[PATCH 2/2] i386: doxygen and comments related to VESA real mode framebuffer
Tue Dec 2 23:59:50 UTC 2014
Sometimes params are identified as in our out, sometimes they are not.
Please be consistent. Generally patch looks OK, does the doxygen look
right when applied? [1] can help
-Gedare
[1] https://github.com/joelsherrill/gci_tasks/blob/master/2013/doxygen_c_header_tasks/validate/do_doxygen
On Tue, Dec 2, 2014 at 11:49 AM, Jan Dolezal <dolezj21 at fel.cvut.cz> wrote:
>  c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c   | 105 ++++---
>  c/src/lib/libbsp/i386/pc386/include/edid.h         |  14 +-
>  c/src/lib/libbsp/i386/pc386/include/fb_vesa.h      |  74 ++---
>  c/src/lib/libbsp/i386/pc386/include/tblsizes.h     |   1 -
>  c/src/lib/libbsp/i386/pc386/include/vbe3.h         | 311 ++++++++++++++-------
>  c/src/lib/libbsp/i386/pc386/startup/ldsegs.S       |   6 +-
>  c/src/lib/libbsp/i386/shared/irq/idt.c             |  10 +-
>  .../libbsp/i386/shared/realmode_int/realmode_int.c |  69 ++++-
>  .../libbsp/i386/shared/realmode_int/realmode_int.h |  33 ++-
>  c/src/lib/libcpu/i386/cpu.h                        |  53 ++--
>  cpukit/score/cpu/i386/cpu_asm.S                    |   4 +-
>  cpukit/score/cpu/i386/rtems/score/i386.h           |  39 ++-
>  12 files changed, 468 insertions(+), 251 deletions(-)
> diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
> index b7b27b6..fb9d575 100644
> --- a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
> +++ b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
> @@ -1,35 +1,39 @@
> - *  FB driver for graphic hardware compatible with VESA Bios Extension
> - *  Real mode interface utilized
> - *  Tested on real HW.
> + * @file fb_vesa_rm.c
> + * @ingroup i386_pc386
> + * @brief FB driver for graphic hardware compatible with VESA Bios Extension
> + *     Real mode interface utilized
> + *     Tested on real HW.
> - *  Copyright (c) 2014 - CTU in Prague
> - *                       Jan Doležal ( dolezj21 at fel.cvut.cz )
> + * Public sources related:
> + *   - VESA BIOS EXTENSION (VBE) Core Function Standard, Ver: 3.0, Sep 16, 1998
> + *   - VESA Enhanced Extended Display Identification Data (E-EDID) Standard
> + *     Release A, Revision 2, September 25, 2006
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> + * Hardware is completely initialized upon boot of the system.
> + * Therefore there is no way to change graphics mode later.
> - *  The code for rtems_buffer_* functions were greatly
> - *  inspired or coppied from:
> - *    - RTEMS fb_cirrus.c - Alexandru-Sever Horin (alex.sever.h at gmail.com)
> + * Interrupt 0x10 is used for entering graphics BIOS.
> - *  Public sources related:
> - *    - VESA BIOS EXTENSION (VBE) Core Function Standard, Ver: 3.0, Sep 16, 1998
> - *    - VESA Enhanced Extended Display Identification Data (E-EDID) Standard
> - *      Release A, Revision 2, September 25, 2006
> + * Driver reads parameter from multiboot command line to setup video:
> + * "--video=<resX>x<resY>[-<bpp>]"
> + * If cmdline parameter is not specified an attempt for obtaining
> + * resolution from display attached is made.
> - *  Hardware is completely initialized upon boot of the system.
> - *  Therefore there is no way to change graphics mode later.
> + * Copyright (c) 2014 - CTU in Prague
> + *                      Jan Doležal ( dolezj21 at fel.cvut.cz )
> - *  Interrupt 0x10 is used for entering graphics BIOS.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> - *  Driver reads parameter from multiboot command line to setup video:
> - *  "--video=<resX>x<resY>[-<bpp>]"
> - *  If cmdline parameter is not specified an attempt for obtaining
> - *  resolution from display attached is made.
> + * The code for rtems_buffer_* functions were greatly
> + * inspired or coppied from:
> + *   - RTEMS fb_cirrus.c - Alexandru-Sever Horin (alex.sever.h at gmail.com)
>  #include <bsp.h>
> @@ -48,6 +52,13 @@
>  #define FB_VESA_NAME    "FB_VESA_RM"
> + * @brief Initializes VBE framebuffer during bootup.
> + * utilizes switches to real mode interrupts and therefore must be
> + * called during bootup before tick is set up and real-time
> + * interrupt vectors utilized
>  void vesa_realmode_bootup_init(void);
>  /* mutex for protection against multiple opens, when called frame_buffer_open */
> @@ -187,19 +198,37 @@ inline uint32_t VBE_read_EDID(uint16_t controller_unit_number,
>      return (parret.reg_eax & 0xFFFF);
> + * @brief Basic graphic's mode parameters
>  typedef struct {
> +    /** number of the graphic's mode */
>      uint16_t mode_number;
> +    /** number of pixels in one line */
>      uint16_t resX;
> +    /** number of lines */
>      uint16_t resY;
> +    /** bits per pixel */
>      uint8_t bpp;
>  } Mode_params;
> -/* finds mode in 'modeList' of 'listLength' length according to resolution
> -    given in 'searchedResolution'. If bpp is given in that struct as well
> -    mode with such color depth and resolution is searched for. Otherwise bpp
> -    has to be zero. Mode number found is returned and also filled into
> -    'searchedResolution'. bpp is also filled into 'searchedResolution' if it
> -    was 0 before call. */
> + * @brief Find mode by resolution in the given list of modes
> + * finds mode in \p mode_list of \p list_length length according to resolution
> + * given in \p searched_resolution . If bpp is given in that struct as well
> + * mode with such color depth and resolution is searched for. Otherwise bpp
> + * has to be zero. Mode number found is returned and also filled into
> + * \p searched_resolution . bpp is also filled into \p searchedResolution if it
> + * was 0 before call.
