[PATCH] New fstest to check rename POSIX conformance
Sebastian Huber
Mon Feb 10 08:14:13 UTC 2014
Hello Andre,
thanks for the test case.
On 2014-02-08 13:26, Andre Marques wrote:
> Hi,
> As discussed in [1], I created a new fstest to check the rename()
> implementation against the POSIX specification [2].
> What the attached patch does not test:
> - Testing the existance of a link visible to other processes during the rename
> process (ensuring that there is always a reference to the file). Not sure about
> the best way to test this.
The file system instance is locked during the rename operation, so other
threads cannot interfere here.
What happens if you rename a file with an open file descriptor should be tested.
> - Testing that after all processes close their references to a file after it
> was removed by rename() the file contents are removed (or marked as free space,
> I guess). I only found platform dependent ways of dealing with disk block's.
Maybe you can use the statvfs() function for this.
> - Testing errno values in error situations. There is already a fstest named
> fserror which purpose seems to be checking errno values for a bunch of
> functions (rename included, but with some errno values missing). Not sure if I
> should put them in this test or add to fserror.
I would move all rename related tests to this new test program.
> This test uses the MOUNTED IMFS filesystem, for no particular reason, so if
> that's an issue please let me know.
> [1] - http://www.rtems.org/pipermail/rtems-users/2014-January/012378.html
> [2] - http://pubs.opengroup.org/onlinepubs/9699919799/functions/rename.html
> --André Marques
> 0001-New-fstest-to-check-rename-POSIX-conformance.patch
>>From fe91c9c1072112c5d191a231da0ef4c04159dce6 Mon Sep 17 00:00:00 2001
> From: Andre Marques<andre.lousa.marques at gmail.com>
> Date: Sat, 8 Feb 2014 11:40:49 +0000
> Subject: [PATCH] New fstest to check rename POSIX conformance
> testsuites/fstests/Makefile.am | 1 +
> testsuites/fstests/configure.ac | 1 +
> testsuites/fstests/fsrename/fsrename.doc | 19 +
> testsuites/fstests/fsrename/fsrename.scn | 166 +++++
> testsuites/fstests/fsrename/test.c | 788 +++++++++++++++++++++
> testsuites/fstests/mimfs_fsrename/Makefile.am | 31 +
> .../fstests/mimfs_fsrename/mimfs_fsrename.scn | 174 +++++
> 7 files changed, 1180 insertions(+)
> create mode 100644 testsuites/fstests/fsrename/fsrename.doc
> create mode 100644 testsuites/fstests/fsrename/fsrename.scn
> create mode 100644 testsuites/fstests/fsrename/test.c
> create mode 100644 testsuites/fstests/mimfs_fsrename/Makefile.am
> create mode 100644 testsuites/fstests/mimfs_fsrename/mimfs_fsrename.scn
> diff --git a/testsuites/fstests/fsrename/test.c b/testsuites/fstests/fsrename/test.c
> new file mode 100644
> index 0000000..c133476
> --- /dev/null
> +++ b/testsuites/fstests/fsrename/test.c
> @@ -0,0 +1,788 @@
> + * COPYRIGHT (c) 2014 - .
> + * Andre Marques<andre.lousa.marques at gmail.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + *http://www.rtems.com/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <sys/stat.h>
> +#include <fcntl.h>
> +#include <stdio.h>
> +#include <string.h>
> +#include <unistd.h>
> +#include "fstest.h"
> +#include "pmacros.h"
> +static void symbolic_link_test (void)
> + uint32_t fd;
> + uint32_t status;
Should be int instead of uint32_t.
> + char *name01 = "name01";
> + char *name02 = "name02";
> + char *symlink01 = "slink01";
Should be "const char *".
> + unlink (name01);
Please check the return value of all functions.
> + unlink (name02);
> + unlink (symlink01);
> + * The new argument points to a symbolic link to another file and
> + * the old argument points to a file.
> + puts("\nNew is a simbolic link and rename operates on the simbolic link itself\n");
> + fd = creat (name01, mode);
assert(fd >= 0);
> + status = close (fd);
> + rtems_test_assert (status == 0);
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
