[rtems commit] preinstall: Regenerated files differ from the repo.
Hesham Moustafa heshamelmatary at gmail.com
Thu Aug 28 14:20:31 UTC 2014
On Thu, Aug 28, 2014 at 4:12 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Chris should be on a Mac. I am on Fedora 20.
I am on Fedora 20 too
$ autoconf --version
autoconf (GNU Autoconf) 2.69
> Double checking, mine is the one built by the RSB.
> Checking on a CentOS 6.x computer with the RSB built
> autoconf, it is different.
> That shouldn't happen. :(
> --joel
> On 8/28/2014 9:07 AM, Hesham Moustafa wrote:
>> Hi,
>> On Thu, Aug 28, 2014 at 3:44 PM, Joel Sherrill
>>> When I bootstrap -p from the top, it looks like every other
>>> preinstall.am in the tree  has this difference.
>>> Big commit following to deal with this.
>> Is this host and/or automake version dependent? Because when I run
>> bootsrap -p, EVERY preinstall.am file differs from the repo. A diff
>> patch is attached.
>>> --joel
>>> On 8/27/2014 7:54 PM, Chris Johns wrote:
>>>> Module:    rtems
>>>> Branch:    master
>>>> Commit:    5826a1b284450778be4b73276560a48ccd0cd9a7
>>>> Changeset: http://git.rtems.org/rtems/commit/?id=5826a1b284450778be4b73276560a48ccd0cd9a7
>>>> Author:    Chris Johns <chrisj at rtems.org>
>>>> Date:      Thu Aug 28 10:08:00 2014 +1000
>>>>  .../lib/libbsp/arm/altera-cyclone-v/preinstall.am  |   12 ++++++------
>>>>  c/src/lib/libbsp/or1k/or1ksim/preinstall.am        |   13 +++++++------
>>>>  c/src/lib/libbsp/or1k/preinstall.am                |    1 +
>>>>  c/src/lib/libcpu/or1k/preinstall.am                |    7 ++++---
>>>>  4 files changed, 18 insertions(+), 15 deletions(-)
>>>> diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am b/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>>> index 768c01d..5b6b9fd 100644
>>>> --- a/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>>> +++ b/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>>> @@ -5,18 +5,18 @@ $(srcdir)/preinstall.am: Makefile.am
>>>>       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>>>>  endif
>>>> -all-am: $(PREINSTALL_FILES)
>>>> -PREINSTALL_FILES =
>>>> -CLEANFILES = $(PREINSTALL_FILES)
>>>>  PREINSTALL_DIRS =
>>>>  DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>>  all-local: $(TMPINSTALL_FILES)
>>>>  TMPINSTALL_FILES =
>>>> -CLEANFILES += $(TMPINSTALL_FILES)
>>>> +CLEANFILES = $(TMPINSTALL_FILES)
>>>> +all-am: $(PREINSTALL_FILES)
>>>> +PREINSTALL_FILES =
>>>> +CLEANFILES += $(PREINSTALL_FILES)
>>>>  $(PROJECT_LIB)/$(dirstamp):
>>>>       @$(MKDIR_P) $(PROJECT_LIB)
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>> index cbdf3df..2569864 100644
>>>> --- a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>> @@ -8,15 +8,15 @@ endif
>>>>  PREINSTALL_DIRS =
>>>> -PREINSTALL_FILES =
>>>>  TMPINSTALL_FILES =
>>>> +PREINSTALL_FILES =
>>>> @@ -117,3 +117,4 @@ TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
>>>>  $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(dirstamp)
>>>>       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>>>>  TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
>>>> diff --git a/c/src/lib/libbsp/or1k/preinstall.am b/c/src/lib/libbsp/or1k/preinstall.am
>>>> index 1143c2e..dba6cc4 100644
>>>> --- a/c/src/lib/libbsp/or1k/preinstall.am
>>>> +++ b/c/src/lib/libbsp/or1k/preinstall.am
>>>> @@ -4,3 +4,4 @@ if AMPOLISH3
>>>>  endif
>>>> diff --git a/c/src/lib/libcpu/or1k/preinstall.am b/c/src/lib/libcpu/or1k/preinstall.am
>>>> index 9670596..ee9d0da 100644
>>>> --- a/c/src/lib/libcpu/or1k/preinstall.am
>>>> +++ b/c/src/lib/libcpu/or1k/preinstall.am
>>>> @@ -5,14 +5,14 @@ $(srcdir)/preinstall.am: Makefile.am
>>>>  endif
>>>> +PREINSTALL_DIRS =
>>>> +DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>>  PREINSTALL_FILES =
>>>> -PREINSTALL_DIRS =
>>>> -DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>>  $(PROJECT_INCLUDE)/libcpu/$(dirstamp):
>>>>       @$(MKDIR_P) $(PROJECT_INCLUDE)/libcpu
>>>>       @: > $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>> @@ -21,3 +21,4 @@ PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>>  $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>>       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
>>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
>>>> _______________________________________________
>>>> vc mailing list
>>>> vc at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/vc
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