> + * @param[in] mode_list list of modes to be searched
> + * @param[in] list_length number of modes in the list
> + * @param searched_resolution element filled with searched resolution or/and
> + *            bpp
> + * @retval mode number satisfying given parameters
> + * @retval -1 no suitable mode found
>  static uint16_t find_mode_by_resolution(   Mode_params *mode_list,
>                                          uint8_t list_length,
>                                          Mode_params *searched_resolution)
> @@ -223,14 +252,18 @@ static uint16_t find_mode_by_resolution(   Mode_params *mode_list,
>      return -1;
> - * Parse comandline option "--video=" if available.
> + * @brief Find mode given within command line.
> + * Parse command line option "--video=" if available.
>   *  expected format
>   *  --video=<resX>x<resY>[-<bpp>]
>   *  numbers <resX>, <resY> and <bpp> are decadic
>   * @retval video mode number to be set
> - *         -1 on parsing error or when no suitable mode found
> + * @retval -1 on parsing error or when no suitable mode found
>  static uint16_t find_mode_using_cmdline(Mode_params *mode_list,
>                                          uint8_t list_length)
> @@ -278,11 +311,13 @@ static uint16_t find_mode_using_cmdline(Mode_params *mode_list,
>      return -1;
> - * returns mode number best fitting to monitor attached
> + * @brief Find mode number best fitting to monitor attached
>  static uint16_t find_mode_using_EDID( Mode_params *mode_list,
> diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h b/c/src/lib/libbsp/i386/pc386/include/edid.h
> index 41bf1ca..16be6f6 100644
> --- a/c/src/lib/libbsp/i386/pc386/include/edid.h
> +++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
> @@ -4,16 +4,16 @@
>   * @brief VESA EDID definitions.
> + * This file contains definitions for constants related to
> + * VESA Extended Display Identification Data.
> + *         More information can be found at
> + *     <http://www.vesa.org/vesa-standards/free-standards/>
> + *         VESA public standards may be found at
> + *     <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
> - * edid.h  - This file contains definitions for constants related to
> - *           VESA Extended Display Identification Data.
> - *          More information can be found at
> - *      <http://www.vesa.org/vesa-standards/free-standards/>
> - *          VESA public standards may be found at
> - *      <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
>   * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
>   *                     CTU in Prague.
> diff --git a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
> index 88e7dd8..d03b070 100644
> --- a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
> +++ b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
> @@ -3,12 +3,10 @@
> - * @brief Definitioins for vesa based framebuffer drivers.
> + * @brief Headers specific for framebuffer drivers utilizing VESA VBE.
> - * Headers specific for framebuffer drivers utilizing VESA VBE.
>   *                     CTU in Prague.
> @@ -35,15 +33,16 @@ extern "C" {
>  /* ----- Prototypes ----- */
> - * Returns information about graphic's controller in the infoBlock structure.
> + * @brief Returns information about graphic's controller in the \p info_block
> + * structure.
> - * @param infoBlock pointer to the struct to be filled with
> -                    controller information
> - * @param queriedVBEVersion if >0x200 then video bios is asked to fill in
> + * @param info_block pointer to the struct to be filled with
> + *                  controller information
> + * @param queried_VBE_Version if >0x200 then video bios is asked to fill in
>   *                          parameters which appeared with second version
>   *                          of VBE.
> - * @retval  register ax content as defined in VBE RETURN STATUS paragraph
> - *          -1 error calling graphical bios
> + * @retval  ax register content as defined in VBE RETURN STATUS paragraph
> + * @retval  -1 error calling graphical bios
>  uint32_t VBE_controller_information (
>      VBE_VbeInfoBlock *info_block,
> @@ -51,13 +50,13 @@ uint32_t VBE_controller_information (
> - * Fills structure infoBlock with informations about selected mode in
> - * modeNumber variable.
> + * @brief Fills structure \p info_block with informations about selected mode in
> + * \p mode_number variable.
> - * @param infoBlock pointer to the struct to be filled with mode information
> - * @param modeNumber detailes of this mode to be filled
> + * @param info_block pointer to the struct to be filled with mode information
> + * @param mode_number detailes of this mode to be filled
>  uint32_t VBE_mode_information (
>      VBE_ModeInfoBlock *info_block,
> @@ -65,13 +64,13 @@ uint32_t VBE_mode_information (
> - * Sets graphics mode selected. If mode has refreshRateCtrl bit set, than the
> - * infoBlock must be filled accordingly.
> + * @brief Sets graphics mode selected. If mode has refreshRateCtrl bit set, than
> + * the \p info_block must be filled accordingly.
> - * @param modeNumber number of mode to be set
> - * @param infoBlock pointer to struct containing refresh rate control info
> + * @param mode_number number of mode to be set
> + * @param info_block pointer to struct containing refresh rate control info
>  uint32_t VBE_set_mode (
>      uint16_t mode_number,
> @@ -79,27 +78,27 @@ uint32_t VBE_set_mode (
> - * Get currently set mode number.
> + * @brief Get currently set mode number.
> - * @param modeNumber variable to be filled with current mode number
> + * @param mode_number variable to be filled with current mode number
>  uint32_t VBE_current_mode (
>      uint16_t *mode_number
> - * Gets information about display data channel implemented in the
> + * @brief Gets information about display data channel implemented in the
>   * graphic's controller.
