[PATCH 3/9] sb: Do not report current date
Tue Dec 9 00:06:50 UTC 2014
On December 8, 2014 6:00:06 PM CST, Peter Dufault <dufault at hda.com> wrote:
>I don't understand what drives this, maybe Sebastian can comment.
>I agree with Chris that requiring a documented "grep -v" in an expected
>output script would assist in reproducibility and process validation.
>I also agree with Sebastian that "cmp" returning that files are
>identical is very reassuring.
A blind cmp doesn't let the report include host, date, tool versions, etc.
>> On Dec 8, 2014, at 16:42 , Chris Johns <chrisj at rtems.org> wrote:
>> On 9/12/2014 8:07 am, Gedare Bloom wrote:
>>> On Mon, Dec 8, 2014 at 3:52 PM, Chris Johns <chrisj at rtems.org>
>wrote:
>>>> On 8/12/2014 5:48 pm, Sebastian Huber wrote:
>>>>> This makes the report reproducible.
>>>> I think the report should include a date. I do not see any
>advantage having
>>>> reproducible reports. The report captures the specific instance of
>the
>>>> build.
>>> Would it make sense to re-build on a different date and want to
>>> compare the results to see there is no difference?
>> What you build on a different date cannot be the same by definition.
>> The date has changed. In a quality context if you reference the first
>> build that is what you have. You cannot reference an initial build
>and
>> then say you used a subsequent build because you know it is the same.
>> Where is the dated report to say they are same ? The report is about
>> reporting what you did and what happened.
>>> Maybe a flag can be turned on/off for "reproducible" builds.
>> I do not like flags being available for things like this. The user
>then
>> needs to audit the setting and this moves the compliance back up to
>the
>> user.
>>> Or is it the user's
>>> responsibility to strip out such non-reproducible bits if they want
>>> such a feature?
>> I can understand an MD5 hash on the components built and that result
>> being in a report. I have never tried to see if a repeat build of the
>> tools produces an exact binary image.
>> I can also understand a user explicitly adding an exemption to an
>audit
>> process not to check the report. For example it is common to see
>target
>> binary images have exemptions for date and time strings embedded in
>them
>> and a manual audit with a hex dump to verify this is the only
>difference.
>> Chris
>> devel mailing list
>> devel at rtems.org
>Peter
>Peter Dufault
>HD Associates, Inc.      Software and System Engineering
>devel mailing list
>devel at rtems.org
--joel
