[PATCH 2/2] i386: doxygen and comments related to VESA real mode framebuffer
Jan Dolezal dolezj21 at fel.cvut.cz
Tue Dec 2 16:49:28 UTC 2014
 c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c   | 105 ++++---
 c/src/lib/libbsp/i386/pc386/include/edid.h         |  14 +-
 c/src/lib/libbsp/i386/pc386/include/fb_vesa.h      |  74 ++---
 c/src/lib/libbsp/i386/pc386/include/tblsizes.h     |   1 -
 c/src/lib/libbsp/i386/pc386/include/vbe3.h         | 311 ++++++++++++++-------
 c/src/lib/libbsp/i386/pc386/startup/ldsegs.S       |   6 +-
 c/src/lib/libbsp/i386/shared/irq/idt.c             |  10 +-
 .../libbsp/i386/shared/realmode_int/realmode_int.c |  69 ++++-
 .../libbsp/i386/shared/realmode_int/realmode_int.h |  33 ++-
 c/src/lib/libcpu/i386/cpu.h                        |  53 ++--
 cpukit/score/cpu/i386/cpu_asm.S                    |   4 +-
 cpukit/score/cpu/i386/rtems/score/i386.h           |  39 ++-
 12 files changed, 468 insertions(+), 251 deletions(-)
diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
index b7b27b6..fb9d575 100644
--- a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
+++ b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
@@ -1,35 +1,39 @@
- *  FB driver for graphic hardware compatible with VESA Bios Extension
- *  Real mode interface utilized
- *  Tested on real HW.
+ * @file fb_vesa_rm.c
+ * @ingroup i386_pc386
+ * @brief FB driver for graphic hardware compatible with VESA Bios Extension
+ *     Real mode interface utilized
+ *     Tested on real HW.
- *  Copyright (c) 2014 - CTU in Prague
- *                       Jan Doležal ( dolezj21 at fel.cvut.cz )
+ * Public sources related:
+ *   - VESA BIOS EXTENSION (VBE) Core Function Standard, Ver: 3.0, Sep 16, 1998
+ *   - VESA Enhanced Extended Display Identification Data (E-EDID) Standard
+ *     Release A, Revision 2, September 25, 2006
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * Hardware is completely initialized upon boot of the system.
+ * Therefore there is no way to change graphics mode later.
- *  The code for rtems_buffer_* functions were greatly
- *  inspired or coppied from:
- *    - RTEMS fb_cirrus.c - Alexandru-Sever Horin (alex.sever.h at gmail.com)
+ * Interrupt 0x10 is used for entering graphics BIOS.
- *  Public sources related:
- *    - VESA BIOS EXTENSION (VBE) Core Function Standard, Ver: 3.0, Sep 16, 1998
- *    - VESA Enhanced Extended Display Identification Data (E-EDID) Standard
- *      Release A, Revision 2, September 25, 2006
+ * Driver reads parameter from multiboot command line to setup video:
+ * "--video=<resX>x<resY>[-<bpp>]"
+ * If cmdline parameter is not specified an attempt for obtaining
+ * resolution from display attached is made.
- *  Hardware is completely initialized upon boot of the system.
- *  Therefore there is no way to change graphics mode later.
+ * Copyright (c) 2014 - CTU in Prague
+ *                      Jan Doležal ( dolezj21 at fel.cvut.cz )
- *  Interrupt 0x10 is used for entering graphics BIOS.
- *  Driver reads parameter from multiboot command line to setup video:
- *  "--video=<resX>x<resY>[-<bpp>]"
- *  If cmdline parameter is not specified an attempt for obtaining
- *  resolution from display attached is made.
+ * The code for rtems_buffer_* functions were greatly
+ * inspired or coppied from:
+ *   - RTEMS fb_cirrus.c - Alexandru-Sever Horin (alex.sever.h at gmail.com)
 #include <bsp.h>
@@ -48,6 +52,13 @@
 #define FB_VESA_NAME    "FB_VESA_RM"
+ * @brief Initializes VBE framebuffer during bootup.
+ * utilizes switches to real mode interrupts and therefore must be
+ * called during bootup before tick is set up and real-time
+ * interrupt vectors utilized
 void vesa_realmode_bootup_init(void);
 /* mutex for protection against multiple opens, when called frame_buffer_open */
@@ -187,19 +198,37 @@ inline uint32_t VBE_read_EDID(uint16_t controller_unit_number,
     return (parret.reg_eax & 0xFFFF);
+ * @brief Basic graphic's mode parameters
 typedef struct {
+    /** number of the graphic's mode */
     uint16_t mode_number;
+    /** number of pixels in one line */
     uint16_t resX;
+    /** number of lines */
     uint16_t resY;
+    /** bits per pixel */
     uint8_t bpp;
 } Mode_params;
-/* finds mode in 'modeList' of 'listLength' length according to resolution
-    given in 'searchedResolution'. If bpp is given in that struct as well
-    mode with such color depth and resolution is searched for. Otherwise bpp
-    has to be zero. Mode number found is returned and also filled into
-    'searchedResolution'. bpp is also filled into 'searchedResolution' if it
-    was 0 before call. */
+ * @brief Find mode by resolution in the given list of modes
+ * finds mode in \p mode_list of \p list_length length according to resolution
+ * given in \p searched_resolution . If bpp is given in that struct as well
+ * mode with such color depth and resolution is searched for. Otherwise bpp
+ * has to be zero. Mode number found is returned and also filled into
+ * \p searched_resolution . bpp is also filled into \p searchedResolution if it
+ * was 0 before call.
