Status of phycore_mpc5554 with latest RTEMS
Peter Dufault dufault at hda.com
Fri Feb 14 14:51:36 UTC 2014
On Feb 14, 2014, at 09:46 , Peter Dufault <dufault at hda.com> wrote:
> I'm running on real hardware.  I didn't think the simulators supported the SPE (Signal Processing Extension) instructions, but I might be wrong, I just googled it and found this for QEMU for 2007:
> Log message:
>        PowerPC 2.03 SPE extension - first pass.
> It won't help with my code, but maybe I can try running the tests with QEMU.  If anyone has QEMU and is familiar with it you can check and see how complete the support seems to be.
It doesn't look good.  A little more googling and I found this.  The MPC5554 uses the e500 processor core.
https://github.com/qemu/qemu/blob/master/target-ppc/STATUS
PowerPC e500: (not implemented)
INSN  KO
SPR   KO
MSR   KO
IRQ   KO
MMU   KO
EXCP  KO
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
