[PATCH] Add GPIO, I2C and SPI support for the RPi BSP
Tue Dec 16 09:38:04 UTC 2014
Hello Alan,
On 15/12/14 21:19, Alan Cudmore wrote:
> Is the ARM Zync BSP using the new i2c API?
yes, see file cadence-i2c.c and the functions mentioned by Chris.
> I was looking through the BSP and did not see how it is initialized.
> Also, the current libi2c supports SPI. Does anyone see a problem with
> using libi2c for SPI and the new i2c API for i2c?
I think we need also something similar for SPI which is also message
based, e.g.
struct spi_msg {
     uint16_t chip_select;
     uint16_t len;
     uint32_t bit_rate;
     uint32_t flags;
     const uint8_t *out;
     uint8_t *in;
This makes it easier to support sophisticated SPI modules like the
Freescale DSPI.
> Finally, will new i2c drivers go in libchip, or in cpukit/dev ?
The I2C device drivers (devices connected via the I2C bus) should go
into cpukit/dev and should have a test case in testsuites/libtests/i2c01.
The I2C bud drivers should be as general as possible.  Unfortunately we
don't have a bus space abstraction yet, so I still placed the first I2C
bus driver into the BSP.  This is not the right location in the long run.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
