RTEMS SMP configuration
Hesham Moustafa heshamelmatary at gmail.com
Fri Dec 5 20:09:12 UTC 2014
It seems like adding an entry for epiphany at aclocal/enable-smp.m4 is
not enough, I still get the same error, any hints?
On Fri, Dec 5, 2014 at 6:03 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> I had to add epiphany to the list RTEMS CPUs that support SMP at
> On Fri, Dec 5, 2014 at 5:06 PM, Hesham Moustafa
>> Hi,
>> Should I add anything other than --enable-smp at configuration line
>> and RTEMS_CHECK_SMP
>> AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
>> to bsp configure.ac file to make the building system collects SMP
>> files (e.g, smpimpl.h). I always get undefined reference to some SMP
>> functions like _SMP_Send_message although I am including
>> <rtems/score/smpimpl.h>
>> Thanks,
>> Hesham
