Uniprocessor Tests in SMP Configuration
Mon Feb 24 08:59:35 UTC 2014
On 2014-02-24 09:09, Joel Sherrill wrote:
>  > > 2. Use alternatives to task variables for all RTEMS support components, e.g.
>  > > the file system environment.  Here we can use __getreent() for example with
>  > > struct S {
>  > >   struct _reent reent;
>  > >   rtems_user_env_t env;
> I am missing some detail here. Can you provide details?
Each thread can have its own file system environment.  So we need some sort of
thread-local storage.  Since applications using a file system will very likely
also enable the Newlib re-entrancy we can re-use the __getreent() function for
the file system environment.  In newlib_create_hook() we create a structure
struct S {
   rtems_user_env_t *env;
and assign it to thread->libc_reent;
The file system can then use
(struct S *) __getreent()
to get its file system environment.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
