[rtems commit] preinstall: Regenerated files differ from the repo.
Thu Aug 28 14:12:02 UTC 2014
Chris should be on a Mac. I am on Fedora 20.
$ autoconf --version
autoconf (GNU Autoconf) 2.69
Double checking, mine is the one built by the RSB.
Checking on a CentOS 6.x computer with the RSB built
autoconf, it is different.
That shouldn't happen. :(
--joel
On 8/28/2014 9:07 AM, Hesham Moustafa wrote:
> Hi,
> On Thu, Aug 28, 2014 at 3:44 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> When I bootstrap -p from the top, it looks like every other
>> preinstall.am in the tree  has this difference.
>> Big commit following to deal with this.
> Is this host and/or automake version dependent? Because when I run
> bootsrap -p, EVERY preinstall.am file differs from the repo. A diff
> patch is attached.
>> --joel
>> On 8/27/2014 7:54 PM, Chris Johns wrote:
>>> Module:    rtems
>>> Branch:    master
>>> Commit:    5826a1b284450778be4b73276560a48ccd0cd9a7
>>> Changeset: http://git.rtems.org/rtems/commit/?id=5826a1b284450778be4b73276560a48ccd0cd9a7
>>> Author:    Chris Johns <chrisj at rtems.org>
>>> Date:      Thu Aug 28 10:08:00 2014 +1000
>>>  .../lib/libbsp/arm/altera-cyclone-v/preinstall.am  |   12 ++++++------
>>>  c/src/lib/libbsp/or1k/or1ksim/preinstall.am        |   13 +++++++------
>>>  c/src/lib/libbsp/or1k/preinstall.am                |    1 +
>>>  c/src/lib/libcpu/or1k/preinstall.am                |    7 ++++---
>>>  4 files changed, 18 insertions(+), 15 deletions(-)
>>> diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am b/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>> index 768c01d..5b6b9fd 100644
>>> --- a/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>> +++ b/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>> @@ -5,18 +5,18 @@ $(srcdir)/preinstall.am: Makefile.am
>>>       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>>>  endif
>>> -all-am: $(PREINSTALL_FILES)
>>> -PREINSTALL_FILES =
>>> -CLEANFILES = $(PREINSTALL_FILES)
>>>  PREINSTALL_DIRS =
>>>  DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>  all-local: $(TMPINSTALL_FILES)
>>>  TMPINSTALL_FILES =
>>> -CLEANFILES += $(TMPINSTALL_FILES)
>>> +CLEANFILES = $(TMPINSTALL_FILES)
>>> +all-am: $(PREINSTALL_FILES)
>>> +PREINSTALL_FILES =
>>> +CLEANFILES += $(PREINSTALL_FILES)
>>>  $(PROJECT_LIB)/$(dirstamp):
>>>       @$(MKDIR_P) $(PROJECT_LIB)
>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>> index cbdf3df..2569864 100644
>>> --- a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>> @@ -8,15 +8,15 @@ endif
>>>  PREINSTALL_DIRS =
>>> -PREINSTALL_FILES =
>>>  TMPINSTALL_FILES =
>>> +PREINSTALL_FILES =
>>> @@ -117,3 +117,4 @@ TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
>>>  $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(dirstamp)
>>>       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>>>  TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
>>> diff --git a/c/src/lib/libbsp/or1k/preinstall.am b/c/src/lib/libbsp/or1k/preinstall.am
>>> index 1143c2e..dba6cc4 100644
>>> --- a/c/src/lib/libbsp/or1k/preinstall.am
>>> +++ b/c/src/lib/libbsp/or1k/preinstall.am
>>> @@ -4,3 +4,4 @@ if AMPOLISH3
>>>  endif
>>> diff --git a/c/src/lib/libcpu/or1k/preinstall.am b/c/src/lib/libcpu/or1k/preinstall.am
>>> index 9670596..ee9d0da 100644
>>> --- a/c/src/lib/libcpu/or1k/preinstall.am
>>> +++ b/c/src/lib/libcpu/or1k/preinstall.am
>>> @@ -5,14 +5,14 @@ $(srcdir)/preinstall.am: Makefile.am
>>>  endif
>>> +PREINSTALL_DIRS =
>>> +DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>  PREINSTALL_FILES =
>>> -PREINSTALL_DIRS =
>>> -DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>  $(PROJECT_INCLUDE)/libcpu/$(dirstamp):
>>>       @$(MKDIR_P) $(PROJECT_INCLUDE)/libcpu
>>>       @: > $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>> @@ -21,3 +21,4 @@ PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>  $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
>>> vc mailing list
>>> vc at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/vc
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
