RTEMS SMP configuration
    Hesham Moustafa
    heshamelmatary at gmail.com
    Fri Dec  5 20:40:59 UTC 2014
On Fri, Dec 5, 2014 at 8:36 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Look for where the undefined functions exist and see what guards in
> the build system or the source code itself might be precluding them
> from your build.
Most of SMP files are guarded with HAS_SMP and RTEMS_SMP. I always run
boostrap -p and bootstrap after every change and configure/build
again.
> Make sure you re-bootstrap and re-configure a clean build, as old
> files might cause problems.
> -Gedare
> On Fri, Dec 5, 2014 at 3:09 PM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
>> It seems like adding an entry for epiphany at aclocal/enable-smp.m4 is
>> not enough, I still get the same error, any hints?
>> On Fri, Dec 5, 2014 at 6:03 PM, Hesham Moustafa
>>> I had to add epiphany to the list RTEMS CPUs that support SMP at
>>> On Fri, Dec 5, 2014 at 5:06 PM, Hesham Moustafa
>>>> Hi,
>>>> Should I add anything other than --enable-smp at configuration line
>>>> and RTEMS_CHECK_SMP
>>>> AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
>>>> to bsp configure.ac file to make the building system collects SMP
>>>> files (e.g, smpimpl.h). I always get undefined reference to some SMP
>>>> functions like _SMP_Send_message although I am including
>>>> <rtems/score/smpimpl.h>
>>>> Thanks,
>>>> Hesham
>> devel mailing list
>> devel at rtems.org
