[PATCH] score: Define _CPU_Start_multitasking only for LEON SPARC, not SPARC in general
Mon Aug 25 17:29:38 UTC 2014
On 8/25/2014 11:44 AM, Sebastian Huber wrote:
> On 08/25/2014 05:04 PM, Joel Sherrill wrote:
>> On 8/25/2014 5:10 AM, Sebastian Huber wrote:
>>> On 25/08/14 11:45, Daniel Cederman wrote:
>>>>    cpukit/score/cpu/sparc/rtems/score/cpu.h |    2 ++
>>>>    1 file changed, 2 insertions(+)
>>>> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>>>> index 9c38b55..d4c2ef0 100644
>>>> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
>>>> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>>>> @@ -1203,9 +1203,11 @@ register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
>>>>      void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
>>>> +  #if defined(__leon__)
>>>>      void _BSP_Start_multitasking( Context_Control *heir )
>>>>        RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
>>>>      #define _CPU_Start_multitasking _BSP_Start_multitasking
>>>> +  #endif
>>> In case it is LEON specific, then it should have a LEON specific name.
>> What's the overall rationale?
> If its mandated by the CPU port, e.g. all the stuff defined by
> no_cpu/cpu.h, then it should be _CPU_*.  In case all BSPs of a CPU port
> must implement a CPU port function, then it is _BSP_*.  In case only
> certain multilib variants implement it specifically, then they should
> have an appropriate multilib specific prefix, e.g. _LEON3_* or
> _ARMV7M_*.  Does this make sense?  Maybe we should add this stuff to the
> CPU supplement.
Yeah. I get this part and we do need better rules but what's the issue
with this
one method? The ifdef made it look like only the leon flavor of RTEMS and no
others even had this method.
