[PATCH v2] score: Add and use _Giant_Drop()
Sebastian Huber
Fri Feb 21 09:38:19 UTC 2014
New test smptests/smpfatal03.
cpukit/score/include/rtems/score/threaddispatch.h | 12 ++
cpukit/score/src/smp.c | 8 +
cpukit/score/src/threaddispatchdisablelevel.c | 13 ++
testsuites/smptests/Makefile.am | 1 +
testsuites/smptests/configure.ac | 1 +
testsuites/smptests/smpfatal03/Makefile.am | 19 +++
testsuites/smptests/smpfatal03/init.c | 142 +++++++++++++++++++++
testsuites/smptests/smpfatal03/smpfatal03.doc | 12 ++
testsuites/smptests/smpfatal03/smpfatal03.scn | 2 +
9 files changed, 210 insertions(+), 0 deletions(-)
create mode 100644 testsuites/smptests/smpfatal03/Makefile.am
create mode 100644 testsuites/smptests/smpfatal03/init.c
create mode 100644 testsuites/smptests/smpfatal03/smpfatal03.doc
create mode 100644 testsuites/smptests/smpfatal03/smpfatal03.scn
diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
index 2211662..cf9b801 100644
--- a/cpukit/score/include/rtems/score/threaddispatch.h
+++ b/cpukit/score/include/rtems/score/threaddispatch.h
@@ -109,6 +109,18 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization( void )
void _Giant_Release( void );
+ * @brief Releases the giant lock completely if held by the executing processor.
+ * The thread dispatch disable level is not altered by this function.
+ * The only use case for this operation is in
+ * _SMP_Request_shutdown().
+ * @param[in] self_cpu The current processor index.
+ void _Giant_Drop( uint32_t self_cpu );
* @brief Sets thread dispatch level to the value passed in.
* This routine sets thread dispatch level to the
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 0f63223..e56073d 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -73,6 +73,14 @@ void _SMP_Request_shutdown( void )
Per_CPU_Control *self_cpu = _Per_CPU_Get_by_index( self );
_Per_CPU_State_change( self_cpu, PER_CPU_STATE_SHUTDOWN );
+ * We have to drop the Giant lock here in order to give other processors the
+ * opportunity to receive the inter-processor interrupts issued previously.
+ * In case the executing thread still holds SMP locks, then other processors
+ * already waiting for this SMP lock will spin forever.
+ _Giant_Drop( self );
void _SMP_Send_message( uint32_t cpu, uint32_t message )
diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
index a3dec99..ec5ac81 100644
--- a/cpukit/score/src/threaddispatchdisablelevel.c
+++ b/cpukit/score/src/threaddispatchdisablelevel.c
@@ -57,6 +57,19 @@ static void _Giant_Do_release( void )
+void _Giant_Drop( uint32_t self_cpu )
+ Giant_Control *giant = &_Giant;
+ _Assert( _ISR_Get_level() != 0 );
+ if ( giant->owner_cpu == self_cpu ) {
+ giant->nest_level = 0;
+ giant->owner_cpu = NO_OWNER_CPU;
+ _SMP_lock_Release( &giant->lock );
uint32_t _Thread_Dispatch_increment_disable_level( void )
ISR_Level isr_level;
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 8422f3a..b15bad5 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -13,6 +13,7 @@ SUBDIRS += smp09
SUBDIRS += smpatomic01
SUBDIRS += smpfatal01
SUBDIRS += smpfatal02
+SUBDIRS += smpfatal03
SUBDIRS += smplock01
SUBDIRS += smpmigration01
SUBDIRS += smpschedule01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 19e32f3..95d082b 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -67,6 +67,7 @@ smp09/Makefile
smpatomic01/Makefile
smpfatal01/Makefile
smpfatal02/Makefile
+smpfatal03/Makefile
smplock01/Makefile
smpmigration01/Makefile
