nios2_iss cache_manager.c Build Failure
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Aug 22 14:32:08 UTC 2014
Hi
Similar issue to NDS. Could someone please fix this?
../../../../../../../rtems/c/src/lib/libcpu/nios2/../shared/src/cache_manager.c:
In function '_invalidate_multiple_instruction_lines_no_range_functions':
../../../../../../../rtems/c/src/lib/libcpu/nios2/../shared/src/cache_manager.c:458:
error: 'CPU_INSTRUCTION_CACHE_ALIGNMENT' undeclared (first use in this
function)
error: (Each undeclared identifier is reported only once
