[PATCH 3/9] sb: Do not report current date
Peter Dufault dufault at hda.com
Tue Dec 9 00:20:01 UTC 2014
I know, and, here's my example of why I think we need the equivalent of "grep -v" to get rid of dates, machine name, etc, and why I think Chris is right in this case.  Until Sebastian explains otherwise.
At some clients I've been putting the development tool chain into clearcase "views" so that when you set your view to a given release you access the development tools appropriate to that release.  However, though the binaries are the exact binaries used to develop the release, the patch release you build will use those binaries executing under a newer operating system.   And I'd like to know and explicitly ignore that.
Yes, you could also save the total OS and run it in a virtual machine, and I'm sure there are others that do that.
> On Dec 8, 2014, at 19:06 , Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> A blind cmp doesn't let the report include host, date, tool versions, etc.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
