[PATCH] rtems: Add rtems_status_code_description()
Sebastian Huber
Wed Feb 5 16:25:46 UTC 2014
cpukit/rtems/Makefile.am | 1 +
cpukit/rtems/include/rtems/rtems/status.h | 10 +++
cpukit/rtems/src/statusdesc.c | 69 ++++++++++++++++++++
doc/user/Makefile.am | 11 ++-
doc/user/dirstat.t | 64 ++++++++++++++++++
doc/user/dirstat.texi | 37 -----------
doc/user/example.texi | 2 +-
testsuites/sptests/spinternalerror02/init.c | 21 ++++++-
.../spinternalerror02/spinternalerror02.scn | 31 +++++++++
9 files changed, 203 insertions(+), 43 deletions(-)
create mode 100644 cpukit/rtems/src/statusdesc.c
create mode 100644 doc/user/dirstat.t
delete mode 100644 doc/user/dirstat.texi
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index fd5af5a..f219db8 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -255,6 +255,7 @@ librtems_a_SOURCES += src/workspacegreedy.c
librtems_a_SOURCES += src/modes.c
librtems_a_SOURCES += src/status.c
+librtems_a_SOURCES += src/statusdesc.c
if HAS_MP
# We only build multiprocessing related files if HAS_MP was defined
diff --git a/cpukit/rtems/include/rtems/rtems/status.h b/cpukit/rtems/include/rtems/rtems/status.h
index 8904288..19df500 100644
--- a/cpukit/rtems/include/rtems/rtems/status.h
+++ b/cpukit/rtems/include/rtems/rtems/status.h
@@ -241,6 +241,16 @@ RTEMS_INLINE_ROUTINE bool rtems_are_statuses_equal(
int rtems_status_code_to_errno(rtems_status_code sc);
+ * @brief Returns a description for a status code.
+ * @param[in] code The status code.
+ * @retval description The status code description.
+ * @retval ? The passed status code is invalid.
+const char *rtems_status_code_description( rtems_status_code code );
#ifdef __cplusplus
diff --git a/cpukit/rtems/src/statusdesc.c b/cpukit/rtems/src/statusdesc.c
new file mode 100644
index 0000000..4cc426d
--- /dev/null
+++ b/cpukit/rtems/src/statusdesc.c
@@ -0,0 +1,69 @@
+ * @file
+ * @ingroup ClassicStatus
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems.h>
+static const char *const status_code_desc[] = {
+ "RTEMS_SUCCESSFUL",
+ "RTEMS_TASK_EXITTED",
+ "RTEMS_MP_NOT_CONFIGURED",
+ "RTEMS_INVALID_NAME",
+ "RTEMS_INVALID_ID",
+ "RTEMS_TOO_MANY",
+ "RTEMS_TIMEOUT",
+ "RTEMS_OBJECT_WAS_DELETED",
+ "RTEMS_INVALID_SIZE",
+ "RTEMS_INVALID_ADDRESS",
+ "RTEMS_INVALID_NUMBER",
+ "RTEMS_NOT_DEFINED",
+ "RTEMS_RESOURCE_IN_USE",
+ "RTEMS_UNSATISFIED",
+ "RTEMS_INCORRECT_STATE",
+ "RTEMS_ALREADY_SUSPENDED",
+ "RTEMS_ILLEGAL_ON_SELF",
+ "RTEMS_ILLEGAL_ON_REMOTE_OBJECT",
+ "RTEMS_CALLED_FROM_ISR",
+ "RTEMS_INVALID_PRIORITY",
+ "RTEMS_INVALID_CLOCK",
+ "RTEMS_INVALID_NODE",
+ "RTEMS_NOT_CONFIGURED",
+ "RTEMS_NOT_OWNER_OF_RESOURCE",
+ "RTEMS_NOT_IMPLEMENTED",
+ "RTEMS_INTERNAL_ERROR",
+ "RTEMS_NO_MEMORY",
+ "RTEMS_IO_ERROR",
+ "RTEMS_PROXY_BLOCKING"
+ size_t i = code;
+ const char *desc = "?";
+ if ( i < RTEMS_ARRAY_SIZE( status_code_desc ) ) {
+ desc = status_code_desc [i];
+ return desc;
diff --git a/doc/user/Makefile.am b/doc/user/Makefile.am
index 7992b29..1b6ddcb 100644
--- a/doc/user/Makefile.am
+++ b/doc/user/Makefile.am
@@ -8,14 +8,14 @@ PROJECT = c_user
include $(top_srcdir)/project.am
include $(top_srcdir)/main.am
-FILES = bsp.texi dirstat.texi example.texi glossary.texi preface.texi
+FILES = bsp.texi example.texi glossary.texi preface.texi
