[PATCH v2] libmisc: More useful default configuration
Wed Dec 3 21:53:23 UTC 2014
On 3/12/2014 7:46 pm, Sebastian Huber wrote:
> The dummy.c is a de-facto default configuration so use unlimited objects
> and the stack checker.  This makes it easier for new RTEMS users which
> will likely use this file if they just work with the usual main()
> function as the application entry point.  Provide proper arguments for
> main() using the BSP command line.  Add spare user extensions and
> drivers.
I am still confused. Does this mean we have 2 pieces of code doing the
same thing ?
If this is to be the one 'main' reference we have when I think it needs
a name that suites. The current name dummy should go. Plus what happens
to the code in bspinit.c ?
