[PATCH] BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Aug 14 09:04:44 UTC 2014
Hello Joel,
On Thursday 14 of August 2014 00:40:49 Joel Sherrill wrote:
> On 8/13/2014 2:48 PM, Premysl Houdek wrote:
> > --- /dev/null
> > +++ b/c/src/lib/libbsp/arm/tms570/README
> > @@ -0,0 +1,64 @@
> > +Development Board: TMS570LS31x Hercules Development Kit from TI
> > +Execution
> > +  There is not used any generic bootloader. Initial complex CPU and
> > peripherals +  initialization and self test are not implemented and
> > included in RTEMS BSP +  right now. For testing and debuging purposes is
> > used simple Ti's HalCoGen +  generated application to setup board and
> > then download RTEMS image over +  OpenOCD to internal EEC SRAM or
> > external SDRAM.
> This is rough from an English viewpoint.  How about:
> Currently, a bootloader is not used. For test and debug purposes, TI's
> HalCoGen generated
> application is used to set up the board and then the RTEMS application
> image is loaded
> using OpenOCD to internal EEC SRAM or external DRAM. The following
> features are
> not implemented in the BSP:
>   + Initial complex CPU and peripheral initialization
>   + Self-test
> Can you be more specific about what that first bullet covers?
> Is the generated setup code available? What's the license on it?
The generated setup is available, see link below
> > +  Setup application code is available there:
> > +          https://github.com/hornmich/tms570ls3137-hdk-sdram
> > +Howto setup TMDS570LS31HDK?
> > +       o Unpack board.
> > +       o Verify that demo application runs.
> > +  o Upload bootloader specified above
> > +  o write BSP aplication either to sdram or intram and jump to RTEMS
> > start code
> application not aplication
> Internal RAM?
Yes, thanks for checking, English is neither Premek nor my
specialty and Pemek.
There would be happy even to provide build binary to everybody who cares.
But generally the hardware needs more work to be done.
Unfortuantelly, flashing to the MCU is quite complicated due
un-documented algorithm. We have used Ti tools to Flash setup
code. But we know other working solution, it is possible to
setup MCU over JTAG and the download flasher code into internal
RAM. The library with flash algorithm is available from Ti
in binary form for Cortex-R4F. So our plan is to have small
loader to allow flash application over CAN or ETHERNET.
But it is still longer term goal.
Best wishes,
                 Pavel
