Uniprocessor Tests in SMP Configuration
    Sebastian Huber
    Sun Feb 23 10:14:58 UTC 2014
Hello,
I would do the following.
1. Implement the thread deletion on SMP.  I will work on this after the
profiling.
http://www.rtems.org/wiki/index.php/SMP#Thread_Delete.2FRestart
2. Use alternatives to task variables for all RTEMS support components,
e.g. the file system environment.  Here we can use __getreent() for
example with
struct S {
   struct _reent reent;
   rtems_user_env_t env;
POSIX keys should be moved outside the RTEMS_POSIX_API scope.
3. Disable the task variables via pre-processor on SMP and remove the
run-time check.
4. Add condition variables to the Classic API.
5. Use alternatives to disabled preemption for all RTEMS support
components, e.g. bdbuf.
6. Disable RTEMS_PREEMT via pre-processor on SMP and remove the run-time
check.
We (= embedded brains) have currently only a budget for 1.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