> - * @param controllerUnitNumber
> - * @param secondsToTransferEDIDBlock approximate time to transfer one EDID block
> - *                                   rounded up to seconds
> - * @param DDCLevelSupported after call contains DDC version supported and
> + * @param controller_unit_number
> + * @param seconds_to_transfer_EDID_block approximate time to transfer one EDID
> + *                                       block rounded up to seconds
> + * @param DDC_level_supported after call contains DDC version supported and
>   *                          screen blanking state during transfer
>  uint32_t VBE_report_DDC_capabilities (
> @@ -108,13 +107,14 @@ uint32_t VBE_report_DDC_capabilities (
> - * Reads selected EDID block from display attached to controller's interface.
> + * @brief Reads selected EDID block from display attached to controller's
> + * interface.
> - * @param EDIDBlockNumber block no. to be read from the display
> + * @param EDID_block_number block no. to be read from the display
>   * @param buffer place to store block fetched from the display
>  uint32_t VBE_read_EDID (
> diff --git a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
> index 6128d87..bd4e989 100644
> --- a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
> +++ b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
> @@ -7,7 +7,6 @@
> - * Definitions related to the PC386 BSP.
>   * This header file is also used in assembler modules.
> diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
> index ba0ae3f..5aaa461 100644
> --- a/c/src/lib/libbsp/i386/pc386/include/vbe3.h
> +++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
> @@ -4,15 +4,15 @@
>   * @brief VESA Bios Extension definitions.
> + * This file contains definitions for constants related to VBE.
> - * vbe3.h  - This file contains definitions for constants related to VBE.
>   *                     CTU in Prague.
> @@ -156,22 +156,41 @@ extern "C" {
>  #define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
>                                          Specification Information */
>  /* *** Structures *** */
> + * @brief Far pointer as defined by VBE standard.
>  typedef struct {
> +    /** @brief Offset to segment described by \a selector. */
>      uint16_t offset;
> +    /** @brief Selector or Segment depending on whether this is used from 16bit
> +        protected mode or from real mode. */
>      uint16_t selector;
>  } VBE3_PACKED_ATTRIBUTE VBE_FarPtr;
> + * @brief Protected mode info block as defined by VBE standard.
>  typedef struct {
> -    uint8_t   Signature[4];    /*  PM Info Block Signature */
> -    uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS */
> -    uint16_t  PMInitialize;    /*  Offset of PM initialization entry point */
> -    uint16_t  BIOSDataSel;     /*  Selector to BIOS data area emulation block */
> -    uint16_t  A0000Sel;        /*  Selector to access A0000h physical mem */
> -    uint16_t  B0000Sel;        /*  Selector to access B0000h physical mem */
> -    uint16_t  B8000Sel;        /*  Selector to access B8000h physical mem */
> -    uint16_t  CodeSegSel;      /*  Selector to access code segment as data */
> -    uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
> -    uint8_t   Checksum;        /*  Checksum byte for structure */
> +    /** PM Info Block Signature */
> +    uint8_t   Signature[4];
> +    /** Offset of PM entry point within BIOS */
> +    uint16_t  EntryPoint;
> +    /** Offset of PM initialization entry point */
> +    uint16_t  PMInitialize;
> +    /** Selector to BIOS data area emulation block */
> +    uint16_t  BIOSDataSel;
> +    /** Selector to access A0000h physical memmory */
> +    uint16_t  A0000Sel;
> +    /** Selector to access B0000h physical memmory */
> +    uint16_t  B0000Sel;
> +    /** Selector to access B8000h physical memmory */
> +    uint16_t  B8000Sel;
> +    /** Selector to access code segment as data */
> +    uint16_t  CodeSegSel;
> +    /** Set to 1 when in protected mode */
> +    uint8_t   InProtectMode;
> +    /** Checksum byte for structure */
> +    uint8_t   Checksum;
>  } VBE3_PACKED_ATTRIBUTE VBE_PMInfoBlock;
>  /* General VBE signature */
> @@ -181,111 +200,201 @@ typedef struct {
>  /* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
>  #define VBE_END_OF_VideoModeList 0xFFFF
>  #define VBE_STUB_VideoModeList 0xFFFF
> + * @brief Information about VBE implementation.
>  typedef struct {
> -    uint8_t   VbeSignature[4];   /*  VBE Signature */
> -    uint16_t  VbeVersion;        /*  VBE Version */
> -    uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
> -    uint8_t   Capabilities[4];   /*  Capabilities of graphics controller */
> -    uint32_t *VideoModePtr;      /*  VbeFarPtr to VideoModeList */
> -    uint16_t  TotalMemory;       /*  Number of 64kb memory blocks    */
> +    /** VBE Signature */
> +    uint8_t   VbeSignature[4];
> +    /** VBE Version */
> +    uint16_t  VbeVersion;
> +    /** VbeFarPtr to OEM String */
> +    uint8_t  *OemStringPtr;
> +    /** Capabilities of graphics controller */
> +    uint8_t   Capabilities[4];
> +    /** VbeFarPtr to VideoModeList */
> +    uint32_t *VideoModePtr;
> +    /** Number of 64kb memory blocks    */
> +    uint16_t  TotalMemory;
>      /*  Added for VBE 2.0+ */
> -    uint16_t  OemSoftwareRev;    /*  VBE implementation Software revision */
> -    uint8_t  *OemVendorNamePtr;  /*  VbeFarPtr to Vendor Name String */
> -    uint8_t  *OemProductNamePtr; /*  VbeFarPtr to Product Name String */
> -    uint8_t  *OemProductRevPtr;  /*  VbeFarPtr to Product Revision String */
> -    uint8_t   Reserved[222];     /*  Reserved for VBE implementation scratch */
> -    /*    area */
> -    uint8_t   OemData[256];      /*  Data Area for OEM Strings */
> +    /** VBE implementation Software revision */
> +    uint16_t  OemSoftwareRev;
> +    /** VbeFarPtr to Vendor Name String */
> +    uint8_t  *OemVendorNamePtr;
> +    /** VbeFarPtr to Product Name String */
> +    uint8_t  *OemProductNamePtr;
> +    /** VbeFarPtr to Product Revision String */
> +    uint8_t  *OemProductRevPtr;
> +    /** Reserved for VBE implementation scratch */
> +    uint8_t   Reserved[222];
> +    /** Data Area for OEM Strings */
> +    uint8_t   OemData[256];
>  } VBE3_PACKED_ATTRIBUTE VBE_VbeInfoBlock;
> + * @brief Describes graphic's mode parameter.
