[PATCH] bsps: Add cache empty manager
Sebastian Huber
Fri Feb 21 16:14:59 UTC 2014
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
c/src/lib/libbsp/arm/csb336/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/csb337/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/edb7312/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/gba/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/gdbarmsim/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/gp32/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/gumstix/Makefile.am | 6 ++++++
c/src/lib/libbsp/arm/nds/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/rtl22xx/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/smdk2410/Makefile.am | 5 +++++
c/src/lib/libbsp/avr/avrtest/Makefile.am | 5 +++++
c/src/lib/libbsp/h8300/h8sim/Makefile.am | 5 +++++
c/src/lib/libbsp/lm32/lm32_evr/Makefile.am | 5 +++++
c/src/lib/libbsp/lm32/milkymist/Makefile.am | 5 +++++
c/src/lib/libbsp/m32c/m32cbsp/Makefile.am | 5 +++++
c/src/lib/libbsp/m32r/m32rsim/Makefile.am | 5 +++++
c/src/lib/libbsp/m68k/csb360/Makefile.am | 1 +
c/src/lib/libbsp/powerpc/ss555/Makefile.am | 1 +
c/src/lib/libbsp/shared/include/cache_.h | 1 +
c/src/lib/libbsp/v850/gdbv850sim/Makefile.am | 5 +++++
20 files changed, 89 insertions(+), 0 deletions(-)
create mode 100644 c/src/lib/libbsp/shared/include/cache_.h
diff --git a/c/src/lib/libbsp/arm/csb336/Makefile.am b/c/src/lib/libbsp/arm/csb336/Makefile.am
index 6de07c7..e254cef 100644
--- a/c/src/lib/libbsp/arm/csb336/Makefile.am
+++ b/c/src/lib/libbsp/arm/csb336/Makefile.am
@@ -49,6 +49,11 @@ libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
libbsp_a_SOURCES += ../../shared/src/irq-server.c
libbsp_a_SOURCES += ../../shared/src/irq-shell.c
+# Cache
+libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
+libbsp_a_SOURCES += ../../shared/include/cache_.h
+libbsp_a_CPPFLAGS = -I$(srcdir)/../../shared/include
if HAS_NETWORKING
network_CPPFLAGS = -D__INSIDE_RTEMS_BSD_TCPIP_STACK__
noinst_PROGRAMS += network.rel
diff --git a/c/src/lib/libbsp/arm/csb337/Makefile.am b/c/src/lib/libbsp/arm/csb337/Makefile.am
index 90d3a2a..75aa4f3 100644
--- a/c/src/lib/libbsp/arm/csb337/Makefile.am
+++ b/c/src/lib/libbsp/arm/csb337/Makefile.am
@@ -86,6 +86,11 @@ if ENABLE_UMON_CONSOLE
libbsp_a_SOURCES += ../../shared/umon/umoncons.c
endif
+# Cache
if HAS_NETWORKING
diff --git a/c/src/lib/libbsp/arm/edb7312/Makefile.am b/c/src/lib/libbsp/arm/edb7312/Makefile.am
index 63df39f..35d9c77 100644
--- a/c/src/lib/libbsp/arm/edb7312/Makefile.am
+++ b/c/src/lib/libbsp/arm/edb7312/Makefile.am
@@ -63,6 +63,11 @@ libbsp_a_SOURCES += ../../shared/src/irq-shell.c
libbsp_a_SOURCES += irq/irq.c
libbsp_a_SOURCES += irq/bsp_irq_asm.S
+# Cache
if HAS_NETWORKING
diff --git a/c/src/lib/libbsp/arm/gba/Makefile.am b/c/src/lib/libbsp/arm/gba/Makefile.am
index dbb656d..6fc022f 100644
--- a/c/src/lib/libbsp/arm/gba/Makefile.am
+++ b/c/src/lib/libbsp/arm/gba/Makefile.am
@@ -61,5 +61,10 @@ libbsp_a_SOURCES += ../../shared/src/irq-server.c
+# Cache
include $(srcdir)/preinstall.am
include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
index 8a351a2..1d91864 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