GENERATED_FILES = overview.texi concepts.texi datatypes.texi init.texi \
task.texi intr.texi clock.texi timer.texi sem.texi msg.texi event.texi \
signal.texi part.texi region.texi dpmem.texi io.texi fatal.texi \
schedule.texi rtmon.texi barrier.texi bsp.texi userext.texi conf.texi \
mp.texi stackchk.texi cpuuse.texi object.texi chains.texi timespec.texi \
- cbs.texi
+ cbs.texi dirstat.texi
COMMON_FILES += $(top_srcdir)/common/cpright.texi
@@ -193,10 +193,15 @@ cbs.texi: cbs.t
-u "Top" \
-n "Directive Status Codes" < $< > $@
+dirstat.texi: dirstat.t
+ $(BMENU2) -p "Constant Bandwidth Server Scheduler API CBS_GET_APPROVED_BUDGET - Get scheduler approved execution time" \
+ -u "Top" \
+ -n "Example Application" < $< > $@
EXTRA_DIST = bsp.t cbs.t clock.t chains.t concepts.t cpuuse.t datatypes.t conf.t \
dpmem.t event.t fatal.t init.t intr.t io.t mp.t msg.t overview.t \
part.t region.t rtmon.t sem.t schedule.t signal.t stackchk.t \
- task.t timer.t userext.t $(TXT_FILES) $(PNG_FILES) $(EPS_IMAGES) \
+ task.t timer.t userext.t dirstat.t $(TXT_FILES) $(PNG_FILES) $(EPS_IMAGES) \
$(noinst_DATA)
CLEANFILES += c_user.info c_user.info-? c_user.info-??
diff --git a/doc/user/dirstat.t b/doc/user/dirstat.t
index 0000000..adb675d
--- /dev/null
+++ b/doc/user/dirstat.t
@@ -0,0 +1,64 @@
+ at c
+ at c COPYRIGHT (c) 1989-2011.
+ at c On-Line Applications Research Corporation (OAR).
+ at c All rights reserved.
+ at chapter Directive Status Codes
+ at section Introduction
+ at table @b
+ at item @code{@value{RPREFIX}SUCCESSFUL} - successful completion
+ at item @code{@value{RPREFIX}TASK_EXITTED} - returned from a task
+ at item @code{@value{RPREFIX}MP_NOT_CONFIGURED} - multiprocessing not configured
+ at item @code{@value{RPREFIX}INVALID_NAME} - invalid object name
+ at item @code{@value{RPREFIX}INVALID_ID} - invalid object id
+ at item @code{@value{RPREFIX}TOO_MANY} - too many
+ at item @code{@value{RPREFIX}TIMEOUT} - timed out waiting
+ at item @code{@value{RPREFIX}OBJECT_WAS_DELETED} - object was deleted while waiting
+ at item @code{@value{RPREFIX}INVALID_SIZE} - invalid specified size
+ at item @code{@value{RPREFIX}INVALID_ADDRESS} - invalid address specified
+ at item @code{@value{RPREFIX}INVALID_NUMBER} - number was invalid
+ at item @code{@value{RPREFIX}NOT_DEFINED} - item not initialized
+ at item @code{@value{RPREFIX}RESOURCE_IN_USE} - resources outstanding
+ at item @code{@value{RPREFIX}UNSATISFIED} - request not satisfied
+ at item @code{@value{RPREFIX}INCORRECT_STATE} - task is in wrong state
+ at item @code{@value{RPREFIX}ALREADY_SUSPENDED} - task already in state
+ at item @code{@value{RPREFIX}ILLEGAL_ON_SELF} - illegal for calling task
+ at item @code{@value{RPREFIX}ILLEGAL_ON_REMOTE_OBJECT} - illegal for remote object
+ at item @code{@value{RPREFIX}CALLED_FROM_ISR} - invalid environment
+ at item @code{@value{RPREFIX}INVALID_PRIORITY} - invalid task priority
+ at item @code{@value{RPREFIX}INVALID_CLOCK} - invalid time buffer
+ at item @code{@value{RPREFIX}INVALID_NODE} - invalid node id
+ at item @code{@value{RPREFIX}NOT_CONFIGURED} - directive not configured
+ at item @code{@value{RPREFIX}NOT_OWNER_OF_RESOURCE} - not owner of resource
+ at item @code{@value{RPREFIX}NOT_IMPLEMENTED} - directive not implemented
