RTEMS SMP configuration
    Gedare Bloom
    gedare at rtems.org
    Fri Dec  5 20:36:51 UTC 2014
Look for where the undefined functions exist and see what guards in
the build system or the source code itself might be precluding them
from your build.
Make sure you re-bootstrap and re-configure a clean build, as old
files might cause problems.
-Gedare
On Fri, Dec 5, 2014 at 3:09 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> It seems like adding an entry for epiphany at aclocal/enable-smp.m4 is
> not enough, I still get the same error, any hints?
> On Fri, Dec 5, 2014 at 6:03 PM, Hesham Moustafa
>> I had to add epiphany to the list RTEMS CPUs that support SMP at
>> On Fri, Dec 5, 2014 at 5:06 PM, Hesham Moustafa
>>> Hi,
>>> Should I add anything other than --enable-smp at configuration line
>>> and RTEMS_CHECK_SMP
>>> AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
>>> to bsp configure.ac file to make the building system collects SMP
>>> files (e.g, smpimpl.h). I always get undefined reference to some SMP
>>> functions like _SMP_Send_message although I am including
>>> <rtems/score/smpimpl.h>
>>> Thanks,
>>> Hesham
> devel mailing list
> devel at rtems.org