+ * @param[in] mode_list list of modes to be searched
+ * @param[in] list_length number of modes in the list
+ * @param searched_resolution element filled with searched resolution or/and
+ *            bpp
+ * @retval mode number satisfying given parameters
+ * @retval -1 no suitable mode found
 static uint16_t find_mode_by_resolution(   Mode_params *mode_list,
                                         uint8_t list_length,
                                         Mode_params *searched_resolution)
@@ -223,14 +252,18 @@ static uint16_t find_mode_by_resolution(   Mode_params *mode_list,
     return -1;
- * Parse comandline option "--video=" if available.
+ * @brief Find mode given within command line.
+ * Parse command line option "--video=" if available.
  *  expected format
  *  --video=<resX>x<resY>[-<bpp>]
  *  numbers <resX>, <resY> and <bpp> are decadic
  * @retval video mode number to be set
- *         -1 on parsing error or when no suitable mode found
+ * @retval -1 on parsing error or when no suitable mode found
 static uint16_t find_mode_using_cmdline(Mode_params *mode_list,
                                         uint8_t list_length)
@@ -278,11 +311,13 @@ static uint16_t find_mode_using_cmdline(Mode_params *mode_list,
     return -1;
- * returns mode number best fitting to monitor attached
+ * @brief Find mode number best fitting to monitor attached
 static uint16_t find_mode_using_EDID( Mode_params *mode_list,
diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h b/c/src/lib/libbsp/i386/pc386/include/edid.h
index 41bf1ca..16be6f6 100644
--- a/c/src/lib/libbsp/i386/pc386/include/edid.h
+++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
@@ -4,16 +4,16 @@
  * @brief VESA EDID definitions.
+ * This file contains definitions for constants related to
+ * VESA Extended Display Identification Data.
+ *         More information can be found at
+ *     <http://www.vesa.org/vesa-standards/free-standards/>
+ *         VESA public standards may be found at
+ *     <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
- * edid.h  - This file contains definitions for constants related to
- *           VESA Extended Display Identification Data.
- *          More information can be found at
- *      <http://www.vesa.org/vesa-standards/free-standards/>
- *          VESA public standards may be found at
- *      <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
  * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
  *                     CTU in Prague.
diff --git a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
index 88e7dd8..d03b070 100644
--- a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
+++ b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
@@ -3,12 +3,10 @@
- * @brief Definitioins for vesa based framebuffer drivers.
+ * @brief Headers specific for framebuffer drivers utilizing VESA VBE.
- * Headers specific for framebuffer drivers utilizing VESA VBE.
  *                     CTU in Prague.
@@ -35,15 +33,16 @@ extern "C" {
 /* ----- Prototypes ----- */
- * Returns information about graphic's controller in the infoBlock structure.
+ * @brief Returns information about graphic's controller in the \p info_block
+ * structure.
- * @param infoBlock pointer to the struct to be filled with
-                    controller information
- * @param queriedVBEVersion if >0x200 then video bios is asked to fill in
+ * @param info_block pointer to the struct to be filled with
+ *                  controller information
+ * @param queried_VBE_Version if >0x200 then video bios is asked to fill in
  *                          parameters which appeared with second version
  *                          of VBE.
- * @retval  register ax content as defined in VBE RETURN STATUS paragraph
- *          -1 error calling graphical bios
+ * @retval  ax register content as defined in VBE RETURN STATUS paragraph
+ * @retval  -1 error calling graphical bios
 uint32_t VBE_controller_information (
     VBE_VbeInfoBlock *info_block,
@@ -51,13 +50,13 @@ uint32_t VBE_controller_information (
- * Fills structure infoBlock with informations about selected mode in
- * modeNumber variable.
+ * @brief Fills structure \p info_block with informations about selected mode in
+ * \p mode_number variable.
- * @param infoBlock pointer to the struct to be filled with mode information
- * @param modeNumber detailes of this mode to be filled
+ * @param info_block pointer to the struct to be filled with mode information
+ * @param mode_number detailes of this mode to be filled
 uint32_t VBE_mode_information (
     VBE_ModeInfoBlock *info_block,
@@ -65,13 +64,13 @@ uint32_t VBE_mode_information (
- * Sets graphics mode selected. If mode has refreshRateCtrl bit set, than the
- * infoBlock must be filled accordingly.
+ * @brief Sets graphics mode selected. If mode has refreshRateCtrl bit set, than
+ * the \p info_block must be filled accordingly.
- * @param modeNumber number of mode to be set
- * @param infoBlock pointer to struct containing refresh rate control info
+ * @param mode_number number of mode to be set
+ * @param info_block pointer to struct containing refresh rate control info
 uint32_t VBE_set_mode (
     uint16_t mode_number,
@@ -79,27 +78,27 @@ uint32_t VBE_set_mode (
- * Get currently set mode number.
+ * @brief Get currently set mode number.
- * @param modeNumber variable to be filled with current mode number
+ * @param mode_number variable to be filled with current mode number
 uint32_t VBE_current_mode (
     uint16_t *mode_number
- * Gets information about display data channel implemented in the
+ * @brief Gets information about display data channel implemented in the
  * graphic's controller.
- * @param controllerUnitNumber
- * @param secondsToTransferEDIDBlock approximate time to transfer one EDID block
- *                                   rounded up to seconds
- * @param DDCLevelSupported after call contains DDC version supported and
+ * @param controller_unit_number
+ * @param seconds_to_transfer_EDID_block approximate time to transfer one EDID
+ *                                       block rounded up to seconds
+ * @param DDC_level_supported after call contains DDC version supported and
  *                          screen blanking state during transfer
 uint32_t VBE_report_DDC_capabilities (
@@ -108,13 +107,14 @@ uint32_t VBE_report_DDC_capabilities (
- * Reads selected EDID block from display attached to controller's interface.