+ at item @code{@value{RPREFIX}INTERNAL_ERROR} - RTEMS inconsistency detected
+ at item @code{@value{RPREFIX}NO_MEMORY} - could not get enough memory
+ at end table
+ at section Directives
+ at page
+ at subsection STATUS_CODE_DESCRIPTION - Returns a description for a status code
+ at cindex fatal error
+ at subheading CALLING SEQUENCE:
+ at ifset is-C
+ at findex rtems_status_code_description
+ at example
+ rtems_status_code code
+ at end example
+ at end ifset
+ at subheading DIRECTIVE STATUS CODES
+The status code description or "?" in case the passed status code is invalid.
+ at subheading DESCRIPTION:
+Returns a description for a status code.
diff --git a/doc/user/dirstat.texi b/doc/user/dirstat.texi
deleted file mode 100644
index 17a7edd..0000000
--- a/doc/user/dirstat.texi
+++ /dev/null
@@ -1,37 +0,0 @@
- at c
- at c COPYRIGHT (c) 1989-2011.
- at c On-Line Applications Research Corporation (OAR).
- at c All rights reserved.
- at node Directive Status Codes, Example Application, Constant Bandwidth Server Scheduler API CBS_GET_APPROVED_BUDGET - Get scheduler approved execution time, Top
- at chapter Directive Status Codes
- at table @b
- at item @code{@value{RPREFIX}SUCCESSFUL} - successful completion
- at item @code{@value{RPREFIX}TASK_EXITTED} - returned from a task
- at item @code{@value{RPREFIX}MP_NOT_CONFIGURED} - multiprocessing not configured
- at item @code{@value{RPREFIX}INVALID_NAME} - invalid object name
- at item @code{@value{RPREFIX}INVALID_ID} - invalid object id
- at item @code{@value{RPREFIX}TOO_MANY} - too many
- at item @code{@value{RPREFIX}TIMEOUT} - timed out waiting
- at item @code{@value{RPREFIX}OBJECT_WAS_DELETED} - object was deleted while waiting
- at item @code{@value{RPREFIX}INVALID_SIZE} - invalid specified size
- at item @code{@value{RPREFIX}INVALID_ADDRESS} - invalid address specified
- at item @code{@value{RPREFIX}INVALID_NUMBER} - number was invalid
- at item @code{@value{RPREFIX}NOT_DEFINED} - item not initialized
- at item @code{@value{RPREFIX}RESOURCE_IN_USE} - resources outstanding
- at item @code{@value{RPREFIX}UNSATISFIED} - request not satisfied
- at item @code{@value{RPREFIX}INCORRECT_STATE} - task is in wrong state
- at item @code{@value{RPREFIX}ALREADY_SUSPENDED} - task already in state
- at item @code{@value{RPREFIX}ILLEGAL_ON_SELF} - illegal for calling task
- at item @code{@value{RPREFIX}ILLEGAL_ON_REMOTE_OBJECT} - illegal for remote object
- at item @code{@value{RPREFIX}CALLED_FROM_ISR} - invalid environment
- at item @code{@value{RPREFIX}INVALID_PRIORITY} - invalid task priority
- at item @code{@value{RPREFIX}INVALID_CLOCK} - invalid time buffer
- at item @code{@value{RPREFIX}INVALID_NODE} - invalid node id
- at item @code{@value{RPREFIX}NOT_CONFIGURED} - directive not configured
- at item @code{@value{RPREFIX}NOT_OWNER_OF_RESOURCE} - not owner of resource
- at item @code{@value{RPREFIX}NOT_IMPLEMENTED} - directive not implemented
- at item @code{@value{RPREFIX}INTERNAL_ERROR} - RTEMS inconsistency detected
- at item @code{@value{RPREFIX}NO_MEMORY} - could not get enough memory
- at end table
diff --git a/doc/user/example.texi b/doc/user/example.texi
index f95868e..71a71ab 100644
--- a/doc/user/example.texi
+++ b/doc/user/example.texi
@@ -3,7 +3,7 @@
@c On-Line Applications Research Corporation (OAR).
