[PATCH 1/2] doc: Clarify rtems_task_set_priority()
Sebastian Huber
Fri Dec 12 14:04:38 UTC 2014
doc/user/task.t | 3 +++
1 file changed, 3 insertions(+)
diff --git a/doc/user/task.t b/doc/user/task.t
index a172a0c..cf7a514 100644
--- a/doc/user/task.t
+++ b/doc/user/task.t
@@ -1291,6 +1291,9 @@ The calling task may be preempted if its preemption mode is
enabled and it lowers its own priority or raises another task's
priority.
+In case the new priority equals the current priority of the task, then nothing
+happens.
Setting the priority of a global task which does not reside on
the local node will generate a request to the remote node to
change the priority of the specified task.
1.8.4.5