+ * @brief Reads selected EDID block from display attached to controller's
+ * interface.
- * @param EDIDBlockNumber block no. to be read from the display
+ * @param EDID_block_number block no. to be read from the display
  * @param buffer place to store block fetched from the display
 uint32_t VBE_read_EDID (
diff --git a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
index 6128d87..bd4e989 100644
--- a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
+++ b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
@@ -7,7 +7,6 @@
- * Definitions related to the PC386 BSP.
  * This header file is also used in assembler modules.
diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
index ba0ae3f..5aaa461 100644
--- a/c/src/lib/libbsp/i386/pc386/include/vbe3.h
+++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
@@ -4,15 +4,15 @@
  * @brief VESA Bios Extension definitions.
+ * This file contains definitions for constants related to VBE.
- * vbe3.h  - This file contains definitions for constants related to VBE.
  *                     CTU in Prague.
@@ -156,22 +156,41 @@ extern "C" {
 #define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
                                         Specification Information */
 /* *** Structures *** */
+ * @brief Far pointer as defined by VBE standard.
 typedef struct {
+    /** @brief Offset to segment described by \a selector. */
     uint16_t offset;
+    /** @brief Selector or Segment depending on whether this is used from 16bit
+        protected mode or from real mode. */
     uint16_t selector;
 } VBE3_PACKED_ATTRIBUTE VBE_FarPtr;
+ * @brief Protected mode info block as defined by VBE standard.
 typedef struct {
-    uint8_t   Signature[4];    /*  PM Info Block Signature */
-    uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS */
-    uint16_t  PMInitialize;    /*  Offset of PM initialization entry point */
-    uint16_t  BIOSDataSel;     /*  Selector to BIOS data area emulation block */
-    uint16_t  A0000Sel;        /*  Selector to access A0000h physical mem */
-    uint16_t  B0000Sel;        /*  Selector to access B0000h physical mem */
-    uint16_t  B8000Sel;        /*  Selector to access B8000h physical mem */
-    uint16_t  CodeSegSel;      /*  Selector to access code segment as data */
-    uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
-    uint8_t   Checksum;        /*  Checksum byte for structure */
+    /** PM Info Block Signature */
+    uint8_t   Signature[4];
+    /** Offset of PM entry point within BIOS */
+    uint16_t  EntryPoint;
+    /** Offset of PM initialization entry point */
+    uint16_t  PMInitialize;
+    /** Selector to BIOS data area emulation block */
+    uint16_t  BIOSDataSel;
+    /** Selector to access A0000h physical memmory */
+    uint16_t  A0000Sel;
+    /** Selector to access B0000h physical memmory */
+    uint16_t  B0000Sel;
+    /** Selector to access B8000h physical memmory */
+    uint16_t  B8000Sel;
+    /** Selector to access code segment as data */
+    uint16_t  CodeSegSel;
+    /** Set to 1 when in protected mode */
+    uint8_t   InProtectMode;
+    /** Checksum byte for structure */
+    uint8_t   Checksum;
 } VBE3_PACKED_ATTRIBUTE VBE_PMInfoBlock;
 /* General VBE signature */
@@ -181,111 +200,201 @@ typedef struct {
 /* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
 #define VBE_END_OF_VideoModeList 0xFFFF
 #define VBE_STUB_VideoModeList 0xFFFF
+ * @brief Information about VBE implementation.
 typedef struct {
-    uint8_t   VbeSignature[4];   /*  VBE Signature */
-    uint16_t  VbeVersion;        /*  VBE Version */
-    uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
-    uint8_t   Capabilities[4];   /*  Capabilities of graphics controller */
-    uint32_t *VideoModePtr;      /*  VbeFarPtr to VideoModeList */
-    uint16_t  TotalMemory;       /*  Number of 64kb memory blocks    */
+    /** VBE Signature */
+    uint8_t   VbeSignature[4];
+    /** VBE Version */
+    uint16_t  VbeVersion;
+    /** VbeFarPtr to OEM String */
+    uint8_t  *OemStringPtr;
+    /** Capabilities of graphics controller */
+    uint8_t   Capabilities[4];
+    /** VbeFarPtr to VideoModeList */
+    uint32_t *VideoModePtr;
+    /** Number of 64kb memory blocks    */
+    uint16_t  TotalMemory;
     /*  Added for VBE 2.0+ */
-    uint16_t  OemSoftwareRev;    /*  VBE implementation Software revision */
-    uint8_t  *OemVendorNamePtr;  /*  VbeFarPtr to Vendor Name String */
-    uint8_t  *OemProductNamePtr; /*  VbeFarPtr to Product Name String */
-    uint8_t  *OemProductRevPtr;  /*  VbeFarPtr to Product Revision String */
-    uint8_t   Reserved[222];     /*  Reserved for VBE implementation scratch */
-    /*    area */
-    uint8_t   OemData[256];      /*  Data Area for OEM Strings */
+    /** VBE implementation Software revision */
+    uint16_t  OemSoftwareRev;
+    /** VbeFarPtr to Vendor Name String */
+    uint8_t  *OemVendorNamePtr;
+    /** VbeFarPtr to Product Name String */
+    uint8_t  *OemProductNamePtr;
+    /** VbeFarPtr to Product Revision String */
+    uint8_t  *OemProductRevPtr;
+    /** Reserved for VBE implementation scratch */
+    uint8_t   Reserved[222];
+    /** Data Area for OEM Strings */
+    uint8_t   OemData[256];
 } VBE3_PACKED_ATTRIBUTE VBE_VbeInfoBlock;
+ * @brief Describes graphic's mode parameter.