@c All rights reserved.
- at node Example Application, Glossary, Directive Status Codes, Top
+ at node Example Application, Glossary, Directive Status Codes STATUS_CODE_DESCRIPTION - Returns a description for a status code, Top
@chapter Example Application
@example
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 4b89e6c..b08a7d4 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -1,8 +1,8 @@
- * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2012-2014 embedded brains GmbH. All rights reserved.
- * Obere Lagerstr. 30
+ * Donierstr. 4
* 82178 Puchheim
* Germany
@@ -52,12 +52,29 @@ static void test_fatal_source_description(void)
rtems_test_assert( source - 3 == RTEMS_FATAL_SOURCE_EXCEPTION );
+static void test_status_code_description(void)
+ rtems_status_code code = 0;
+ const char *desc = NULL;
+ const char *desc_last;
+ do {
+ desc_last = desc;
+ desc = rtems_status_code_description( code );
+ ++code;
+ puts( desc );
+ } while ( desc != desc_last );
+ rtems_test_assert( code - 3 == RTEMS_PROXY_BLOCKING );
static void Init(rtems_task_argument arg)
puts("\n\n*** TEST SPINTERNALERROR 2 ***");
test_internal_error_description();
test_fatal_source_description();
+ test_status_code_description();
puts("*** END OF TEST SPINTERNALERROR 2 ***");
diff --git a/testsuites/sptests/spinternalerror02/spinternalerror02.scn b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
index 9d7a722..65fd425 100644
--- a/testsuites/sptests/spinternalerror02/spinternalerror02.scn
+++ b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
@@ -39,4 +39,35 @@ RTEMS_FATAL_SOURCE_STACK_CHECKER
+RTEMS_SUCCESSFUL
+RTEMS_TASK_EXITTED
+RTEMS_MP_NOT_CONFIGURED
+RTEMS_INVALID_NAME
+RTEMS_INVALID_ID
+RTEMS_TOO_MANY
+RTEMS_TIMEOUT
+RTEMS_OBJECT_WAS_DELETED
+RTEMS_INVALID_SIZE
+RTEMS_INVALID_ADDRESS
+RTEMS_INVALID_NUMBER
+RTEMS_NOT_DEFINED
+RTEMS_RESOURCE_IN_USE
+RTEMS_UNSATISFIED
+RTEMS_INCORRECT_STATE
+RTEMS_ALREADY_SUSPENDED
+RTEMS_ILLEGAL_ON_SELF
+RTEMS_ILLEGAL_ON_REMOTE_OBJECT
+RTEMS_CALLED_FROM_ISR
+RTEMS_INVALID_PRIORITY
+RTEMS_INVALID_CLOCK
+RTEMS_INVALID_NODE
+RTEMS_NOT_CONFIGURED
+RTEMS_NOT_OWNER_OF_RESOURCE
+RTEMS_NOT_IMPLEMENTED
+RTEMS_INTERNAL_ERROR
+RTEMS_NO_MEMORY
+RTEMS_IO_ERROR
+RTEMS_PROXY_BLOCKING
1.7.7
