[PATCH v2] libmisc: More useful default configuration
Wed Dec 3 23:00:55 UTC 2014
On December 3, 2014 4:53:23 PM EST, Chris Johns <chrisj at rtems.org> wrote:
>On 3/12/2014 7:46 pm, Sebastian Huber wrote:
>> The dummy.c is a de-facto default configuration so use unlimited
>objects
>> and the stack checker.  This makes it easier for new RTEMS users
>which
>> will likely use this file if they just work with the usual main()
>> function as the application entry point.  Provide proper arguments
>for
>> main() using the BSP command line.  Add spare user extensions and
>> drivers.
>I am still confused. Does this mean we have 2 pieces of code doing the
>same thing ?
>If this is to be the one 'main' reference we have when I think it needs
>a name that suites. The current name dummy should go. Plus what happens
>to the code in bspinit.c ?
It should be in cpukit. Merge two into one and rename dummy.c
>Chris
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
--joel
