Bug at spcache01/init.c ?
Hesham Moustafa heshamelmatary at gmail.com
Wed Aug 20 18:23:01 UTC 2014
Hi,
When I was building the new or1ksim/OpenRISC BSP with --enable-tests
option. I got some errors from the spcache01/init.c compilation. The
error is related to assembler
"spcache01/init.c:117: Error: unrecognized instruction `nop'"
Which is generated from the following line:
"#define I() __asm__ volatile ("nop")"
Should this test be target/feature dependent?
Thanks,
Hesham
