[PATCH] Add GPIO, I2C and SPI support for the RPi BSP
Alan Cudmore alan.cudmore at gmail.com
Tue Dec 16 21:43:20 UTC 2014
Thanks Sebastian and Chris ,
I will look at converting the Pi I2C code to this new interface.
What Zync boards does RTEMS run on? Will it run on the Micro Zed?
Finally, do we have a target for 4.11?  I probably will not get any
serious development time for another week or so.
Thanks,
Alan
On 12/16/2014 4:38 AM, Sebastian Huber wrote:
> Hello Alan,
> On 15/12/14 21:19, Alan Cudmore wrote:
>> Is the ARM Zync BSP using the new i2c API?
> yes, see file cadence-i2c.c and the functions mentioned by Chris.
>> I was looking through the BSP and did not see how it is initialized.
>> Also, the current libi2c supports SPI. Does anyone see a problem with
>> using libi2c for SPI and the new i2c API for i2c?
> I think we need also something similar for SPI which is also message
> based, e.g.
> struct spi_msg {
>     uint16_t chip_select;
>     uint16_t len;
>     uint32_t bit_rate;
>     uint32_t flags;
>     const uint8_t *out;
>     uint8_t *in;
> This makes it easier to support sophisticated SPI modules like the
> Freescale DSPI.
>> Finally, will new i2c drivers go in libchip, or in cpukit/dev ?
> The I2C device drivers (devices connected via the I2C bus) should go
> into cpukit/dev and should have a test case in testsuites/libtests/i2c01.
> The I2C bud drivers should be as general as possible. Unfortunately we
> don't have a bus space abstraction yet, so I still placed the first
> I2C bus driver into the BSP.  This is not the right location in the
> long run.