>  typedef struct {
>      /*  Mandatory information for all VBE revisions */
> -    uint16_t  ModeAttributes;        /* mode attributes */
> -    uint8_t   WinAAttributes;        /* window A attributes */
> -    uint8_t   WinBAttributes;        /* window B attributes */
> -    uint16_t  WinGranularity;        /* window granularity */
> -    uint16_t  WinSize;               /* window size */
> -    uint16_t  WinASegment;           /* window A start segment */
> -    uint16_t  WinBSegment;           /* window B start segment */
> -    uint32_t *WinFuncPtr;            /* real mode pointer to window function */
> -    uint16_t  BytesPerScanLine;      /* bytes per scan line */
> +    /** mode attributes */
> +    uint16_t  ModeAttributes;
> +    /** window A attributes */
> +    uint8_t   WinAAttributes;
> +    /** window B attributes */
> +    uint8_t   WinBAttributes;
> +    /** window granularity */
> +    uint16_t  WinGranularity;
> +    /** window size */
> +    uint16_t  WinSize;
> +    /** window A start segment */
> +    uint16_t  WinASegment;
> +    /** window B start segment */
> +    uint16_t  WinBSegment;
> +    /** real mode pointer to window function */
> +    uint32_t *WinFuncPtr;
> +    /** bytes per scan line */
> +    uint16_t  BytesPerScanLine;
>      /*  Mandatory information for VBE 1.2 and above */
> -    uint16_t  XResolution;           /* horizontal resolution in px or chars */
> -    uint16_t  YResolution;           /* vertical resolution in px or chars */
> -    uint8_t   XCharSize;             /* character cell width in pixels */
> -    uint8_t   YCharSize;             /* character cell height in pixels */
> -    uint8_t   NumberOfPlanes;        /* number of memory planes */
> -    uint8_t   BitsPerPixel;          /* bits per pixel */
> -    uint8_t   NumberOfBanks;         /* number of banks */
> -    uint8_t   MemoryModel;           /* memory model type */
> -    uint8_t   BankSize;              /* bank size in KB */
> -    uint8_t   NumberOfImagePages;    /* number of images */
> -    uint8_t   Reserved0;             /* reserved for page function */
> +    /** horizontal resolution in px or chars */
> +    uint16_t  XResolution;
> +    /** vertical resolution in px or chars */
> +    uint16_t  YResolution;
> +    /** character cell width in pixels */
> +    uint8_t   XCharSize;
> +    /** character cell height in pixels */
> +    uint8_t   YCharSize;
> +    /** number of memory planes */
> +    uint8_t   NumberOfPlanes;
> +    uint8_t   BitsPerPixel;
> +    /** number of banks */
> +    uint8_t   NumberOfBanks;
> +    /** memory model type */
> +    uint8_t   MemoryModel;
> +    /** bank size in KB */
> +    uint8_t   BankSize;
> +    /** number of images */
> +    uint8_t   NumberOfImagePages;
> +    /** reserved for page function */
> +    uint8_t   Reserved0;
>      /*  Direct Color fields (required for direct/6 and YUV/7 memory models) */
> -    uint8_t   RedMaskSize;           /* size of direct color red mask in bits */
> -    uint8_t   RedFieldPosition;      /* bit position of lsb of red mask */
> -    uint8_t   GreenMaskSize;         /* size of direct color green mask in b */
> -    uint8_t   GreenFieldPosition;    /* bit position of lsb of green mask */
> -    uint8_t   BlueMaskSize;          /* size of direct color blue mask in b */
> -    uint8_t   BlueFieldPosition;     /* bit position of lsb of blue mask */
> -    uint8_t   RsvdMaskSize;          /* size of direct color reserved mask */
> -    uint8_t   RsvdFieldPosition;     /* bit position of lsb of reserved mask */
> -    uint8_t   DirectColorModeInfo;   /* direct color mode attributes */
> +    /** size of direct color red mask in bits */
> +    uint8_t   RedMaskSize;
> +    /** bit position of lsb of red mask */
> +    uint8_t   RedFieldPosition;
> +    /** size of direct color green mask in b */
> +    uint8_t   GreenMaskSize;
> +    /** bit position of lsb of green mask */
> +    uint8_t   GreenFieldPosition;
> +    /** size of direct color blue mask in b */
> +    uint8_t   BlueMaskSize;
> +    /** bit position of lsb of blue mask */
> +    uint8_t   BlueFieldPosition;
> +    /** size of direct color reserved mask */
> +    uint8_t   RsvdMaskSize;
> +    /** bit position of lsb of reserved mask */
> +    uint8_t   RsvdFieldPosition;
> +    /** direct color mode attributes */
> +    uint8_t   DirectColorModeInfo;
>      /*  Mandatory information for VBE 2.0 and above */
> -    uint32_t *PhysBasePtr;           /* physical address for
> -                                        flat memory frame buffer */
> -    uint32_t  Reserved1;             /* Reserved - always set to 0 */
