[rtems commit] preinstall: Regenerated files differ from the repo.
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Fri Aug 29 14:53:40 UTC 2014
On 8/29/2014 8:13 AM, Hesham Moustafa wrote:
> Hi,
> On Fri, Aug 29, 2014 at 2:55 PM, Ralf Corsepius
> <ralf.corsepius at rtems.org> wrote:
>> On 08/29/2014 01:11 PM, Hesham Moustafa wrote:
>>> On Fri, Aug 29, 2014 at 12:58 PM, Ralf Corsepius
>>>> On 08/29/2014 10:55 AM, Hesham Moustafa wrote:
>>>>>> Does the attached patch fix the problem ?
>>>>> I applied the attached patch (for both HEAD, and before Joel's
>>>>> preinstall.am commit), and then run bootstrap -p, the same behavior
>>>>> occurs for me which is EVERY preinstall.am file is modified.
>>>> Which OS are you on, which version of perl is it and which LOCALE are you
>>>> using?
>> You didn't answer my questions.
>> Which OS is it? Ubuntu, Debian, CentOS, Windows, *BSD?
> Oh, sorry, I though you read my reply to Joel in which I mentioned I
> am using fedora 20 - 64 bit
>> Locale: What are the environment variables specifying your language set to
>> (e.g. what does "echo $LANG" return)? Your name sounds Arab, so it would
>> seem likely to me you are using some Arab locale.
> $ echo $LANG
> en_US.utf8
This is from rtbf64a which generates the "new" order
$ perl --version
This is perl 5, version 18, subversion 2 (v5.18.2) built for
x86_64-linux-thread-multi
(with 19 registered patches, see perl -V for more detail)
$ locale --version
locale (GNU libc) 2.18
$ echo $LANG
en_US.UTF-8
>> Also, it's quite possible, the files Chris has generated are affected,
>> because he prefers to use exotic OSes.
And Fedora 20 for me generates the same thing.
>> Ralf
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
