Uniprocessor Tests in SMP Configuration
    Gedare Bloom
    gedare at rtems.org
    Mon Feb 24 01:19:43 UTC 2014
Any of 2, 4, and 5 could be made into reasonable GSoC projects if we
get accepted as an org?
On Sun, Feb 23, 2014 at 5:14 AM, Sebastian Huber
> Hello,
> I would do the following.
> 1. Implement the thread deletion on SMP.  I will work on this after the
> profiling.
> http://www.rtems.org/wiki/index.php/SMP#Thread_Delete.2FRestart
> 2. Use alternatives to task variables for all RTEMS support components, e.g.
> the file system environment.  Here we can use __getreent() for example with
> struct S {
>   struct _reent reent;
>   rtems_user_env_t env;
> POSIX keys should be moved outside the RTEMS_POSIX_API scope.
> 3. Disable the task variables via pre-processor on SMP and remove the
> run-time check.
> 4. Add condition variables to the Classic API.
> 5. Use alternatives to disabled preemption for all RTEMS support components,
> e.g. bdbuf.
> 6. Disable RTEMS_PREEMT via pre-processor on SMP and remove the run-time
> check.
> We (= embedded brains) have currently only a budget for 1.
> rtems-devel mailing list
> rtems-devel at rtems.org
