[PATCH v2] libmisc: More useful default configuration
Thu Dec 4 06:30:45 UTC 2014
On 04/12/14 00:00, Joel Sherrill wrote:
> On December 3, 2014 4:53:23 PM EST, Chris Johns<chrisj at rtems.org>  wrote:
>> >On 3/12/2014 7:46 pm, Sebastian Huber wrote:
>>> >>The dummy.c is a de-facto default configuration so use unlimited
>> >objects
>>> >>and the stack checker.  This makes it easier for new RTEMS users
>> >which
>>> >>will likely use this file if they just work with the usual main()
>>> >>function as the application entry point.  Provide proper arguments
>> >for
>>> >>main() using the BSP command line.  Add spare user extensions and
>>> >>drivers.
>> >I am still confused. Does this mean we have 2 pieces of code doing the
>> >same thing ?
>> >If this is to be the one 'main' reference we have when I think it needs
>> >a name that suites. The current name dummy should go. Plus what happens
>> >to the code in bspinit.c ?
> It should be in cpukit. Merge two into one and rename dummy.c
The bspinit.c only provides a Init() function that calls main().  It
doesn't provide a configuration.  If you look at the README file in the
dummy directory, then I am not sure if we should rename this file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