> -    uint16_t  Reserved2;             /* Reserved - always set to 0 */
> +    /** physical address for flat memory frame buffer */
> +    uint32_t *PhysBasePtr;
> +    /** Reserved - always set to 0 */
> +    uint32_t  Reserved1;
> +    uint16_t  Reserved2;
>      /*  Mandatory information for VBE 3.0 and above */
> -    uint16_t  LinBytesPerScanLine;   /* bytes per scan line for linear modes */
> -    uint8_t   BnkNumberOfImagePages; /* number of images for banked modes */
> -    uint8_t   LinNumberOfImagePages; /* number of images for linear modes */
> +    /** bytes per scan line for linear modes */
> +    uint16_t  LinBytesPerScanLine;
> +    /** number of images for banked modes */
> +    uint8_t   BnkNumberOfImagePages;
> +    /** number of images for linear modes */
> +    uint8_t   LinNumberOfImagePages;
>          /* linear modes */
> -    uint8_t   LinRedMaskSize;        /* size of direct color red mask */
> -    uint8_t   LinRedFieldPosition;   /* bit position of lsb of red mask */
> -    uint8_t   LinGreenMaskSize;      /* size of direct color green mask  */
> -    uint8_t   LinGreenFieldPosition; /* bit position of lsb of green mask */
> -    uint8_t   LinBlueMaskSize;       /* size of direct color blue mask  */
> -    uint8_t   LinBlueFieldPosition;  /* bit position of lsb of blue mask */
> -    uint8_t   LinRsvdMaskSize;       /* size of direct color reserved mask */
> -    uint8_t   LinRsvdFieldPosition;  /* bit position of lsb of reserved mask */
> -    uint32_t  MaxPixelClock;         /* maximum pixel clock
> -                                        (in Hz) for graphics mode */
> -    uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
> +    /** size of direct color red mask */
> +    uint8_t   LinRedMaskSize;
> +    uint8_t   LinRedFieldPosition;
> +    /** size of direct color green mask  */
> +    uint8_t   LinGreenMaskSize;
> +    uint8_t   LinGreenFieldPosition;
> +    /** size of direct color blue mask  */
> +    uint8_t   LinBlueMaskSize;
> +    uint8_t   LinBlueFieldPosition;
> +    uint8_t   LinRsvdMaskSize;
> +    uint8_t   LinRsvdFieldPosition;
> +    /** maximum pixel clock (in Hz) for graphics mode */
> +    uint32_t  MaxPixelClock;
> +    /** remainder of ModeInfoBlock */
> +    uint8_t   Reserved3[189];
>  } VBE3_PACKED_ATTRIBUTE VBE_ModeInfoBlock;
> + * @brief Describes monitor synchronization.
>  typedef struct {
> -    uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
> -    uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels */
> -    uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
> -    uint16_t  VerticalTotal;         /* Vertical total in lines */
> -    uint16_t  VerticalSyncStart;     /* Vertical sync start in lines */
> -    uint16_t  VerticalSyncEnd;       /* Vertical sync end in lines */
> -    uint8_t   Flags;                 /* Flags (Interlaced, Double Scan etc) */
> -    uint32_t  PixelClock;            /* Pixel clock in units of Hz */
> -    uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz */
> -    uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
> +    /** Horizontal total in pixels */
> +    uint16_t  HorizontalTotal;
> +    /** Horizontal sync start in pixels */
> +    uint16_t  HorizontalSyncStart;
> +    /** Horizontal sync end in pixels */
> +    uint16_t  HorizontalSyncEnd;
> +    /** Vertical total in lines */
> +    uint16_t  VerticalTotal;
> +    /** Vertical sync start in lines */
> +    uint16_t  VerticalSyncStart;
> +    /** Vertical sync end in lines */
> +    uint16_t  VerticalSyncEnd;
> +    /** Flags (Interlaced, Double Scan etc) */
> +    uint8_t   Flags;
> +    /** Pixel clock in units of Hz */
> +    uint32_t  PixelClock;
> +    /** Refresh rate in units of 0.01 Hz */
> +    uint16_t  RefreshRate;
> +    uint8_t   Reserved[40];
>  } VBE3_PACKED_ATTRIBUTE VBE_CRTCInfoBlock;
> + * @brief Describes palette entry.
>  typedef struct {
> -    uint8_t   Blue;                  /* Blue channel value (6 or 8 bits) */
> -    uint8_t   Green;                 /* Green channel value (6 or 8 bits) */
> -    uint8_t   Red;                   /* Red channel value(6 or 8 bits) */
> -    uint8_t   Alignment;             /* DWORD alignment byte (unused) */
> +    /** Blue channel value (6 or 8 bits) */
> +    uint8_t   Blue;
> +    /** Green channel value (6 or 8 bits) */
> +    uint8_t   Green;
> +    /** Red channel value(6 or 8 bits) */
> +    uint8_t   Red;
> +    /** DWORD alignment byte (unused) */
> +    uint8_t   Alignment;
>  } VBE3_PACKED_ATTRIBUTE VBE_PaletteEntry;
> + * @brief Supplemental VBE info block.
