[PATCH] Properly flush cache when writing to MPC55XX flash.
Peter Dufault dufault at hda.com
Wed Aug 20 20:48:06 UTC 2014
Also cleanup:
* Remove un-needed interrupt disables.
* Address errata "e989: FLASH: Disable Prefetch during programming and erase"
* Use RTEMS_ARRAY_SIZE() macro instead of own macro.
.../libcpu/powerpc/mpc55xx/misc/flash_support.c    |   85 +++++++++-----------
1 files changed, 39 insertions(+), 46 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c b/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c
index 17c4e3f..b286b51 100644
--- a/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c
+++ b/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c
@@ -135,8 +135,6 @@ range_set(
    *p_bits = bits;
-#define N(ARG) (sizeof(ARG)/sizeof(ARG[0]))
/** Return the size of the on-chip flash
 *  verifying that this is a device that we know about.
 * @return 0 for OK, non-zero for error:
@@ -207,7 +205,6 @@ unlock_once(int lsel, int msel, int hbsel, int *p_locked)
    union LMLR_tag lmlr;
    union SLMLR_tag slmlr;
    union HLR_tag hlr;
-    rtems_interrupt_level level;
    /* If we're already locked return.
@@ -217,7 +214,6 @@ unlock_once(int lsel, int msel, int hbsel, int *p_locked)
    /* Do we have to lock something in the low or mid block?
-    rtems_interrupt_disable(level);
    lmlr = FLASH.LMLR;
    if ((lsel || msel) && (lmlr.B.LME == 0)) {
        union LMLR_tag lmlr_unlock;
@@ -228,7 +224,6 @@ unlock_once(int lsel, int msel, int hbsel, int *p_locked)
        if (lmlr.B.LLOCK != lmlr_unlock.B.LLOCK ||
        lmlr.B.MLOCK != lmlr_unlock.B.MLOCK) {
            if (p_locked == 0) {
-                rtems_interrupt_enable(level);
                return MPC55XX_FLASH_LOCK_ERR;
            } else {
                *p_locked = 1;
@@ -237,9 +232,7 @@ unlock_once(int lsel, int msel, int hbsel, int *p_locked)
            FLASH.LMLR = lmlr_unlock;
    slmlr = FLASH.SLMLR;
    if ((lsel || msel) && (slmlr.B.SLE == 0)) {
        union SLMLR_tag slmlr_unlock;
@@ -250,7 +243,6 @@ unlock_once(int lsel, int msel, int hbsel, int *p_locked)
        if (slmlr.B.SLLOCK != slmlr_unlock.B.SLLOCK ||
        slmlr.B.SMLOCK != slmlr_unlock.B.SMLOCK) {
            } else {
                *p_locked = 1;
@@ -259,11 +251,9 @@ unlock_once(int lsel, int msel, int hbsel, int *p_locked)
            FLASH.SLMLR = slmlr_unlock;
    /* Do we have to unlock something in the high block?
    hlr = FLASH.HLR;
    if (hbsel && (hlr.B.HBE == 0)) {
        union HLR_tag hlr_unlock;
@@ -272,7 +262,6 @@ unlock_once(int lsel, int msel, int hbsel, int *p_locked)
        if (hlr.B.HBLOCK != hlr_unlock.B.HBLOCK) {
            } else {
                *p_locked = 1;
@@ -280,7 +269,6 @@ unlock_once(int lsel, int msel, int hbsel, int *p_locked)
            FLASH.HLR = hlr_unlock;
    return 0;
@@ -398,24 +386,25 @@ mpc55xx_flash_copy_op(
    uint32_t udest, usrc, flash_size;
    int r;
-    int peg;            /* Program or Erase Good - Did it work? */
+    int peg;                        /* Program or Erase Good - Did it work? */
-    int lsel;           /* Low block select bits. */
-    int msel;           /* Mid block select bits. */
-    int hbsel;          /* High block select bits. */
+    int lsel;                       /* Low block select bits. */
+    int msel;                       /* Mid block select bits. */
+    int hbsel;                      /* High block select bits. */
-    int s_lsel;           /* Source Low block select bits. */
-    int s_msel;           /* Source Mid block select bits. */
-    int s_hbsel;          /* Source High block select bits. */
+    int s_lsel;                     /* Source Low block select bits. */
+    int s_msel;                     /* Source Mid block select bits. */
+    int s_hbsel;                    /* Source High block select bits. */
    int unlocked = 0;
    int *p_unlocked;
    int i;
-    int nwords;         /* The number of 32 bit words to write. */
-    volatile uint32_t *flash;    /* Where the flash is mapped in. */
-    volatile uint32_t *memory;   /* What to copy into flash. */
-    uint32_t offset;    /* Where the FLASH is mapped into memory. */
+    int nwords;                     /* The number of 32 bit words to write. */
+    volatile uint32_t *flash;       /* Where the flash is mapped in. */
+    volatile uint32_t *memory;      /* What to copy into flash. */
+    const void *flashing_from;      /* Where we are flahsing from.
+                                     * "const" is to match invalidate cache function signature. */
+    uint32_t offset;                /* Where the FLASH is mapped into memory. */
    if ( (r = mpc55xx_flash_size(&flash_size))) {
        return r;
@@ -461,13 +450,13 @@ mpc55xx_flash_copy_op(
    /* Set up the bit masks for the blocks to program or erase.
