[rtems commit] preinstall: Regenerated files differ from the repo.
Thu Aug 28 14:25:15 UTC 2014
On 8/28/2014 9:20 AM, Hesham Moustafa wrote:
> On Thu, Aug 28, 2014 at 4:12 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Chris should be on a Mac. I am on Fedora 20.
> I am on Fedora 20 too
> $ autoconf --version
> autoconf (GNU Autoconf) 2.69
The RSB version? 32 or 64 bit?
>> Double checking, mine is the one built by the RSB.
>> Checking on a CentOS 6.x computer with the RSB built
>> autoconf, it is different.
>> That shouldn't happen. :(
>> --joel
>> On 8/28/2014 9:07 AM, Hesham Moustafa wrote:
>>> Hi,
>>> On Thu, Aug 28, 2014 at 3:44 PM, Joel Sherrill
>>>> When I bootstrap -p from the top, it looks like every other
>>>> preinstall.am in the tree  has this difference.
>>>> Big commit following to deal with this.
>>> Is this host and/or automake version dependent? Because when I run
>>> bootsrap -p, EVERY preinstall.am file differs from the repo. A diff
>>> patch is attached.
>>>> --joel
>>>> On 8/27/2014 7:54 PM, Chris Johns wrote:
>>>>> Module:    rtems
>>>>> Branch:    master
>>>>> Commit:    5826a1b284450778be4b73276560a48ccd0cd9a7
>>>>> Changeset: http://git.rtems.org/rtems/commit/?id=5826a1b284450778be4b73276560a48ccd0cd9a7
>>>>> Author:    Chris Johns <chrisj at rtems.org>
>>>>> Date:      Thu Aug 28 10:08:00 2014 +1000
>>>>>  .../lib/libbsp/arm/altera-cyclone-v/preinstall.am  |   12 ++++++------
>>>>>  c/src/lib/libbsp/or1k/or1ksim/preinstall.am        |   13 +++++++------
>>>>>  c/src/lib/libbsp/or1k/preinstall.am                |    1 +
>>>>>  c/src/lib/libcpu/or1k/preinstall.am                |    7 ++++---
>>>>>  4 files changed, 18 insertions(+), 15 deletions(-)
>>>>> diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am b/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>>>> index 768c01d..5b6b9fd 100644
>>>>> --- a/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>>>> +++ b/c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am
>>>>> @@ -5,18 +5,18 @@ $(srcdir)/preinstall.am: Makefile.am
>>>>>       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>>>>>  endif
>>>>> -all-am: $(PREINSTALL_FILES)
>>>>> -PREINSTALL_FILES =
>>>>> -CLEANFILES = $(PREINSTALL_FILES)
>>>>>  PREINSTALL_DIRS =
>>>>>  DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>>>  all-local: $(TMPINSTALL_FILES)
>>>>>  TMPINSTALL_FILES =
>>>>> -CLEANFILES += $(TMPINSTALL_FILES)
>>>>> +CLEANFILES = $(TMPINSTALL_FILES)
>>>>> +all-am: $(PREINSTALL_FILES)
>>>>> +PREINSTALL_FILES =
>>>>> +CLEANFILES += $(PREINSTALL_FILES)
>>>>>  $(PROJECT_LIB)/$(dirstamp):
>>>>>       @$(MKDIR_P) $(PROJECT_LIB)
>>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>>> index cbdf3df..2569864 100644
>>>>> --- a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>>> @@ -8,15 +8,15 @@ endif
>>>>>  PREINSTALL_DIRS =
>>>>> -PREINSTALL_FILES =
>>>>>  TMPINSTALL_FILES =
>>>>> +PREINSTALL_FILES =
>>>>> @@ -117,3 +117,4 @@ TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
>>>>>  $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(dirstamp)
>>>>>       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>>>>>  TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
>>>>> diff --git a/c/src/lib/libbsp/or1k/preinstall.am b/c/src/lib/libbsp/or1k/preinstall.am
>>>>> index 1143c2e..dba6cc4 100644
>>>>> --- a/c/src/lib/libbsp/or1k/preinstall.am
>>>>> +++ b/c/src/lib/libbsp/or1k/preinstall.am
>>>>> @@ -4,3 +4,4 @@ if AMPOLISH3
>>>>>  endif
>>>>> diff --git a/c/src/lib/libcpu/or1k/preinstall.am b/c/src/lib/libcpu/or1k/preinstall.am
>>>>> index 9670596..ee9d0da 100644
>>>>> --- a/c/src/lib/libcpu/or1k/preinstall.am
>>>>> +++ b/c/src/lib/libcpu/or1k/preinstall.am
>>>>> @@ -5,14 +5,14 @@ $(srcdir)/preinstall.am: Makefile.am
>>>>>  endif
>>>>> +PREINSTALL_DIRS =
>>>>> +DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>>>  PREINSTALL_FILES =
>>>>> -PREINSTALL_DIRS =
>>>>> -DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>>>  $(PROJECT_INCLUDE)/libcpu/$(dirstamp):
>>>>>       @$(MKDIR_P) $(PROJECT_INCLUDE)/libcpu
>>>>>       @: > $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>>> @@ -21,3 +21,4 @@ PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>>>  $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>>>       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
>>>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
>>>>> _______________________________________________
>>>>> vc mailing list
>>>>> vc at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/vc
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
