[PATCH 3/9] sb: Do not report current date
Tue Dec 9 07:00:53 UTC 2014
On 08/12/14 21:52, Chris Johns wrote:
> On 8/12/2014 5:48 pm, Sebastian Huber wrote:
>> This makes the report reproducible.
> I think the report should include a date. I do not see any advantage
> having reproducible reports. The report captures the specific instance
> of the build.
Yes, it captures a specific instance of the build, but why should the
date be part of it?  What can you do with this date?
My goal is to get rid of anything that is host dependent, e.g. the home
directory path.
If you really want the date, then I omit this patch.  For XML report
however I would like to omit the date nonetheless.
> The purpose behind the report is to have an output from the process
> that can feed into a QA audit type process. Part of the purpose of the
> RTEMS tools is to create an RTEMS Ecosystem and this is about pushing
> down into RTEMS report generation for these parts of process so users
> can feed them up into their configuration management system.
My intention to use this report is to add it eventually to the RTEMS
sources to that you can determine the tool chain that can build exactly
this RTEMS version.  Since the RSB commit is included in the report, you
can use the RSB in the best case to build the tools.  In the worst case
the report should contain everything that is necessary to build it manually.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
