[rtems commit] preinstall: Regenerated files differ from the repo.
Hesham Moustafa heshamelmatary at gmail.com
Fri Aug 29 08:55:00 UTC 2014
On Fri, Aug 29, 2014 at 3:45 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 29/08/2014 12:30 am, Hesham Moustafa wrote:
>> On Thu, Aug 28, 2014 at 4:25 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>>> On 8/28/2014 9:20 AM, Hesham Moustafa wrote:
>>>> On Thu, Aug 28, 2014 at 4:12 PM, Joel Sherrill
>>>>> Chris should be on a Mac. I am on Fedora 20.
>>>> I am on Fedora 20 too
>>>> $ autoconf --version
>>>> autoconf (GNU Autoconf) 2.69
>>> The RSB version? 32 or 64 bit?
>> RTEMS Source Builder - Set Builder, v0.4.0
>> Python: 2.7.5 (default, Jun 25 2014, 10:19:55) [GCC 4.8.2 20131212
>> (Red Hat 4.8.2-7)]
>> Fedora 20 - 64 bit
> Does the attached patch fix the problem ?
I applied the attached patch (for both HEAD, and before Joel's
preinstall.am commit), and then run bootstrap -p, the same behavior
occurs for me which is EVERY preinstall.am file is modified.
> For me this patch gives the same output before Joel's patch (which may need
> to be reverted).
> Chris