>  typedef struct {
> -    uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
> -    uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
> -    uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported subfunctions */
> -    uint16_t  OemSoftwareRev;        /* OEM Software revision */
> -    uint8_t   Reserved[221];         /* Reserved for description
> -                                        strings and future */
> -    /*  expansion */
> +    /** Supplemental VBE Signature */
> +    uint8_t   SupVbeSignature[7];
> +    /** Supplemental VBE Version */
> +    uint16_t  SupVbeVersion;
> +    /** Bitfield of supported subfunctions */
> +    uint8_t   SupVbeSubFunc[8];
> +    /** OEM Software revision */
> +    /** Reserved for description strings and future expansion */
> +    uint8_t   Reserved[221];
>  } VBE3_PACKED_ATTRIBUTE VBE_SupVbeInfoBlock;
>  /* VbeInfoBlock Capabilities */
> diff --git a/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S b/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
> index 14cbb95..9d61caf 100644
> --- a/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
> +++ b/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
> @@ -200,7 +200,7 @@ SYM (_Global_descriptor_table):
>          PUBLIC(gdtdesc)
>  SYM(gdtdesc):
> -       .word (GDT_SIZE*8 - 1)
> +        .word (GDT_SIZE*8 - 1)
>         .long SYM (_Global_descriptor_table)
> @@ -210,7 +210,7 @@ SYM(gdtdesc):
>         PUBLIC(Interrupt_descriptor_table)
>  SYM(Interrupt_descriptor_table):
> -       .rept IDT_SIZE
> +        .rept IDT_SIZE
>         .word 0,0,0,0
>         .endr
> @@ -221,7 +221,7 @@ SYM(Interrupt_descriptor_table):
>         .p2align 4
>         PUBLIC(IDT_Descriptor)
>  SYM(IDT_Descriptor):
> -       .word  (IDT_SIZE*8 - 1)
> +        .word  (IDT_SIZE*8 - 1)
>         .long  SYM (Interrupt_descriptor_table)
>  END_DATA
> diff --git a/c/src/lib/libbsp/i386/shared/irq/idt.c b/c/src/lib/libbsp/i386/shared/irq/idt.c
> index fc9364e..ff7db36 100644
> --- a/c/src/lib/libbsp/i386/shared/irq/idt.c
> +++ b/c/src/lib/libbsp/i386/shared/irq/idt.c
> @@ -1,12 +1,12 @@
> - * cpu.c  - This file contains implementation of C function to
> + * idt.c  - This file contains implementation of C function to
>   *          instantiate IDT entries. More detailled information can be found
> - *         on Intel site and more precisely in the following book :
> + *          on Intel site and more precisely in the following book :
> - *             Pentium Processor family
> - *             Developper's Manual
> + *              Pentium Processor family
> + *              Developper's Manual
> - *             Volume 3 : Architecture and Programming Manual
> + *              Volume 3 : Architecture and Programming Manual
>   * Copyright (C) 1998  Eric Valette (valette at crf.canon.fr)
>   *                     Canon Centre Recherche France.
> diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
> index af5cf1e..8e9a83d 100644
> --- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
> +++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
> @@ -1,20 +1,28 @@
> - *  Realmode interrupt call implementation.
> + * @file realmode_int.c
> + * @ingroup i386_shared
> + * @brief Real mode interrupt call implementation
>  #include <bsp/realmode_int.h>
>  #include <string.h>
>  #include <rtems/score/cpu.h>
> + * offsets to \a i386_realmode_interrupt_registers declared in realmode_int.h
> + * used in inline assmbler for better readability
>  #define IR_EAX_OFF      "0x00"
>  #define IR_EBX_OFF      "0x04"
>  #define IR_ECX_OFF      "0x08"
> @@ -26,25 +34,45 @@
>  #define IR_FS_OFF       "0x1C"
>  #define IR_GS_OFF       "0x1E"
> + * offsets to \a rm_int_regs_bkp_param
>  #define BKP_ESP_OFF     "0x20"
>  #define BKP_SS_OFF      "0x24"
>  #define BKP_DS_OFF      "0x26"
>  #define RM_ENTRY        "0x28"
>  #define PM_ENTRY        "0x2C"
> -/* parameters, results, backup values accessible in real mode */
> + * @brief parameters, results, backup values accessible in real mode
> + * @note Struct members not necessarily used in C. This serves also as
> + *       layout of memory and it is used within inline assembler.
>  typedef struct {
>      i386_realmode_interrupt_registers inoutregs;
> +    /** spot for back up of protected mode stack pointer */
>      uint32_t pm_esp_bkp;
> +    /** spot for back up of protected mode stack selector */
>      uint16_t pm_ss_bkp;
> +    /** spot for back up of protected mode data selector */
>      uint16_t ds_bkp;
> +    /** spot for setting up long indirect jump offset
> +        to real mode from 16bit protected mode */
>      uint16_t rm_entry;
> +    /** spot for setting up long indirect jump segment
>      uint16_t rm_code_segment;
> +    /** returning offset for long indirect jump back
> +        to 32bit protected mode */
>      uint32_t pm_entry;
> +    /** returning selector for long indirect jump back
>      uint16_t pm_code_selector;
> -    /* if modifying update offset definitions as well */
> +    /* if this struct is to be modified update offset definitions as well */
>  } RTEMS_COMPILER_PACKED_ATTRIBUTE rm_int_regs_bkp_param;
> +/* offsets to \a pm_bkp_and_param */
>  #define BKP_IDTR_LIM    "0x00"
>  #define BKP_IDTR_BASE   "0x02"
>  #define BKP_ES_OFF      "0x06"
> @@ -55,18 +83,35 @@ typedef struct {
>  #define RM_SS           "0x14"
>  #define RM_SP           "0x16"
>  #define RM_DS           "0x18"
> -/* backup values, pointers/parameters accessible in protected mode */
> + * @brief backup values, pointers/parameters accessible in protected mode
>  typedef struct {
> +    /** spot for backup protected mode interrupt descriptor table register */
>      uint16_t idtr_lim_bkp;
> +    /** @see idtr_lim_bkp */
>      uint32_t idtr_base_bkp;
> +    /** spot to backup of ES register value in 32bit protected mode */
>      uint16_t es_bkp;
> +    /** spot to backup of FS register value in 32bit protected mode */
>      uint16_t fs_bkp;
> +    /** spot to backup of GS register value in 32bit protected mode */
>      uint16_t gs_bkp;
> +    /** values for indirect jump to 16bit protected mode */
>      uint32_t rml_entry;
> +    /** @see rml_entry */
>      uint16_t rml_code_selector;
> +    /** data selector for 16bit protected mode */
>      uint16_t rml_data_selector;
> +    /** values determinig location of real mode stack */
>      uint16_t rm_stack_segment;
> +    /** @see rm_stack_segment */
>      uint16_t rm_stack_pointer;
> +    /** data segment for real mode */
>      uint16_t rm_data_segment;
>  } RTEMS_COMPILER_PACKED_ATTRIBUTE pm_bkp_and_param;
> @@ -112,10 +157,14 @@ static __DP_TYPE descsPrepared = __DP_NO;
>  static uint16_t rml_code_dsc_index = 0;
>  static uint16_t rml_data_dsc_index = 0;
> - * Prepares real-mode like descriptors to be used for switching
> + * @brief Prepares real-mode like descriptors to be used for switching
>   * to real mode.