smppsxsignal01/Makefile
diff --git a/testsuites/smptests/smpfatal03/Makefile.am b/testsuites/smptests/smpfatal03/Makefile.am
new file mode 100644
index 0000000..4ec2862
--- /dev/null
+++ b/testsuites/smptests/smpfatal03/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpfatal03
+smpfatal03_SOURCES = init.c
+dist_rtems_tests_DATA = smpfatal03.scn smpfatal03.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpfatal03_OBJECTS)
+LINK_LIBS = $(smpfatal03_LDLIBS)
+smpfatal03$(EXEEXT): $(smpfatal03_OBJECTS) $(smpfatal03_DEPENDENCIES)
+ @rm -f smpfatal03$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpfatal03/init.c b/testsuites/smptests/smpfatal03/init.c
index 0000000..3e5ebe2
--- /dev/null
+++ b/testsuites/smptests/smpfatal03/init.c
@@ -0,0 +1,142 @@
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/counter.h>
+#include <rtems/score/smpbarrier.h>
+#include <rtems/score/smpimpl.h>
+#include <rtems/score/threaddispatch.h>
+#include <assert.h>
+#include <stdlib.h>
+#define CPU_COUNT 2
+static uint32_t main_cpu;
+static SMP_barrier_Control barrier = SMP_BARRIER_CONTROL_INITIALIZER;
+static void end_of_test(void)
+ printk( "*** END OF TEST SMPFATAL 3 ***\n" );
+static void acquire_giant_and_fatal_task(rtems_task_argument arg)
+ SMP_barrier_State state = SMP_BARRIER_STATE_INITIALIZER;
+ int i;
+ for (i = 0; i < 13; ++i) {
+ _Giant_Acquire();
+ _SMP_barrier_Wait(&barrier, &state, CPU_COUNT);
+ * Now we have to wait some time so that the other thread can actually start
+ * with the _Giant_Acquire() procedure.
+ rtems_counter_delay_nanoseconds(1000000);
+ rtems_fatal(RTEMS_FATAL_SOURCE_APPLICATION, 0xdeadbeef);
+static void wait_for_giant(void)
+ _Giant_Acquire();
+static void Init(rtems_task_argument arg)
+ uint32_t self = rtems_smp_get_current_processor();
+ uint32_t cpu_count = rtems_smp_get_processor_count();
+ printk("\n\n*** TEST SMPFATAL 3 ***\n");
+ main_cpu = self;
+ if (cpu_count >= CPU_COUNT) {
+ rtems_status_code sc;
+ rtems_id id;
+ sc = rtems_task_create(
+ rtems_build_name( 'W', 'A', 'I', 'T' ),
+ 1,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &id
+ assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_start(id, acquire_giant_and_fatal_task, 0);
+ wait_for_giant();
+ } else {
+ end_of_test();
+ exit(0);
+static void fatal_extension(
+ rtems_fatal_source source,
+ bool is_internal,
+ rtems_fatal_code code
+ if (
+ source == RTEMS_FATAL_SOURCE_APPLICATION
+ || source == RTEMS_FATAL_SOURCE_SMP
+ assert(!is_internal);
+ if (self == main_cpu) {
+ assert(source == RTEMS_FATAL_SOURCE_SMP);
+ assert(code == SMP_FATAL_SHUTDOWN);
+ end_of_test();
+ } else {
+ assert(source == RTEMS_FATAL_SOURCE_APPLICATION);
+ assert(code == 0xdeadbeef);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpfatal03/smpfatal03.doc b/testsuites/smptests/smpfatal03/smpfatal03.doc
index 0000000..32cf14a
--- /dev/null
+++ b/testsuites/smptests/smpfatal03/smpfatal03.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpfatal03
+directives:
+ - _Terminate()
+concepts:
+ - Ensure that _Terminate() drops the Giant lock so that other processors
+ waiting on the Giant clock can receive shutdown requests.
diff --git a/testsuites/smptests/smpfatal03/smpfatal03.scn b/testsuites/smptests/smpfatal03/smpfatal03.scn
index 0000000..f502b4e
--- /dev/null
+++ b/testsuites/smptests/smpfatal03/smpfatal03.scn
@@ -0,0 +1,2 @@
+*** TEST SMPFATAL 3 ***
+*** END OF TEST SMPFATAL 3 ***
1.7.7
