION_TEXT_LOAD", RAM_INT);
> +REGION_ALIAS ("REGION_RODATA", RAM_INT);
> +REGION_ALIAS ("REGION_RODATA_LOAD", RAM_INT);
> +REGION_ALIAS ("REGION_DATA_LOAD", RAM_INT);
> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM_INT);
> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM_INT);
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
> index 0000000..110179f
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
> @@ -0,0 +1,27 @@
> +MEMORY {
> +REGION_ALIAS ("REGION_START", RAM_EXT);
> +REGION_ALIAS ("REGION_VECTOR", RAM_EXT);
> +REGION_ALIAS ("REGION_TEXT", RAM_EXT);
> +REGION_ALIAS ("REGION_TEXT_LOAD", RAM_EXT);
> +REGION_ALIAS ("REGION_RODATA", RAM_EXT);
> +REGION_ALIAS ("REGION_RODATA_LOAD", RAM_EXT);
> +REGION_ALIAS ("REGION_DATA", RAM_EXT);
> +REGION_ALIAS ("REGION_DATA_LOAD", RAM_EXT);
> +REGION_ALIAS ("REGION_FAST_TEXT", RAM_EXT);
> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM_EXT);
> +REGION_ALIAS ("REGION_FAST_DATA", RAM_EXT);
> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM_EXT);
> +REGION_ALIAS ("REGION_BSS", RAM_EXT);
> +REGION_ALIAS ("REGION_WORK", RAM_EXT);
> +REGION_ALIAS ("REGION_STACK", RAM_EXT);
> 1.7.10.4
> devel mailing list
> devel at rtems.org
