[GSoC2014] arinc653 on rtems (using pok) patches
Mon Aug 18 13:13:28 UTC 2014
If you're using git for your development, you can use 'git
format-patch' to convert a set of commits into a set of patches. Some
properly formatted git patches can make it easier to review and merge
your code. Some other notes follow.
virtualpok_arinc653.patch:
* it seems the only part of this patch specific to the arinc653 code
is the Makefile.am and preinstall.am changes?
* The virtualizationlayercpu.h is missing. Is this supposed to come
from another patch already?
* You comment out a few lines in bspstart.c, are these things that were broken?
* Is the linkcmds change required for running pok-rtems?
hello_init_c.patch:
* This would be much improved if you provided a new example instead of
replacing the existing one, like 'arinc653_test.c' or similar.
libpok_rtems_arinc653.patch:
It seems incorrect to remove extern from all of these arrays. Usually
for global variables in C code, there should be one declaration of the
variable with the 'extern' attribute in a header file that gets
included in every c source file that needs that variable, and then one
definition of the variable without 'extern' in just one of the .c
files. Please explain your changes.
Also, the patches that are for pok should be sent to the pok mailing
list(s) for review.
-Gedare
On Sat, Aug 16, 2014 at 4:34 PM, Janek van Oirschot
<janekvoirschot at gmail.com> wrote:
> A bit unconventional for a new patch but since my patches also include POK
> changes this seemed like the best way to upload it. Patches and readme with
> explanation on how to duplicate my environment and work are in the tarball.
> I do assume that the virtualpok BSP and paravirt_cpu patches are already
> installed so I didn't include that with my patches. Working on the wikipage
> about arinc653 on rtems right now so that'll be up soon.
> Thanks,
> Janek van Oirschot
> devel mailing list
> devel at rtems.org