 typedef struct {
     /*  Mandatory information for all VBE revisions */
-    uint16_t  ModeAttributes;        /* mode attributes */
-    uint8_t   WinAAttributes;        /* window A attributes */
-    uint8_t   WinBAttributes;        /* window B attributes */
-    uint16_t  WinGranularity;        /* window granularity */
-    uint16_t  WinSize;               /* window size */
-    uint16_t  WinASegment;           /* window A start segment */
-    uint16_t  WinBSegment;           /* window B start segment */
-    uint32_t *WinFuncPtr;            /* real mode pointer to window function */
-    uint16_t  BytesPerScanLine;      /* bytes per scan line */
+    /** mode attributes */
+    uint16_t  ModeAttributes;
+    /** window A attributes */
+    uint8_t   WinAAttributes;
+    /** window B attributes */
+    uint8_t   WinBAttributes;
+    /** window granularity */
+    uint16_t  WinGranularity;
+    /** window size */
+    uint16_t  WinSize;
+    /** window A start segment */
+    uint16_t  WinASegment;
+    /** window B start segment */
+    uint16_t  WinBSegment;
+    /** real mode pointer to window function */
+    uint32_t *WinFuncPtr;
+    /** bytes per scan line */
+    uint16_t  BytesPerScanLine;
     /*  Mandatory information for VBE 1.2 and above */
-    uint16_t  XResolution;           /* horizontal resolution in px or chars */
-    uint16_t  YResolution;           /* vertical resolution in px or chars */
-    uint8_t   XCharSize;             /* character cell width in pixels */
-    uint8_t   YCharSize;             /* character cell height in pixels */
-    uint8_t   NumberOfPlanes;        /* number of memory planes */
-    uint8_t   BitsPerPixel;          /* bits per pixel */
-    uint8_t   NumberOfBanks;         /* number of banks */
-    uint8_t   MemoryModel;           /* memory model type */
-    uint8_t   BankSize;              /* bank size in KB */
-    uint8_t   NumberOfImagePages;    /* number of images */
-    uint8_t   Reserved0;             /* reserved for page function */
+    /** horizontal resolution in px or chars */
+    uint16_t  XResolution;
+    /** vertical resolution in px or chars */
+    uint16_t  YResolution;
+    /** character cell width in pixels */
+    uint8_t   XCharSize;
+    /** character cell height in pixels */
+    uint8_t   YCharSize;
+    /** number of memory planes */
+    uint8_t   NumberOfPlanes;
+    uint8_t   BitsPerPixel;
+    /** number of banks */
+    uint8_t   NumberOfBanks;
+    /** memory model type */
+    uint8_t   MemoryModel;
+    /** bank size in KB */
+    uint8_t   BankSize;
+    /** number of images */
+    uint8_t   NumberOfImagePages;
+    /** reserved for page function */
+    uint8_t   Reserved0;
     /*  Direct Color fields (required for direct/6 and YUV/7 memory models) */
-    uint8_t   RedMaskSize;           /* size of direct color red mask in bits */
-    uint8_t   RedFieldPosition;      /* bit position of lsb of red mask */
-    uint8_t   GreenMaskSize;         /* size of direct color green mask in b */
-    uint8_t   GreenFieldPosition;    /* bit position of lsb of green mask */
-    uint8_t   BlueMaskSize;          /* size of direct color blue mask in b */
-    uint8_t   BlueFieldPosition;     /* bit position of lsb of blue mask */
-    uint8_t   RsvdMaskSize;          /* size of direct color reserved mask */
-    uint8_t   RsvdFieldPosition;     /* bit position of lsb of reserved mask */
-    uint8_t   DirectColorModeInfo;   /* direct color mode attributes */
+    /** size of direct color red mask in bits */
+    uint8_t   RedMaskSize;
+    /** bit position of lsb of red mask */
+    uint8_t   RedFieldPosition;
+    /** size of direct color green mask in b */
+    uint8_t   GreenMaskSize;
+    /** bit position of lsb of green mask */
+    uint8_t   GreenFieldPosition;
+    /** size of direct color blue mask in b */
+    uint8_t   BlueMaskSize;
+    /** bit position of lsb of blue mask */
+    uint8_t   BlueFieldPosition;
+    /** size of direct color reserved mask */
+    uint8_t   RsvdMaskSize;
+    /** bit position of lsb of reserved mask */
+    uint8_t   RsvdFieldPosition;
+    /** direct color mode attributes */
+    uint8_t   DirectColorModeInfo;
     /*  Mandatory information for VBE 2.0 and above */
-    uint32_t *PhysBasePtr;           /* physical address for
-                                        flat memory frame buffer */
-    uint32_t  Reserved1;             /* Reserved - always set to 0 */
