[rtems commit] preinstall: Regenerated files differ from the repo.
Hesham Moustafa heshamelmatary at gmail.com
Fri Aug 29 13:13:54 UTC 2014
Hi,
On Fri, Aug 29, 2014 at 2:55 PM, Ralf Corsepius
<ralf.corsepius at rtems.org> wrote:
> On 08/29/2014 01:11 PM, Hesham Moustafa wrote:
>> On Fri, Aug 29, 2014 at 12:58 PM, Ralf Corsepius
>>> On 08/29/2014 10:55 AM, Hesham Moustafa wrote:
>>>>> Does the attached patch fix the problem ?
>>>> I applied the attached patch (for both HEAD, and before Joel's
>>>> preinstall.am commit), and then run bootstrap -p, the same behavior
>>>> occurs for me which is EVERY preinstall.am file is modified.
>>> Which OS are you on, which version of perl is it and which LOCALE are you
>>> using?
> You didn't answer my questions.
> Which OS is it? Ubuntu, Debian, CentOS, Windows, *BSD?
Oh, sorry, I though you read my reply to Joel in which I mentioned I
am using fedora 20 - 64 bit
> Locale: What are the environment variables specifying your language set to
> (e.g. what does "echo $LANG" return)? Your name sounds Arab, so it would
> seem likely to me you are using some Arab locale.
$ echo $LANG
en_US.utf8
> Also, it's quite possible, the files Chris has generated are affected,
> because he prefers to use exotic OSes.
> Ralf
> devel mailing list
> devel at rtems.org