+++ b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
@@ -44,6 +44,11 @@ libbsp_a_SOURCES += ../../shared/timerstub.c
# above
libbsp_a_SOURCES += ../shared/abort/abort.c
+# Cache
#libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/arm920.rel \
# ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/clock.rel \
# ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/timer.rel \
diff --git a/c/src/lib/libbsp/arm/gp32/Makefile.am b/c/src/lib/libbsp/arm/gp32/Makefile.am
index 72a41c6..fecb3d7 100644
--- a/c/src/lib/libbsp/arm/gp32/Makefile.am
+++ b/c/src/lib/libbsp/arm/gp32/Makefile.am
@@ -54,6 +54,11 @@ libbsp_a_SOURCES += ../shared/abort/abort.c
# smc
libbsp_a_SOURCES += smc/smc.c smc/smc.h
+# Cache
../../../libcpu/@RTEMS_CPU@/s3c24xx/clock.rel \
../../../libcpu/@RTEMS_CPU@/s3c24xx/timer.rel \
diff --git a/c/src/lib/libbsp/arm/gumstix/Makefile.am b/c/src/lib/libbsp/arm/gumstix/Makefile.am
index e55e80c..cca6948 100644
--- a/c/src/lib/libbsp/arm/gumstix/Makefile.am
+++ b/c/src/lib/libbsp/arm/gumstix/Makefile.am
@@ -51,6 +51,12 @@ libbsp_a_SOURCES += ../../shared/src/irq-server.c
#abort
+# Cache
#framebuffer
if ON_SKYEYE
libbsp_a_SOURCES += fb/fb.c
diff --git a/c/src/lib/libbsp/arm/nds/Makefile.am b/c/src/lib/libbsp/arm/nds/Makefile.am
index 2f83aa3..76bab01 100644
--- a/c/src/lib/libbsp/arm/nds/Makefile.am
+++ b/c/src/lib/libbsp/arm/nds/Makefile.am
@@ -255,6 +255,11 @@ coproc.bin: coproc/coproc.S coproc/coproc.c libnds7.rel
endif
project_lib_DATA += coproc.bin
+# Cache
libbsp_a_LIBADD = clock.rel console.rel gnatsupp.rel startup.rel irq.rel \
timer.rel libnds9.rel rtc.rel fb.rel touchscreen.rel sound.rel \
block.rel libdldi.rel
diff --git a/c/src/lib/libbsp/arm/rtl22xx/Makefile.am b/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
index 1c156fa..dd6faf5 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
@@ -56,6 +56,11 @@ libbsp_a_SOURCES += ../shared/abort/simple_abort.c
# debugio
libbsp_a_SOURCES += console/uart.c
+# Cache
if HAS_NETWORKING
diff --git a/c/src/lib/libbsp/arm/smdk2410/Makefile.am b/c/src/lib/libbsp/arm/smdk2410/Makefile.am
index 24b070c..21a3501 100644
--- a/c/src/lib/libbsp/arm/smdk2410/Makefile.am
+++ b/c/src/lib/libbsp/arm/smdk2410/Makefile.am
@@ -55,6 +55,11 @@ libbsp_a_SOURCES += ../shared/abort/abort.c
# smc
libbsp_a_SOURCES += ../gp32/smc/smc.c ../gp32/smc/smc.h
+# Cache
diff --git a/c/src/lib/libbsp/avr/avrtest/Makefile.am b/c/src/lib/libbsp/avr/avrtest/Makefile.am
index ec14b7d..51f3fd4 100644
--- a/c/src/lib/libbsp/avr/avrtest/Makefile.am
+++ b/c/src/lib/libbsp/avr/avrtest/Makefile.am
@@ -37,5 +37,10 @@ noinst_LIBRARIES = libbsp.a
libbsp_a_SOURCES = $(startup_SOURCES) $(clock_SOURCES) $(console_SOURCES) \
$(timer_SOURCES)
+# Cache
diff --git a/c/src/lib/libbsp/h8300/h8sim/Makefile.am b/c/src/lib/libbsp/h8300/h8sim/Makefile.am
index 70016a4..147b93d 100644
--- a/c/src/lib/libbsp/h8300/h8sim/Makefile.am
+++ b/c/src/lib/libbsp/h8300/h8sim/Makefile.am
@@ -39,5 +39,10 @@ libbsp_a_SOURCES += ../../shared/console-polled.c console/console-io.c \
# timer
+# Cache
diff --git a/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am b/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
