[rtems commit] preinstall: Regenerated files differ from the repo.
Fri Aug 29 14:47:38 UTC 2014
On 8/29/2014 3:55 AM, Hesham Moustafa wrote:
> On Fri, Aug 29, 2014 at 3:45 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 29/08/2014 12:30 am, Hesham Moustafa wrote:
>>> On Thu, Aug 28, 2014 at 4:25 PM, Joel Sherrill
>>> <joel.sherrill at oarcorp.com> wrote:
>>>> On 8/28/2014 9:20 AM, Hesham Moustafa wrote:
>>>>> On Thu, Aug 28, 2014 at 4:12 PM, Joel Sherrill
>>>>>> Chris should be on a Mac. I am on Fedora 20.
>>>>> I am on Fedora 20 too
>>>>> $ autoconf --version
>>>>> autoconf (GNU Autoconf) 2.69
>>>> The RSB version? 32 or 64 bit?
>>> RTEMS Source Builder - Set Builder, v0.4.0
>>> Python: 2.7.5 (default, Jun 25 2014, 10:19:55) [GCC 4.8.2 20131212
>>> (Red Hat 4.8.2-7)]
>>> Fedora 20 - 64 bit
>> Does the attached patch fix the problem ?
> I applied the attached patch (for both HEAD, and before Joel's
> preinstall.am commit), and then run bootstrap -p, the same behavior
> occurs for me which is EVERY preinstall.am file is modified.
For me, this is the breakdown.
Old output (formerly in git):
CentOS 6.x: perl-5.10.1-136.el6.i686
Fedora 18: perl-5.16.3-245.fc18.i686
New output (in git now):
Fedora 20: perl-5.18.2-289.fc20.x86_64
>> For me this patch gives the same output before Joel's patch (which may need
>> to be reverted).
>> Chris