> + * Descriptors will be placed to the GDT.
> + * @param[in] base32 32-bit physical address to be used as base for 16-bit
> + *               protected mode descriptors
>   * @retval __DP_YES descriptors are prepared
>   * @retval __DP_FAIL descriptors allocation failed (GDT too small)
> diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
> index a0216ea..6f77ec9 100644
> --- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
> +++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
> @@ -4,14 +4,14 @@
>   * @brief Definitioins supporting real mode interrupt calls.
> + * Interface allows calling given interrupt number with content of the
> + * registers defined. For passing or receiving higher amounts of the data
> + * there is a buffer accessible from real mode available. Real mode pointer
> + * to this buffer is passed to the interrupt in the registers.
> - *  Interface allows calling given interrupt number with content of the
> - *  registers defined. For passing or receiving higher amounts of the data
> - *  there is a buffer accessible from real mode available. Real mode pointer
> - *  to this buffer is passed to the interrupt in the registers.
>   *                     CTU in Prague.
> @@ -36,7 +36,11 @@ extern "C" {
>  /* number of interrupt servicing video functions */
>  #define INTERRUPT_NO_VIDEO_SERVICES 0x10
> -typedef struct { /* used for passing parameters, fetching results and preserving values */
> + * @brief Used for passing and retrieving registers content to/from real mode
> + * interrupt call.
> +typedef struct {
>      uint32_t reg_eax;
>      uint32_t reg_ebx;
>      uint32_t reg_ecx;
> @@ -50,6 +54,8 @@ typedef struct { /* used for passing parameters, fetching results and preserving
>  } RTEMS_COMPILER_PACKED_ATTRIBUTE i386_realmode_interrupt_registers;
> + * @brief Returns buffer and its size usable with real mode interrupt call.
>   * Provides position to real mode buffer. It is buffer
>   * accessible from real mode context - it is located below
>   * address ~0x100000 in order for it to be accessible
> @@ -57,22 +63,25 @@ typedef struct { /* used for passing parameters, fetching results and preserving
>   * and through this get bigger portion of an information to/from
>   * interrupt service routine than just by using register.
> - * @param size pointer to variable, where the size of buffer
> - *        will be filled
> + * @param[out] size pointer to variable, where the size of buffer
> + *             will be filled
>   * @retval pointer to buffer
>  extern void *i386_get_default_rm_buffer(uint16_t *size);
> + * @brief Call to real mode interrupt with specified int NO and processor
> + * registers.
>   * This function allows calling interrupts in real mode and to set processor
>   * registers as desired before interrupt call is made and to retrieve the
>   * registers content after call was made.
> - * @param interruptNumber interrupt number to be called
> - * @param ir pointer to structure containing registers to be passed to interrupt
> - *        and to retrieve register content after call was made.
> + * @param[in] interrupt_number interrupt number to be called
> + * @param[in] ir pointer to structure containing registers to be passed to
> + *            interrupt and to retrieve register content after call was made.
>   * @retval  0 call failed (GDT too small or pagin is on)
> - *          1 call successful
> + * @retval  1 call successful
>  extern int i386_real_interrupt_call(
>      uint8_t interrupt_number,
> diff --git a/c/src/lib/libcpu/i386/cpu.h b/c/src/lib/libcpu/i386/cpu.h
> index 23a82de..50234a6 100644
> --- a/c/src/lib/libcpu/i386/cpu.h
> +++ b/c/src/lib/libcpu/i386/cpu.h
> @@ -1,5 +1,7 @@
> - * cpu.h  - This file contains definitions for data structure related
> + * @file cpu.h
> + *          This file contains definitions for data structure related
>   *          to Intel system programming. More information can be found
> @@ -241,7 +243,9 @@ extern int i386_get_idt_config (rtems_raw_irq_global_settings** config);
>   * See page 11.12 Figure 11-8.
> + * @brief segment_descriptors sturcture describes one entry of Descriptor Table
>  typedef struct {
>    unsigned int limit_15_0              : 16;
>    unsigned int base_address_15_0       : 16;
> @@ -272,34 +276,36 @@ extern void i386_set_GDTR (segment_descriptors*,
>                             uint16_t limit);
> - * C callable function:
> - * Puts global descriptor @sd to the global descriptor table on index
> - * @segment_selector_index
> + * @brief Allows to set a GDT entry.
> + * Puts global descriptor \p sd to the global descriptor table on index
> + * \p segment_selector_index
> + * @param[in] segment_selector_index index to GDT entry
> + * @param[in] sd structure to be coppied to given \p segment_selector in GDT
>   * @retval  0 FAILED out of GDT range or index is 0, which is not valid
>   *                   index in GDT
> - *          1 SUCCESS
> + * @retval  1 SUCCESS
>  extern uint32_t i386_raw_gdt_entry (uint16_t segment_selector_index,
>                                 segment_descriptors* sd);
> - * fills @sd with provided @base in appropriate fields of @sd
> + * @brief fills \p sd with provided \p base in appropriate fields of \p sd
>   * @param base 32-bit address to be set as descriptor's base
> - * @param sd descriptor being filled with @base
> + * @param sd descriptor being filled with \p base
>  extern void i386_fill_segment_desc_base (uint32_t base,
> - * fills @sd with provided @limit in appropriate fields of @sd
> - * also influences granularity bit
> + * @brief fills \p sd with provided \p limit in appropriate fields of \p sd
> + * sets granularity bit if necessary
>   * @param limit 32-bit value representing number of limit bytes
> - * @param sd descriptor being filled with @limit
> + * @param sd descriptor being filled with \p limit
>  extern void i386_fill_segment_desc_limit (uint32_t limit,
> @@ -312,35 +318,36 @@ extern uint32_t i386_set_gdt_entry (uint16_t segment_selector,
>                                      uint32_t limit);
> - * C callable function returns next empty descriptor in GDT.