index d792226..616ea14 100644
--- a/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
+++ b/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
@@ -42,6 +42,11 @@ libbsp_a_SOURCES += ../../lm32/shared/console/console.c ../../lm32/shared/consol
# timer
libbsp_a_SOURCES += ../../lm32/shared/timer/timer.c
+# Cache
if HAS_NETWORKING
network_rel_SOURCES = ../../lm32/shared/tsmac/tsmac.c
diff --git a/c/src/lib/libbsp/lm32/milkymist/Makefile.am b/c/src/lib/libbsp/lm32/milkymist/Makefile.am
index 0a48fb3..6ddc641 100644
--- a/c/src/lib/libbsp/lm32/milkymist/Makefile.am
+++ b/c/src/lib/libbsp/lm32/milkymist/Makefile.am
@@ -110,6 +110,11 @@ libbsp_a_SOURCES += ../../lm32/shared/milkymist_video/video.c
# versions
libbsp_a_SOURCES += ../../lm32/shared/milkymist_versions/versions.c
+# Cache
if HAS_NETWORKING
network_rel_SOURCES = ../../lm32/shared/milkymist_networking/network.c
diff --git a/c/src/lib/libbsp/m32c/m32cbsp/Makefile.am b/c/src/lib/libbsp/m32c/m32cbsp/Makefile.am
index b3fe1b3..1378979 100644
--- a/c/src/lib/libbsp/m32c/m32cbsp/Makefile.am
+++ b/c/src/lib/libbsp/m32c/m32cbsp/Makefile.am
@@ -38,5 +38,10 @@ noinst_LIBRARIES = libbsp.a
$(timer_SOURCES)
+# Cache
diff --git a/c/src/lib/libbsp/m32r/m32rsim/Makefile.am b/c/src/lib/libbsp/m32r/m32rsim/Makefile.am
index d360747..7fca9f5 100644
--- a/c/src/lib/libbsp/m32r/m32rsim/Makefile.am
+++ b/c/src/lib/libbsp/m32r/m32rsim/Makefile.am
$(timer_SOURCES)
+# Cache
diff --git a/c/src/lib/libbsp/m68k/csb360/Makefile.am b/c/src/lib/libbsp/m68k/csb360/Makefile.am
index ca2047b..a8afbb1 100644
--- a/c/src/lib/libbsp/m68k/csb360/Makefile.am
+++ b/c/src/lib/libbsp/m68k/csb360/Makefile.am
@@ -37,6 +37,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
libbsp_a_SOURCES += console/console-io.c ../../shared/console-polled.c
libbsp_a_LIBADD = \
+ ../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
../../../libcpu/@RTEMS_CPU@/shared/misc.rel \
../../../libcpu/@RTEMS_CPU@/mcf5272/clock.rel \
../../../libcpu/@RTEMS_CPU@/mcf5272/timer.rel
diff --git a/c/src/lib/libbsp/powerpc/ss555/Makefile.am b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
index ac23b9c..0cb21da 100644
--- a/c/src/lib/libbsp/powerpc/ss555/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
@@ -38,6 +38,7 @@ libbsp_a_SOURCES += startup/tm27supp.c
libbsp_a_LIBADD = \
../../../libcpu/@RTEMS_CPU@/shared/cpuIdent.rel \
../../../libcpu/@RTEMS_CPU@/@exceptions@/rtems-cpu.rel \
../../../libcpu/@RTEMS_CPU@/mpc5xx/clock.rel \
../../../libcpu/@RTEMS_CPU@/mpc5xx/console-generic.rel \
diff --git a/c/src/lib/libbsp/shared/include/cache_.h b/c/src/lib/libbsp/shared/include/cache_.h
new file mode 100644
index 0000000..710cecc
--- /dev/null
+++ b/c/src/lib/libbsp/shared/include/cache_.h
@@ -0,0 +1 @@
+/* Empty */
diff --git a/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am b/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
index e7e4c49..8e648c8 100644
--- a/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
+++ b/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
@@ -47,6 +47,11 @@ libbsp_a_SOURCES += ../../shared/console-polled.c
+# Cache
1.7.7
