[PATCH] BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)
Thu Aug 14 13:44:54 UTC 2014
Thanks.
I am just worried about reproducibility or the BSP and test results
combined with licensing and redistribution of the TI support
code. As long as everyone is comfortable with that, I am as well.
On 8/14/2014 4:04 AM, Pavel Pisa wrote:
> Hello Joel,
> On Thursday 14 of August 2014 00:40:49 Joel Sherrill wrote:
>> On 8/13/2014 2:48 PM, Premysl Houdek wrote:
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/arm/tms570/README
>>> @@ -0,0 +1,64 @@
>>> +Development Board: TMS570LS31x Hercules Development Kit from TI
>>> +Execution
>>> +  There is not used any generic bootloader. Initial complex CPU and
>>> peripherals +  initialization and self test are not implemented and
>>> included in RTEMS BSP +  right now. For testing and debuging purposes is
>>> used simple Ti's HalCoGen +  generated application to setup board and
>>> then download RTEMS image over +  OpenOCD to internal EEC SRAM or
>>> external SDRAM.
>> This is rough from an English viewpoint.  How about:
>> Currently, a bootloader is not used. For test and debug purposes, TI's
>> HalCoGen generated
>> application is used to set up the board and then the RTEMS application
>> image is loaded
>> using OpenOCD to internal EEC SRAM or external DRAM. The following
>> features are
>> not implemented in the BSP:
>>   + Initial complex CPU and peripheral initialization
>>   + Self-test
>> Can you be more specific about what that first bullet covers?
>> Is the generated setup code available? What's the license on it?
> The generated setup is available, see link below
>>> +  Setup application code is available there:
>>> +          https://github.com/hornmich/tms570ls3137-hdk-sdram
>>> +Howto setup TMDS570LS31HDK?
>>> +       o Unpack board.
>>> +       o Verify that demo application runs.
>>> +  o Upload bootloader specified above
>>> +  o write BSP aplication either to sdram or intram and jump to RTEMS
>>> start code
>> application not aplication
>> Internal RAM?
> Yes, thanks for checking, English is neither Premek nor my
> specialty and Pemek.
> There would be happy even to provide build binary to everybody who cares.
> But generally the hardware needs more work to be done.
> Unfortuantelly, flashing to the MCU is quite complicated due
> un-documented algorithm. We have used Ti tools to Flash setup
> code. But we know other working solution, it is possible to
> setup MCU over JTAG and the download flasher code into internal
> RAM. The library with flash algorithm is available from Ti
> in binary form for Cortex-R4F. So our plan is to have small
> loader to allow flash application over CAN or ETHERNET.
> But it is still longer term goal.
> Best wishes,
>                  Pavel