> + * @brief Returns next empty descriptor in GDT.
>   * @retval  0 FAILED GDT is full
> - *          <1;65535> segment_selector number as index to GDT
> + * @retval  <1;65535> segment_selector number as index to GDT
>  extern uint16_t i386_next_empty_gdt_entry (void);
> - * Copies GDT entry at index @segment_selector to structure
> - * pointed to by @struct_to_fill
> + * @brief Copies GDT entry at index \p segment_selector to structure
> + * pointed to by \p struct_to_fill
>   * @param  segment_selector index to GDT table for specifying descriptor to copy
> + * @param  struct_to_fill pointer to memory where should be descriptor coppied
>   * @retval  0 FAILED segment_selector out of GDT range
> - *          <1;65535> retrieved segment_selector
> + * @retval  <1;65535> retrieved segment_selector
>  extern uint16_t i386_cpy_gdt_entry (uint16_t segment_selector,
>                                      segment_descriptors* struct_to_fill);
> - * Returns pointer to GDT table at index given by @segment_selector
> + * @brief Returns pointer to GDT table at index given by \p segment_selector
> - * @param   segment_selector index to GDT table for specifying descriptor to get
> + * @param   sgmnt_selector index to GDT table for specifying descriptor to get
>   * @retval  NULL FAILED segment_selector out of GDT range
> - *          pointer to GDT table at @segment_selector
> + * @retval  pointer to GDT table at \p segment_selector
>  extern segment_descriptors* i386_get_gdt_entry (uint16_t sgmnt_selector);
> - * Extracts base address from GDT entry pointed to by @gdt_entry
> + * @brief Extracts base address from GDT entry pointed to by \p gdt_entry
>   * @param  gdt_entry pointer to entry from which base should be retrieved
>   * @retval base address from GDT entry
> @@ -353,7 +360,7 @@ RTEMS_INLINE_ROUTINE void* i386_base_gdt_entry (segment_descriptors* gdt_entry)
> - * Extracts limit in bytes from GDT entry pointed to by @gdt_entry
> + * @brief Extracts limit in bytes from GDT entry pointed to by \p gdt_entry
>   * @param  gdt_entry pointer to entry from which limit should be retrieved
>   * @retval limit value in bytes from GDT entry
> diff --git a/cpukit/score/cpu/i386/cpu_asm.S b/cpukit/score/cpu/i386/cpu_asm.S
> index f3ef4e2..45079a6 100644
> --- a/cpukit/score/cpu/i386/cpu_asm.S
> +++ b/cpukit/score/cpu/i386/cpu_asm.S
> @@ -334,9 +334,9 @@ SYM (i386_Physical_to_logical):
>   *     uint16_t *offset
> - *  Fills segment:offest realmode pointer counted from thirty-two bit physical
> + *  Fills segment:offest real mode pointer counted from thirty-two bit physical
>   *  address.
> - *  Returns 0 if unconvertible, 1 if successfuly converted.
> + *  Returns 0 if inconvertible, 1 if successfuly converted.
>  .set PHYS_PTR_ARG,   4
> diff --git a/cpukit/score/cpu/i386/rtems/score/i386.h b/cpukit/score/cpu/i386/rtems/score/i386.h
> index 926627d..875526a 100644
> --- a/cpukit/score/cpu/i386/rtems/score/i386.h
> +++ b/cpukit/score/cpu/i386/rtems/score/i386.h
> @@ -185,10 +185,14 @@ void *i386_Physical_to_logical(
>    void           *address
> - *  i386_Real_to_physical
> + * @brief Converts real mode pointer {segment, offset} to physical address.
> + * i386_Real_to_physical
> - *  Converts real mode pointer {segment, offset} to physical address.
> + * @param[in] segment used with \p offset to compute physical address
> + * @param[in] offset used with \p segment to compute physical address
> + * @retval    physical address
>  RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
>      uint16_t segment,
> @@ -197,19 +201,24 @@ RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
>      return (void *)(((uint32_t)segment<<4)+offset);
> - *  i386_Physical_to_real
> - *  Retreives real mode pointer elements {segmnet, offset} from physical address
> - *  Function returns the highest segment (base) address possible.
> - *  Example:    input   address - 0x4B3A2
> - *              output  segment - 0x4B3A
> - *                      offset  - 0x2
> - *              input   address - 0x10F12E
> - *              output  segment - 0xFFFF
> - *                      offset  - 0xF13E
> + * @brief Retreives real mode pointer elements {segmnet, offset} from
> + * physical address.
> + * i386_Physical_to_real
> + * Function returns the highest segment (base) address possible.
> + * Example:    input   address - 0x4B3A2
> + *             output  segment - 0x4B3A
> + *                     offset  - 0x2
> + *             input   address - 0x10F12E
> + *             output  segment - 0xFFFF
> + *                     offset  - 0xF13E
> - *  return  0 address not convertible, must be less than 0x10FFEF
> - *          1 segment and offset extracted
> + * @param[in]  address address to be converted, must be less than 0x10FFEF
> + * @param[out] segment segment computed from \p address
> + * @param[out] offset offset computed from \p address
> + * @retval  0 address not convertible
> + * @retval  1 segment and offset extracted
>  int i386_Physical_to_real(
>    void *address,
> 1.9.1
> devel mailing list
> devel at rtems.org