-    uint16_t  Reserved2;             /* Reserved - always set to 0 */
+    /** physical address for flat memory frame buffer */
+    uint32_t *PhysBasePtr;
+    /** Reserved - always set to 0 */
+    uint32_t  Reserved1;
+    uint16_t  Reserved2;
     /*  Mandatory information for VBE 3.0 and above */
-    uint16_t  LinBytesPerScanLine;   /* bytes per scan line for linear modes */
-    uint8_t   BnkNumberOfImagePages; /* number of images for banked modes */
-    uint8_t   LinNumberOfImagePages; /* number of images for linear modes */
+    /** bytes per scan line for linear modes */
+    uint16_t  LinBytesPerScanLine;
+    /** number of images for banked modes */
+    uint8_t   BnkNumberOfImagePages;
+    /** number of images for linear modes */
+    uint8_t   LinNumberOfImagePages;
         /* linear modes */
-    uint8_t   LinRedMaskSize;        /* size of direct color red mask */
-    uint8_t   LinRedFieldPosition;   /* bit position of lsb of red mask */
-    uint8_t   LinGreenMaskSize;      /* size of direct color green mask  */
-    uint8_t   LinGreenFieldPosition; /* bit position of lsb of green mask */
-    uint8_t   LinBlueMaskSize;       /* size of direct color blue mask  */
-    uint8_t   LinBlueFieldPosition;  /* bit position of lsb of blue mask */
-    uint8_t   LinRsvdMaskSize;       /* size of direct color reserved mask */
-    uint8_t   LinRsvdFieldPosition;  /* bit position of lsb of reserved mask */
-    uint32_t  MaxPixelClock;         /* maximum pixel clock
-                                        (in Hz) for graphics mode */
-    uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
+    /** size of direct color red mask */
+    uint8_t   LinRedMaskSize;
+    uint8_t   LinRedFieldPosition;
+    /** size of direct color green mask  */
+    uint8_t   LinGreenMaskSize;
+    uint8_t   LinGreenFieldPosition;
+    /** size of direct color blue mask  */
+    uint8_t   LinBlueMaskSize;
+    uint8_t   LinBlueFieldPosition;
+    uint8_t   LinRsvdMaskSize;
+    uint8_t   LinRsvdFieldPosition;
+    /** maximum pixel clock (in Hz) for graphics mode */
+    uint32_t  MaxPixelClock;
+    /** remainder of ModeInfoBlock */
+    uint8_t   Reserved3[189];
 } VBE3_PACKED_ATTRIBUTE VBE_ModeInfoBlock;
+ * @brief Describes monitor synchronization.
 typedef struct {
-    uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
-    uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels */
-    uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
-    uint16_t  VerticalTotal;         /* Vertical total in lines */
-    uint16_t  VerticalSyncStart;     /* Vertical sync start in lines */
-    uint16_t  VerticalSyncEnd;       /* Vertical sync end in lines */
-    uint8_t   Flags;                 /* Flags (Interlaced, Double Scan etc) */
-    uint32_t  PixelClock;            /* Pixel clock in units of Hz */
-    uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz */
-    uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
+    /** Horizontal total in pixels */
+    uint16_t  HorizontalTotal;
+    /** Horizontal sync start in pixels */
+    uint16_t  HorizontalSyncStart;
+    /** Horizontal sync end in pixels */
+    uint16_t  HorizontalSyncEnd;
+    /** Vertical total in lines */
+    uint16_t  VerticalTotal;
+    /** Vertical sync start in lines */
+    uint16_t  VerticalSyncStart;
+    /** Vertical sync end in lines */
+    uint16_t  VerticalSyncEnd;
+    /** Flags (Interlaced, Double Scan etc) */
+    uint8_t   Flags;
+    /** Pixel clock in units of Hz */
+    uint32_t  PixelClock;
+    /** Refresh rate in units of 0.01 Hz */
+    uint16_t  RefreshRate;
+    uint8_t   Reserved[40];
 } VBE3_PACKED_ATTRIBUTE VBE_CRTCInfoBlock;
+ * @brief Describes palette entry.
 typedef struct {
-    uint8_t   Blue;                  /* Blue channel value (6 or 8 bits) */
-    uint8_t   Green;                 /* Green channel value (6 or 8 bits) */
-    uint8_t   Red;                   /* Red channel value(6 or 8 bits) */
-    uint8_t   Alignment;             /* DWORD alignment byte (unused) */
+    /** Blue channel value (6 or 8 bits) */
+    uint8_t   Blue;
+    /** Green channel value (6 or 8 bits) */
+    uint8_t   Green;
+    /** Red channel value(6 or 8 bits) */
+    uint8_t   Red;
+    /** DWORD alignment byte (unused) */
+    uint8_t   Alignment;
 } VBE3_PACKED_ATTRIBUTE VBE_PaletteEntry;
+ * @brief Supplemental VBE info block.
