[rtems commit] preinstall: Regenerated files differ from the repo.
Ralf Corsepius ralf.corsepius at rtems.org
Fri Aug 29 10:58:25 UTC 2014
On 08/29/2014 10:55 AM, Hesham Moustafa wrote:
>> Does the attached patch fix the problem ?
> I applied the attached patch (for both HEAD, and before Joel's
> preinstall.am commit), and then run bootstrap -p, the same behavior
> occurs for me which is EVERY preinstall.am file is modified.
Which OS are you on, which version of perl is it and which LOCALE are
you using?
Ralf
