[PATCH] New fstest to check rename POSIX conformance
Andre Marques
andre.lousa.marques at gmail.com
Sat Feb 8 12:26:22 UTC 2014
Hi,
As discussed in [1], I created a new fstest to check the rename()
implementation against the POSIX specification [2].
What the attached patch does not test:
- Testing the existance of a link visible to other processes during the
rename process (ensuring that there is always a reference to the file).
Not sure about the best way to test this.
- Testing that after all processes close their references to a file
after it was removed by rename() the file contents are removed (or
marked as free space, I guess). I only found platform dependent ways of
dealing with disk block's.
- Testing errno values in error situations. There is already a fstest
named fserror which purpose seems to be checking errno values for a
bunch of functions (rename included, but with some errno values
missing). Not sure if I should put them in this test or add to fserror.
This test uses the MOUNTED IMFS filesystem, for no particular reason, so
if that's an issue please let me know.
[1] - http://www.rtems.org/pipermail/rtems-users/2014-January/012378.html
[2] - http://pubs.opengroup.org/onlinepubs/9699919799/functions/rename.html
--André Marques
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140208/20ae7275/attachment.bin>