 typedef struct {
-    uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
-    uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
-    uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported subfunctions */
-    uint16_t  OemSoftwareRev;        /* OEM Software revision */
-    uint8_t   Reserved[221];         /* Reserved for description
-                                        strings and future */
-    /*  expansion */
+    /** Supplemental VBE Signature */
+    uint8_t   SupVbeSignature[7];
+    /** Supplemental VBE Version */
+    uint16_t  SupVbeVersion;
+    /** Bitfield of supported subfunctions */
+    uint8_t   SupVbeSubFunc[8];
+    /** OEM Software revision */
+    /** Reserved for description strings and future expansion */
+    uint8_t   Reserved[221];
 } VBE3_PACKED_ATTRIBUTE VBE_SupVbeInfoBlock;
 /* VbeInfoBlock Capabilities */
diff --git a/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S b/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
index 14cbb95..9d61caf 100644
--- a/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
+++ b/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
@@ -200,7 +200,7 @@ SYM (_Global_descriptor_table):
         PUBLIC(gdtdesc)
 SYM(gdtdesc):
-	.word (GDT_SIZE*8 - 1)
+        .word (GDT_SIZE*8 - 1)
 	.long SYM (_Global_descriptor_table)
@@ -210,7 +210,7 @@ SYM(gdtdesc):
 	PUBLIC(Interrupt_descriptor_table)
 SYM(Interrupt_descriptor_table):
-	.rept IDT_SIZE
+        .rept IDT_SIZE
 	.word 0,0,0,0
 	.endr
@@ -221,7 +221,7 @@ SYM(Interrupt_descriptor_table):
 	.p2align 4
 	PUBLIC(IDT_Descriptor)
 SYM(IDT_Descriptor):
-	.word  (IDT_SIZE*8 - 1)
+        .word  (IDT_SIZE*8 - 1)
 	.long  SYM (Interrupt_descriptor_table)
 END_DATA
diff --git a/c/src/lib/libbsp/i386/shared/irq/idt.c b/c/src/lib/libbsp/i386/shared/irq/idt.c
index fc9364e..ff7db36 100644
--- a/c/src/lib/libbsp/i386/shared/irq/idt.c
+++ b/c/src/lib/libbsp/i386/shared/irq/idt.c
@@ -1,12 +1,12 @@
- * cpu.c  - This file contains implementation of C function to
+ * idt.c  - This file contains implementation of C function to
  *          instantiate IDT entries. More detailled information can be found
- *	    on Intel site and more precisely in the following book :
+ *          on Intel site and more precisely in the following book :
- *		Pentium Processor family
- *		Developper's Manual
+ *              Pentium Processor family
+ *              Developper's Manual
- *		Volume 3 : Architecture and Programming Manual
+ *              Volume 3 : Architecture and Programming Manual
  * Copyright (C) 1998  Eric Valette (valette at crf.canon.fr)
  *                     Canon Centre Recherche France.
diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
index af5cf1e..8e9a83d 100644
--- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
+++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
@@ -1,20 +1,28 @@
- *  Realmode interrupt call implementation.
+ * @file realmode_int.c
+ * @ingroup i386_shared
+ * @brief Real mode interrupt call implementation
 #include <bsp/realmode_int.h>
 #include <rtems/score/cpu.h>
+ * offsets to \a i386_realmode_interrupt_registers declared in realmode_int.h
+ * used in inline assmbler for better readability
 #define IR_EAX_OFF      "0x00"
 #define IR_EBX_OFF      "0x04"
 #define IR_ECX_OFF      "0x08"
@@ -26,25 +34,45 @@
 #define IR_FS_OFF       "0x1C"
 #define IR_GS_OFF       "0x1E"
+ * offsets to \a rm_int_regs_bkp_param
 #define BKP_ESP_OFF     "0x20"
 #define BKP_SS_OFF      "0x24"
 #define BKP_DS_OFF      "0x26"
 #define RM_ENTRY        "0x28"
 #define PM_ENTRY        "0x2C"
-/* parameters, results, backup values accessible in real mode */
+ * @brief parameters, results, backup values accessible in real mode
+ * @note Struct members not necessarily used in C. This serves also as
+ *       layout of memory and it is used within inline assembler.
 typedef struct {
     i386_realmode_interrupt_registers inoutregs;
+    /** spot for back up of protected mode stack pointer */
     uint32_t pm_esp_bkp;
+    /** spot for back up of protected mode stack selector */
     uint16_t pm_ss_bkp;
+    /** spot for back up of protected mode data selector */
     uint16_t ds_bkp;
+    /** spot for setting up long indirect jump offset
+        to real mode from 16bit protected mode */
     uint16_t rm_entry;
+    /** spot for setting up long indirect jump segment
     uint16_t rm_code_segment;
+    /** returning offset for long indirect jump back
+        to 32bit protected mode */
     uint32_t pm_entry;
+    /** returning selector for long indirect jump back
     uint16_t pm_code_selector;
-    /* if modifying update offset definitions as well */
+    /* if this struct is to be modified update offset definitions as well */
 } RTEMS_COMPILER_PACKED_ATTRIBUTE rm_int_regs_bkp_param;
+/* offsets to \a pm_bkp_and_param */
 #define BKP_IDTR_LIM    "0x00"
 #define BKP_IDTR_BASE   "0x02"
 #define BKP_ES_OFF      "0x06"
@@ -55,18 +83,35 @@ typedef struct {
 #define RM_SS           "0x14"
 #define RM_SP           "0x16"
 #define RM_DS           "0x18"
-/* backup values, pointers/parameters accessible in protected mode */
+ * @brief backup values, pointers/parameters accessible in protected mode
 typedef struct {
+    /** spot for backup protected mode interrupt descriptor table register */
     uint16_t idtr_lim_bkp;
+    /** @see idtr_lim_bkp */
     uint32_t idtr_base_bkp;
+    /** spot to backup of ES register value in 32bit protected mode */
     uint16_t es_bkp;
+    /** spot to backup of FS register value in 32bit protected mode */
     uint16_t fs_bkp;
+    /** spot to backup of GS register value in 32bit protected mode */
     uint16_t gs_bkp;
+    /** values for indirect jump to 16bit protected mode */
     uint32_t rml_entry;
+    /** @see rml_entry */
     uint16_t rml_code_selector;
+    /** data selector for 16bit protected mode */
     uint16_t rml_data_selector;
+    /** values determinig location of real mode stack */
     uint16_t rm_stack_segment;
+    /** @see rm_stack_segment */
     uint16_t rm_stack_pointer;
+    /** data segment for real mode */
     uint16_t rm_data_segment;
 } RTEMS_COMPILER_PACKED_ATTRIBUTE pm_bkp_and_param;
@@ -112,10 +157,14 @@ static __DP_TYPE descsPrepared = __DP_NO;
 static uint16_t rml_code_dsc_index = 0;
 static uint16_t rml_data_dsc_index = 0;
- * Prepares real-mode like descriptors to be used for switching
+ * @brief Prepares real-mode like descriptors to be used for switching
  * to real mode.