-    range_set(udest, udest + nbytes, &lsel,   lsel_ranges, N( lsel_ranges));
-    range_set(udest, udest + nbytes, &msel,   msel_ranges, N( msel_ranges));
-    range_set(udest, udest + nbytes, &hbsel, hbsel_ranges, N(hbsel_ranges));
+    range_set(udest, udest + nbytes, &lsel,   lsel_ranges, RTEMS_ARRAY_SIZE( lsel_ranges));
+    range_set(udest, udest + nbytes, &msel,   msel_ranges, RTEMS_ARRAY_SIZE( msel_ranges));
+    range_set(udest, udest + nbytes, &hbsel, hbsel_ranges, RTEMS_ARRAY_SIZE(hbsel_ranges));
-    range_set(usrc, usrc + nbytes, &s_lsel,   lsel_ranges, N( lsel_ranges));
-    range_set(usrc, usrc + nbytes, &s_msel,   msel_ranges, N( msel_ranges));
-    range_set(usrc, usrc + nbytes, &s_hbsel, hbsel_ranges, N(hbsel_ranges));
+    range_set(usrc, usrc + nbytes, &s_lsel,   lsel_ranges, RTEMS_ARRAY_SIZE( lsel_ranges));
+    range_set(usrc, usrc + nbytes, &s_msel,   msel_ranges, RTEMS_ARRAY_SIZE( msel_ranges));
+    range_set(usrc, usrc + nbytes, &s_hbsel, hbsel_ranges, RTEMS_ARRAY_SIZE(hbsel_ranges));
    /* Are we attempting overlapping flash?
@@ -481,33 +470,39 @@ mpc55xx_flash_copy_op(
  /* In the following sections any "Step N" notes refer to
   * the steps in "13.4.2.3 Flash Programming" in the reference manual.
-   * XXX Do parts of this neeed to be protected by interrupt locks?
    if (opmask & MPC55XX_FLASH_ERASE) {   /* Erase. */
+        uint32_t flash_biucr_r;
        if ( (r = unlock_once(lsel, msel, hbsel, p_unlocked)) ) {
            return r;
+        /* Per errata "e989: FLASH: Disable Prefetch during programming and erase" */
+        flash_biucr_r = FLASH.BIUCR.R;
+        FLASH.BIUCR.B.PFLIM = 0;
+        FLASH.MCR.B.ESUS = 0;       /* Be sure ESUS is clear. */
        FLASH.MCR.B.ERS = 1;        /* Step 1: Select erase. */
        FLASH.LMSR.B.LSEL = lsel;   /* Step 2: Select blocks to be erased. */
        FLASH.LMSR.B.MSEL = msel;
        FLASH.HSR.B.HBSEL = hbsel;
-        flash[0] = 1;               /* Step 3: Write to any address in the flash
+        flash[0] = 0xffffffff;      /* Step 3: Write to any address in the flash
                                     * (the "erase interlock write)".
+        rtems_cache_flush_multiple_data_lines(flash, sizeof(flash[0]));
        FLASH.MCR.B.EHV = 1;         /* Step 4: Enable high V to start erase. */
        while (FLASH.MCR.B.DONE == 0) { /* Step 5: Wait until done. */
        peg = FLASH.MCR.B.PEG;       /* Save result. */
        FLASH.MCR.B.EHV = 0;         /* Disable high voltage. */
        FLASH.MCR.B.ERS = 0;         /* De-select erase. */
+        FLASH.BIUCR.R = flash_biucr_r;
        if (peg == 0) {
            return MPC55XX_FLASH_ERASE_ERR; /* Flash erase failed. */
@@ -534,9 +529,7 @@ mpc55xx_flash_copy_op(
        FLASH.MCR.B.PGM = 1;                /* Step 1 */
-        for (i = 0; i < nwords; i += 2) {
+        for (flashing_from = (const void *)flash, i = 0; i < nwords; i += 2) {
           flash[i] = memory[i];            /* Step 2 */
           flash[i + 1] = memory[i + 1];    /* Always program in min 64 bits. */
@@ -548,45 +541,45 @@ mpc55xx_flash_copy_op(
           chunk++;
           if (chunk == 4) {
                /* Collected 4 64-bits for a 256 bit chunk. */
+                rtems_cache_flush_multiple_data_lines(flashing_from, 32);    /* Flush cache. */
                FLASH.MCR.B.EHV = 1;            /* Step 4: Enable high V. */
                peg = FLASH.MCR.B.PEG;          /* Step 6: Save result. */
                FLASH.MCR.B.EHV = 0;            /* Step 7: Disable high V. */
                if (peg == 0) {
                    FLASH.MCR.B.PGM = 0;
                    if (p_fail) {
                        *p_fail = (uint32_t)(flash + i);
                    return MPC55XX_FLASH_PROGRAM_ERR; /* Programming failed. */
                chunk = 0;                       /* Reset chunk counter. */
+                flashing_from = (const void *)(flash + i);
                                                 /* Step 8: Back to step 2. */
       if (!chunk) {
       } else {
           /* If there is anything left in that last chunk flush it out:
+            rtems_cache_flush_multiple_data_lines(flashing_from, chunk * 8);
            while (FLASH.MCR.B.DONE == 0) {     /* Wait until done. */
            if (peg == 0) {
                if (p_fail) {
1.7.1