+ * Descriptors will be placed to the GDT.
+ * @param[in] base32 32-bit physical address to be used as base for 16-bit
+ *               protected mode descriptors
  * @retval __DP_YES descriptors are prepared
  * @retval __DP_FAIL descriptors allocation failed (GDT too small)
diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
index a0216ea..6f77ec9 100644
--- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
+++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
@@ -4,14 +4,14 @@
  * @brief Definitioins supporting real mode interrupt calls.
+ * Interface allows calling given interrupt number with content of the
+ * registers defined. For passing or receiving higher amounts of the data
+ * there is a buffer accessible from real mode available. Real mode pointer
+ * to this buffer is passed to the interrupt in the registers.
- *  Interface allows calling given interrupt number with content of the
- *  registers defined. For passing or receiving higher amounts of the data
- *  there is a buffer accessible from real mode available. Real mode pointer
- *  to this buffer is passed to the interrupt in the registers.
  *                     CTU in Prague.
@@ -36,7 +36,11 @@ extern "C" {
 /* number of interrupt servicing video functions */
 #define INTERRUPT_NO_VIDEO_SERVICES 0x10
-typedef struct { /* used for passing parameters, fetching results and preserving values */
+ * @brief Used for passing and retrieving registers content to/from real mode
+ * interrupt call.
+typedef struct {
     uint32_t reg_eax;
     uint32_t reg_ebx;
     uint32_t reg_ecx;
@@ -50,6 +54,8 @@ typedef struct { /* used for passing parameters, fetching results and preserving
 } RTEMS_COMPILER_PACKED_ATTRIBUTE i386_realmode_interrupt_registers;
+ * @brief Returns buffer and its size usable with real mode interrupt call.
  * Provides position to real mode buffer. It is buffer
  * accessible from real mode context - it is located below
  * address ~0x100000 in order for it to be accessible
@@ -57,22 +63,25 @@ typedef struct { /* used for passing parameters, fetching results and preserving
  * and through this get bigger portion of an information to/from
  * interrupt service routine than just by using register.
- * @param size pointer to variable, where the size of buffer
- *        will be filled
+ * @param[out] size pointer to variable, where the size of buffer
+ *             will be filled
  * @retval pointer to buffer
 extern void *i386_get_default_rm_buffer(uint16_t *size);
+ * @brief Call to real mode interrupt with specified int NO and processor
+ * registers.
  * This function allows calling interrupts in real mode and to set processor
  * registers as desired before interrupt call is made and to retrieve the
  * registers content after call was made.
- * @param interruptNumber interrupt number to be called
- * @param ir pointer to structure containing registers to be passed to interrupt
- *        and to retrieve register content after call was made.
+ * @param[in] interrupt_number interrupt number to be called
+ * @param[in] ir pointer to structure containing registers to be passed to
+ *            interrupt and to retrieve register content after call was made.
  * @retval  0 call failed (GDT too small or pagin is on)
- *          1 call successful
+ * @retval  1 call successful
 extern int i386_real_interrupt_call(
     uint8_t interrupt_number,
diff --git a/c/src/lib/libcpu/i386/cpu.h b/c/src/lib/libcpu/i386/cpu.h
index 23a82de..50234a6 100644
--- a/c/src/lib/libcpu/i386/cpu.h
+++ b/c/src/lib/libcpu/i386/cpu.h
@@ -1,5 +1,7 @@
- * cpu.h  - This file contains definitions for data structure related
+ * @file cpu.h
+ *          This file contains definitions for data structure related
  *          to Intel system programming. More information can be found
@@ -241,7 +243,9 @@ extern int i386_get_idt_config (rtems_raw_irq_global_settings** config);
  * See page 11.12 Figure 11-8.
+ * @brief segment_descriptors sturcture describes one entry of Descriptor Table
 typedef struct {
   unsigned int limit_15_0 		: 16;
   unsigned int base_address_15_0	: 16;
@@ -272,34 +276,36 @@ extern void i386_set_GDTR (segment_descriptors*,
                            uint16_t limit);
- * C callable function:
- * Puts global descriptor @sd to the global descriptor table on index
- * @segment_selector_index
+ * @brief Allows to set a GDT entry.
+ * Puts global descriptor \p sd to the global descriptor table on index
+ * \p segment_selector_index
+ * @param[in] segment_selector_index index to GDT entry
+ * @param[in] sd structure to be coppied to given \p segment_selector in GDT
  * @retval  0 FAILED out of GDT range or index is 0, which is not valid
  *                   index in GDT
- *          1 SUCCESS
+ * @retval  1 SUCCESS
 extern uint32_t i386_raw_gdt_entry (uint16_t segment_selector_index,
                                segment_descriptors* sd);
- * fills @sd with provided @base in appropriate fields of @sd
+ * @brief fills \p sd with provided \p base in appropriate fields of \p sd
  * @param base 32-bit address to be set as descriptor's base
- * @param sd descriptor being filled with @base
+ * @param sd descriptor being filled with \p base
 extern void i386_fill_segment_desc_base (uint32_t base,
- * fills @sd with provided @limit in appropriate fields of @sd
- * also influences granularity bit
+ * @brief fills \p sd with provided \p limit in appropriate fields of \p sd
+ * sets granularity bit if necessary
  * @param limit 32-bit value representing number of limit bytes
- * @param sd descriptor being filled with @limit
+ * @param sd descriptor being filled with \p limit
 extern void i386_fill_segment_desc_limit (uint32_t limit,
@@ -312,35 +318,36 @@ extern uint32_t i386_set_gdt_entry (uint16_t segment_selector,
                                     uint32_t limit);
- * C callable function returns next empty descriptor in GDT.
+ * @brief Returns next empty descriptor in GDT.
  * @retval  0 FAILED GDT is full
- *          <1;65535> segment_selector number as index to GDT
+ * @retval  <1;65535> segment_selector number as index to GDT
 extern uint16_t i386_next_empty_gdt_entry (void);
- * Copies GDT entry at index @segment_selector to structure
- * pointed to by @struct_to_fill
+ * @brief Copies GDT entry at index \p segment_selector to structure
+ * pointed to by \p struct_to_fill
  * @param  segment_selector index to GDT table for specifying descriptor to copy
+ * @param  struct_to_fill pointer to memory where should be descriptor coppied
  * @retval  0 FAILED segment_selector out of GDT range
- *          <1;65535> retrieved segment_selector
+ * @retval  <1;65535> retrieved segment_selector
 extern uint16_t i386_cpy_gdt_entry (uint16_t segment_selector,
                                     segment_descriptors* struct_to_fill);
- * Returns pointer to GDT table at index given by @segment_selector
+ * @brief Returns pointer to GDT table at index given by \p segment_selector
- * @param   segment_selector index to GDT table for specifying descriptor to get
+ * @param   sgmnt_selector index to GDT table for specifying descriptor to get
  * @retval  NULL FAILED segment_selector out of GDT range
- *          pointer to GDT table at @segment_selector
+ * @retval  pointer to GDT table at \p segment_selector
 extern segment_descriptors* i386_get_gdt_entry (uint16_t sgmnt_selector);
- * Extracts base address from GDT entry pointed to by @gdt_entry
+ * @brief Extracts base address from GDT entry pointed to by \p gdt_entry
  * @param  gdt_entry pointer to entry from which base should be retrieved
  * @retval base address from GDT entry
@@ -353,7 +360,7 @@ RTEMS_INLINE_ROUTINE void* i386_base_gdt_entry (segment_descriptors* gdt_entry)
- * Extracts limit in bytes from GDT entry pointed to by @gdt_entry
+ * @brief Extracts limit in bytes from GDT entry pointed to by \p gdt_entry
  * @param  gdt_entry pointer to entry from which limit should be retrieved
  * @retval limit value in bytes from GDT entry
diff --git a/cpukit/score/cpu/i386/cpu_asm.S b/cpukit/score/cpu/i386/cpu_asm.S
index f3ef4e2..45079a6 100644
--- a/cpukit/score/cpu/i386/cpu_asm.S
+++ b/cpukit/score/cpu/i386/cpu_asm.S
@@ -334,9 +334,9 @@ SYM (i386_Physical_to_logical):
  *     uint16_t *offset
- *  Fills segment:offest realmode pointer counted from thirty-two bit physical
+ *  Fills segment:offest real mode pointer counted from thirty-two bit physical
  *  address.
- *  Returns 0 if unconvertible, 1 if successfuly converted.
+ *  Returns 0 if inconvertible, 1 if successfuly converted.
 .set PHYS_PTR_ARG,   4
diff --git a/cpukit/score/cpu/i386/rtems/score/i386.h b/cpukit/score/cpu/i386/rtems/score/i386.h
index 926627d..875526a 100644
--- a/cpukit/score/cpu/i386/rtems/score/i386.h
+++ b/cpukit/score/cpu/i386/rtems/score/i386.h
@@ -185,10 +185,14 @@ void *i386_Physical_to_logical(
   void           *address
- *  i386_Real_to_physical
+ * @brief Converts real mode pointer {segment, offset} to physical address.
+ * i386_Real_to_physical
- *  Converts real mode pointer {segment, offset} to physical address.
+ * @param[in] segment used with \p offset to compute physical address
+ * @param[in] offset used with \p segment to compute physical address
+ * @retval    physical address
 RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
     uint16_t segment,
@@ -197,19 +201,24 @@ RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
     return (void *)(((uint32_t)segment<<4)+offset);
- *  i386_Physical_to_real
- *  Retreives real mode pointer elements {segmnet, offset} from physical address
- *  Function returns the highest segment (base) address possible.
- *  Example:    input   address - 0x4B3A2
- *              output  segment - 0x4B3A
- *                      offset  - 0x2
- *              input   address - 0x10F12E
- *              output  segment - 0xFFFF
- *                      offset  - 0xF13E
+ * @brief Retreives real mode pointer elements {segmnet, offset} from
+ * physical address.
+ * i386_Physical_to_real
+ * Function returns the highest segment (base) address possible.
+ * Example:    input   address - 0x4B3A2
+ *             output  segment - 0x4B3A
+ *                     offset  - 0x2
+ *             input   address - 0x10F12E
+ *             output  segment - 0xFFFF
+ *                     offset  - 0xF13E
- *  return  0 address not convertible, must be less than 0x10FFEF
- *          1 segment and offset extracted
+ * @param[in]  address address to be converted, must be less than 0x10FFEF
+ * @param[out] segment segment computed from \p address
+ * @param[out] offset offset computed from \p address
+ * @retval  0 address not convertible
+ * @retval  1 segment and offset extracted
 int i386_Physical_to_real(
   void *address,
1.9.1
